Poll
How long until we shut off the power.
< 5 sec?
0 (0%)
idk
0 (0%)
Total Members Voted: 0
Author Topic: Zynq Xilinx overheating  (Read 1183 times)
Offline AjaySTopic starter
« on: May 31, 2019, 04:13:04 pm »
I was working with a Zynq Xilinx FPGA running at 3.3V. For some reason, I did not realized that my power supply was shorted and I stopped getting the output. I tried checking by taping my finger on the FPGA and it nearly burnt my finger. I have no idea why it was too hot. I immediately turned the main power supply off. I am still figuring out why it was shorted but is the FPGA ok? I did no see any smoke coming out from it. Once I figured out the short with the power, I will plug the power back in. Also, how long do we have (if something is heating up) to turn the power off and the chip is still safe?
Online wraper
  • Country: lv
Re: Zynq Xilinx overheating
« Reply #1 on: May 31, 2019, 04:27:48 pm »
There is no predetermined time. If something goes wrong, chips may be bust in milliseconds or survive for hours.
Offline 0culus
« Reply #2 on: May 31, 2019, 04:45:43 pm »
Not an FPGA, but I recently had an LM386 survive quite a bit of trying to find where the output was shorting to ground. Like wraper says, it might blow instantly or survive for hours.
Offline Fred27
    • Fred's blog
« Reply #3 on: May 31, 2019, 04:52:02 pm »
Getting hot is not a good sign, but you might be lucky.
Online mikerj
« Reply #4 on: May 31, 2019, 05:25:57 pm »
Do you not think the two issues are very likely related?  Something has probably killed the Zynq which then started drawing a very high current from your supply.
Offline dmills
« Reply #5 on: May 31, 2019, 06:46:23 pm »
I hope that 3.3V was only applied to the HR IO pins... 3.3V on the core or PS supply lines is an expensive mistake in a time measured in factions of a millisecond.
Regards, Dan.
