Author Topic: Wiring Ultrasonic transducer driver  (Read 1139 times)
Offline VictorrTopic starter
« on: May 23, 2019, 08:08:54 pm »
Hello guys i'm new to the forum.
I need some info about the correct wiring of the AC input on the driver. Maybe someone can help me.https://ibb.co/SJ8q4sr this is a picture showing it. Do i just need to connect live and neutral ? Don't i need to ground anything? Is there a specific plug for such an AC input?
Thank you
« Last Edit: May 23, 2019, 08:10:42 pm by Victorr »
Online Zero999
  • 0999
Re: Wiring Ultrasonic transducer driver
« Reply #1 on: May 23, 2019, 09:42:55 pm »
I would connect the neutral to the left and live to right, as that's the side with the fuse, although it really shouldn't matter. It should always be operated inside an case, which should be connected to earth, if it's made of metal.
