A measured value of 0.46 ohms indicates that there's almost certainly absolutely nothing wrong with it. Its near impossible to get an accurate measurement of fractional ohm resistances with any two wire meter, and even if you removed it and did a four wire measurement with a bench meter with that facility, the acceptable +/-10% tolerance range for it would be 0.351 to 0.429 ohms.
Its reading approximately 0.3 ohms higher than its upper tolerance limit, which if measured by a two wire meter, is either due to contact resistance, and/or due to other accuracy limitations of the meter.
TLDR: it isn't broke, and unless you've got another unit that it has blown in, you don't need one!
P.S. it is *NOT* just an ordinary resistor. Fusible resistors are designed and constructed to rapidly go open circuit on serious overload, without catching on fire. An ordinary resistor may well survive even a x10 overload, and if it doesn't frequently catches fire.
