Hi, I have this circuit, it's basically an electromagnet which discharges capacitors into a coil. Works with high voltage.
The 25w/25Ohm resistor keeps failing and disconnecting. What kind of resistor should I use so that it doesn't fail?
Also, I run it at 1 pulse every 20 seconds. The coil runs cool.
