Author Topic: PWM circuit - calculating capacity and resistance  (Read 826 times)
Offline Drake122Topic starter
  • Country: hu
« on: February 21, 2018, 10:40:17 am »
Hey guys!
I was trying to make a PWM circuit, but don't really know how to calcaulate the discharge cap and the pot to use to be able to maximize its "bandwith". This test circuit I made in EveryCircuit only regulates the amps between 27.9 and 30. How can I make as close to 0 and 30 as it can get?
Offline danadak
Re: PWM circuit - calculating capacity and resistance
« Reply #1 on: February 21, 2018, 12:02:49 pm »
Some questions -
1) What is the bandwidth of the oscilloscope you are using ?
2) You mention amps, what does total circuit schematic look like ?
3) You referred to BW, normally a PWM is low pass filtered into DC. If you need
it I have an ap note on calculating filter values which control ripple and settling
time in the DC output.
Another approach -
http://www.instructables.com/id/Yet-Another-Simple-Pot-controlled-555-PWM-generato/
Regards, Dana.
  • Country: hu
« Reply #2 on: February 21, 2018, 02:15:05 pm »
Thanks, but its just a test :P I'm trying to learn electronics, so for now, I just want to make that circuit, which I made in EveryCircuit work. Posted a screenshot. I'm not able to lower the amps on that lamp.
