I'm trying to repair a PSS-590 keyboard, it worked well a few months ago but today it keeps creating random noises and random display when I power it on.
So opened it up then I reworked all the solders. Now it starts with the right display ("000" on the 7 digit displays) but no sound and the interface doesn't respond at all (pressing any key does nothing).
I also noticed two leds randomly flickers with varying intensity while they should be completely on or off.
Power supply is OK (+5V), the sound amplifier part too. The keyboard scans the button matrix I see the pulses. But I noticed that some 8-bit communication between two IC's YM7138 (sound chip) <=> XH748A0 (mask rom I think) is totally weird, see what I probed with my scope (attached pic)
It's the same on all the 8 data lines. Random levels instead of clean 0/5V pulses.
I'm not very experienced in repairs but does that mean the IC went bad (for no apparent reason)? I'm short of ideas, I probably could remove some caps to test them for high ESR (although they look perfect) but if you have more ideas to try let me know
