Discrete pre-regulators have traditionally been used in places where the supply voltage may exceed the main regulator's maximum voltage rating.
For instance, in large trucks with a nominal 24 volt bus, the load dump transients may exceed 90 volts (if I remember correctly), so it was customary to use a pre-regulator for the purpose.
Another reason was to lower the total power dissipation in the main regulator.
