Hi there,
I want to preface this by saying I am totally new to wiring up electronics and could really use a pointer. I am trying to wire up a exhaust flap actuator Kuster 3 pin) to a wireless control board (DieseRC 433Mhz 1 CH Universal Wireless Remote Control Switch DC 12V).
The thing I am not certain about is where do I attach the white wire. The actuator has 3 wires, black (gnd) red (12+v) and a white (I assume is some sort of signal wire).
Here is the attachment so far:
DC 12V+ to 12V+ on the board
DC 12V- to 12V- on the board
Jumped 12V+ to COM on the board
Red wire from the actuator to NO on the board
Black wire to 12V- on the board
That leaves the white wire which I don't know where it should go. Note that the remote control when pressed ON or OFF doesn't do anything. However if I touch the white wire to ground on the board, the actuator will respond.
Any help appreciated.
