You don't say if you are using Winx or Linux, I believe from my experiences there are some differences in USB pickup.
MPLABX is horrible in just about every way but we are forced to use it to support newer chips! MPLAB8 being a bit long in the tooth.
I find with X it is soooooo damm slow I don't try doing anything fancy so just one thing open at a time
The two problems I have encountered with PK3 are :-
It has to be plugged in before you start X
If it reloads the PK3 firmware it will be incompatible with MPLAB8 firmware reloads! (Workaround is change FW if required under X then use it under 8
If your not using C might I suggest sticking to MPLAB8, so much better and faster
