I will do the Version with 1 OpAmp per channel. The only problem there, what OP-Amp can be used best? I want to try some Surface mount stuff, to test my new soldering iron.
I'd love, if you can tell me about a good SMD OpAmp, that has a good quality and is not to difficult to wire up. It also should not cost so much. I mean, the TDA2822M is a Hi-Fi OpAmp - or let's just say, it more is like High-End quality, but how to find something with enought inputs, so I do not need 300 OpAmps, cause they only handle 2 channels?
Can't wait, to do some SMD soldering work. <3
Well, I get money in 1 month... Will have to wait, but I can plan all yet.
Edit:
What about the "TLC 274 CD SMD"?
