I built a LESLIE (tm) SPEAKER personal copy.
Not sure about trade and legal laws: certainly don't be going into that business...but...
At any rate you use a 12 inch speaker, for nice good bass end bottom. Speaker points upwards, plus there needs to be a bearing, co-axial, I used 3 thin 'spokes' suspending that bearing, while you've got a rotating 'horn' up there, using the bearing.
Another option, puts speaker up top, enclosed in wood box, points down, into mouth of rotating horn. Like a carousel, I liked to include a strong metal axel, plus a second ball bearing raceway (roller skate-like), down at bottom end of axel shaft.
It helps to use a low power Variac, I got lucky and salvaged a nice Variac... No pulse EMFs caused by electronic switching for motor speed. Variacs produce adjustable voltage outputs, with no pulse output.
For reference, see most Hammond Organ literature.
Great for 'airing out' your guitar sound space...
