Author Topic: x86 industrial motherboard with unknown connector  (Read 1114 times)
Offline crazy_driverTopic starter
« on: July 28, 2019, 09:12:14 pm »
Hi, i have this motherboard on my wheel balancer. SECCO Italy CS478 REVB
Geode 200mhz 8Mb sdram
All i can find in google is that it is a DIN 41612.
https://www.conrad.com/p/assmann-wsw-a-cf96abct-spring-pin-design-c-straight-number-of-pins-96-a-b-c-742287
I am afraid that the motherboard will die again (already did twice)
Is it possible to adapt this pinout to a isa or pci to use on a more modern motherboard?
https://www.amd.com/system/files/TechDocs/5530a_db.pdf
« Last Edit: July 28, 2019, 09:28:40 pm by crazy_driver »
Offline amyk
Re: x86 industrial motherboard with unknown connector
« Reply #1 on: July 29, 2019, 01:22:05 am »
Figure out why it's dying first...
Offline Per Hansson
« Reply #2 on: July 29, 2019, 06:33:20 am »
https://en.wikipedia.org/wiki/DIN_41612
Often used in what is called the European industrial connector.
Many times it is just a standard PC/104 interface in a special connector.
For being mounted in a 19" rack...
« Last Edit: July 29, 2019, 06:36:05 am by Per Hansson »
« Reply #3 on: July 29, 2019, 08:48:50 am »
it died because of memory, i think the onbord 8Mb are not ok so the first time i used a 32mb dimm and it worked for a little bit.
After that i even tryed to reflow the grafic chip but for nothing, i found another 64mb dimm and it works again.
i saw many boards with the 104 conector it would be a lot better to find than this.
Offline amyk
« Reply #4 on: July 29, 2019, 11:41:34 am »
Check the caps and especially the stability of the RAM supply voltage. They don't just die for no reason.
« Reply #5 on: August 27, 2019, 09:17:04 pm »
the caps look fine and i have 3.39v on the 3.3v rail.
What i see now is that the onboard memory is not working, only the 64mb that i added.
