No. NOT exactly as shown. There aren't any extra fixing holes that could be used to give the transformer a separate earth for its core, so as a minimum use a Nylock or other type of locknut + a Belville or wave spring washer so the ground connection remains effective even if some idiot tries to turn that mounting screw without opening the case. The IEC power inlet fixing screws should also be grounded, and unless the rear of the connector is shrouded, they should also be locknutted as there is a significant short-circuit risk if the ground wire to them comes loose and it and the socket are flapping around.
Fortunately there aren't any metal bodied toggle switches - grounding them (or other metal bodied controls) safely in a plastic case can be a royal PITA.
