I can recommend the Digitech QM1321 from Jaycar here;
https://www.jaycar.com.au/economy-true-rms-autorange-multimeter/p/QM1321It’s AU$40 and for that price is a pretty good meter.
It’s a re-badged Honeytek HK68A and when you click on the link to the user manual in the above page it actually brings up the Honeytek HK68 series manual. This is definitely the HK68A identical to the image but yellow and the QM1321/HK68A doesn’t have temp reading and is 4000 count.
https://www.jaycar.com.au/medias/sys_master/images/9047422009374/QM1321-manualMain.pdfThe only thing I did was replace what
** APPEARED TO BE *** 10A/500mA ceramic HRC AG3 fuses (unbranded) with the SIBA® equivalent.
It comes with PVC test leads which are a knock-off of the Silicon Fluke® TL71 and for PVC leads are quite OK to use, low resistance, and good connections (i.e. no wobbly readings with probe movement).
It’s claimed basic DC accuracy is 0.5% but this is only 0.5% + 3 digits up to 400mV at which it becomes 0.08% + 3 digits.
Despite the 0.8% accuracy, I’ve tested it against my PentaRef at 1, 2, 3, 5 & 10 Volts and at 12, 18, 24 & 30 volts from my PSU with my Fluke® 28ii as a reference and it’s within a “bees d1ck” and certainly good enough for home use. Also OK on VAC ~ 240V with close enough accuracy on frequency and duty cycle.
It’s 3.75 digit + 4000 count + True RMS + Auto ranging + auto power-off + built-in NCV which is all you need in a home DMM. There is also an ordinary vinyl case for it for AU$6 odd bucks!
I made an accuracy comparison chart to monitor “drift” of my DMMs. It’s a bit anally retentive I know but I’ll post it anyways to show this thing is well and truly within it’s spec. Mebbe I got lucky and got the “good egg”?
Cheers
EDIT: They have a Lifetime warranty which is a straight swap for a new unit, no sending off for repairs
