I never use multimeters for mains. I only use it in the 1-12V range. Maybe 24V some times. But yes, i'm going to order the Brymen 869S.
In some cases you can implement industrial panel meters to monitor fixed voltage ranges. You will need to look around but they can sometimes make sense if you don't mind a little bit of work to mount them. The idea is that a custom installation can avoid a the trouble of hooking up a meter constantly.
As for the Brymen do make a point to get rid of the alkaline batteries. Try rechargeable if the unit will operate with them or Lithium primary cells. I can't over state how disgusting it is to open up a battery compartment and see the result of a massive alkaline battery leak.
Sadly the common practice of pulling the batteries when not in use, is a pain on a lot of multimeters so I'm not sure that is a good alternative with this model.
The only Fluke that looks good, and have big screen cost around 800 dollar. I'm talking about Fluke 287. Insane price to pay for an hobbyist. For that price i can get an very good laptop, AND a good enough multimeter.
Well if you look at a top end Fluke and compare it to a entry level DMM it will look to be expensive. To get into the hobby I wouldn't recommend a new Fluke, as there are plenty of low cost entry level meters out there. Get started with a low end meter, just realize that a lot of the check box features that the meter makers market are not used all that often if at all. The basic features are what you will be using for a good long time.
As others have already said in the long run you will need more than one meter. When you get to the point where you really need additional meters you will likely be able to justify a higher price. You will also have a better idea as to what features are important to you.
By the way many of us started out with analog meters. Shocking yes to the young ones out there, but if you find an operable used one, at at reasonable price, pick it up. Often people get obsessed to resolution of a reading out to the nano volt but that is rarely needed and never by somebody just getting into electronics.
