Hello everyone, newbie here.
After a few months thinking about it I started to design my own power supply and after a few itherations finally got something promising, it all works fairly well until tried to implement a self made High side current sensing amplifier that could measure the current through a shunt resistor user for short circuit protection.
After some research I whipped up a somewhat functional circuit based on an opamp, two voltage dividers and a few resistors nonetheless this circuit is not working as intended as the output voltage is offseted by at least 1.465V, is there any way to bring down the output level to 0V at 0V input?.
Schematics and simulation results attached
Edit: Added the application note from which I based this design, te base design is in figure 2 (pages 2 and 3)
