Author Topic: Would an "one transistor amplifier" be a "class A" amp?  (Read 931 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
« on: November 29, 2019, 12:14:34 am »
If you had a simple BJT circuit where a (audio) signal was fed into the base and a load was put on the collector would that be considered a class A amp since it would be amplifying all the time? But doesn't a class A amp also pull the same current whether or not there is a signal on it, and this would pull almost none when there is no signal, like in AM modulation with no audio on it,  Maybe I'm trying to over simplify.  :-//
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline oPossum
Re: Would an "one transistor amplifier" be a "class A" amp?
« Reply #1 on: November 29, 2019, 12:39:34 am »
The circuit has to be biased in a way that allows current flow through all transistors all the time. It is possible to bias a one transistor (or one tube) circuit to meet this requirement. It is also possible to use a 'sliding bias' that greatly reduces idle current. Some say that this is not 'true class A'.
Offline oPossum
« Reply #2 on: November 29, 2019, 12:50:06 am »
A simple one transistor Class A amp can be made with a depletion mode MOSFET (IXTH20N50)... http://www.firstwatt.com/pdf/art_delite.pdf
Online ejeffrey
« Reply #3 on: November 29, 2019, 04:21:50 am »
Yes, a single ended amplifier is an example of class A since the lone transistor is always in conduction.
It needs to be biased such that the transistor is conducting about 50% max current at 0 volts input because it can't swing past zero.  This is normally accomplished by capacitively coupling the audio input and adding a DC bias circuit to the base which could be as simple as a couple of diodes forward biased, or a more complicated servo.
Offline rstofer
« Reply #4 on: November 29, 2019, 03:05:59 pm »
W2AEW does an excellent job of explaining this stuff:
