Author Topic: Zener circuit not working as expected  (Read 1222 times)
Offline @rtTopic starter
« on: March 05, 2020, 03:12:15 am »
False alarm.. mods please delete.
Transistor was shorted collector to emitter.
« Last Edit: March 05, 2020, 04:02:47 am by @rt »
Offline greenpossum
Re: Zener circuit not working as expected
« Reply #1 on: March 05, 2020, 04:03:44 am »
Even so, you need to calculate the series resistor so that you're running the zener on the slope, not where a little leakage current will turn on the transistor if it has enough gain. A zener is not a perfect threshold switch.
Offline Zero999
  • 0999
« Reply #2 on: March 05, 2020, 10:00:54 am »
And a zener probably isn't required in this application, just use a higher value base resistor. The relay is also missing the important flyback diode across the coil, to protect the transistor against the back-EMF, when it turns off.
Offline JoeyG
« Reply #3 on: March 05, 2020, 10:35:32 am »
No diode snubber across the coil to protect the transistor???
« Reply #4 on: March 05, 2020, 01:11:09 pm »
No, the transistor was out of a junk box and already no good.
My circuit does have the protection diode, caps for the reg, and another diode for reverse polarity protection.
