Hi, can someone more experienced to say if this cable was properly shielded?
I am replacing the USB connector of an old keyboard. It's a "low-speed USB device". Between the four USB conductors "VCC,D-,D+ and GND" there is a bare wire which I called "sh" (in yellow on the picture). Which is connected directly to GND inside the keyboard and to the outer metal body of the male USB connector. There is also a foil around all conductors I called "sh2" (in blue on the picture).
There is no continuity between the blue "sh2" foil and yellow "sh". Shouldn't "sh2" and "sh" be connected together for proper shielding?
Thank you.
