Author Topic: 194 distance sensor  (Read 5991 times)
Offline bruce273
194 distance sensor
« on: August 08, 2011, 08:02:04 pm »
Nice bench :),
Got this sensor for my car but should do what you want. Could even have one half of the sensors on your wall or something aswell :)
eBay auction: #http://www.ebay.com.au/itm/Car-LED-4-Parking-Sensor-Reverse-backup-kit-many-color-/320670199952?pt=AU_Car_Parts_Accessories&hash=item4aa96ef090
Offline Chet T16
  • Country: ie
    • Retro-Renault
Re: 194 distance sensor
« Reply #1 on: August 08, 2011, 10:01:45 pm »
Just bolt a length of timber to the floor in front of where you want the front wheels to stop, simples!
Chet
Paid Electron Wrestler
Offline Lightages
  • Canadian po
« Reply #2 on: August 09, 2011, 07:04:12 am »
Dave:
I have to agree with the piece of wood bolted to the floor, KISS!
And to protect your car from the inevitable bits and things being pushed off the back of the new bench, put two pieces of wood to your rafters to hold the bench up on the end and back,and then put a piece of pegboard as a back board to the new bench. Then you can hang cables and other things there out of the way too. You can never have enough storage!
Alex
  • Guest
« Reply #3 on: August 09, 2011, 04:28:00 pm »
Here, cut the top of this and glue it on the side of the supporting beam. Provides audible indication and is child friendly.
http://www.a-zara.com/images/products/d101%20large.jpg
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #4 on: August 09, 2011, 04:51:20 pm »
I think the necessary impact speed may lead to "issues"
Chet
Offline Freighternut
« Reply #5 on: August 09, 2011, 11:47:46 pm »
The KISS principal is totally inappropriate in this case. After all we are electronics engineers / enthusiasts.
I would go with a Ultrasonic or possibly IR sensor approach, there are plenty of options in both cases. As a side benefit, wire it into your alarm system so if somebody steals you car or, god forbid it, the bench, an alarm would be triggered.
Save the earth - Travel the world by Container Ship! Almost zero carbon foot print
Offline Rufus
« Reply #6 on: August 09, 2011, 11:58:12 pm »
With space apparently at a premium why is so much is allocated to keeping a car a bit warmer and cleaner?
Uncle Vernon
  • Guest
« Reply #7 on: August 10, 2011, 01:32:50 am »
Cooler too! Come Western Sydney summer, parking in a garage will equate to around 50°C lower cabin temperature. Most Aussie kids have copped Kingswood upholstery burns to the back of their legs at one time or another. It's almost considered a rite of passage.
Offline Lightages
  • Canadian po
« Reply #8 on: August 10, 2011, 03:32:23 am »
In that case, he should install an ultrasonic sensor in the garage and a controller that monitors the speed of the approaching car. The controller would then send a signal out by bluetooth which would be received by a bluetooth receiver and controller in the car. The controller in the car would then apply the brakes through a servo. The controller in the garage could then smoothly apply the brakes so that the car comes to a comfortable and smooth stop every time at the same spot. The controller in the garage could also then automatically close the garage door when the car is in the correct position and turn the car off and apply the hand brake via bluetooth and servo in the car again.
The controller would then relinquish control until the next time it detects motion toward the ultrasonic sensor.
But just in case the power fails, the backup would be a piece of wood bolted to the floor.
 ;D
Offline joelby
« Reply #9 on: August 10, 2011, 05:11:01 am »
It also saves the hassle of waking up to find your car on bricks with the wheels missing. Insurance premiums can be cheaper if your cars are kept secure.
« Reply #10 on: August 10, 2011, 12:13:48 pm »
Excellent Lightages, you are on to it!
Couple all that with a large display on the bench back board facing the driver showing entry velocity and distance to impact with the bench.
If the wireless auto stop system failed to stop the car, Dave having feedback from the display could hit the brakes in time to prevent demolishing the bench.
The system could be referred to as a  BDPD (Bench Demolition Prevention Device).
Cheers, Roger...
Offline Richard W.
« Reply #11 on: August 10, 2011, 08:28:23 pm »
I would suggest 2 "distance sensors".
The technical one: photoelectric barrier (maybe more reliable than ultrasonic sensors)
The backup one: timber beam (if the technical solution fails...)
Offline James
« Reply #12 on: August 11, 2011, 11:50:02 am »
WORST CASE SCENARIO
Car won't start and bonnet needs to be lifted! :)
Anyway, nice job Dave. Besides providing you with alerts and saving the bench, a distance sensor would make a great tutorial covering the circuit design, software design (depending on the hardware), implementation and testing of the device!
James
All electronic devices work off smoke...Once the smoke is let out they no longer work!
Offline Dieselrunner88
« Reply #13 on: August 11, 2011, 05:09:22 pm »
The distance sensor is a better idea than the wood blocks.  Maybe even have it count down to zero and have a warning if you go to far in.  The Idea I had for the corner of the table was to "hang" it from the roof with a small steel cable.  According to engineering toolbox 6.4 mm can handle safe load of 498kg.
Scavenging for parts.  What is this?  oh well I'll throw it in with the rest of the unknown stuff!
Offline larry104
« Reply #14 on: September 07, 2011, 08:50:03 pm »
Low tech solution: hang a string down from the ceiling with a tennis ball at the end so the ball just touches the windshield when parked at the correct spot - I guess it's called a tennis ball car stop ;)
Offline Lawsen
« Reply #15 on: September 13, 2011, 12:31:51 am »
The hanging tennis ball on a string was done successfully at my friend's house to warn motorists from driving into a table saw or monitor top refrigerator.  I am sure garage door electric eye sensor connected to a relay and separate lower voltage LED light to indicate the car is in the limit.  Marking painted on the side wall that lines up with a feature on the car, so not to drive it too far or into the table leg.
