Thanks for your reply. Regarding what you talk about with external resistors, would the scheme be something like they show in
Figure 3 of this App Note? It is annoying that this wasn't expounded upon in the datasheet and was only briefly mentioned.
Yes, it appears that for unused inputs, internal resistors set the output to a defined HIGH state as per the datasheet.
It's kind of late to be asking, but is it really necessary to have the termination resistor? The receiver isn't being driven by another LVDS driver IC, but rather it receives an LVDS signal-pair (at least, that's what the device manual says; no indication of how this signal is being driven, no schematic. All it says is signals are LVDS type) and converts it to a single-ended signal. I was testing this scheme with another part, the AM26LS32, and it worked when there was no resistor at the inputs (yes, I know the part not meant for LVDS, but as a proof of concept, it achieves the goal).
