Author Topic: Amazon Kindle Fire Tablet Teardown - EEVblog #219  (Read 4094 times)
Offline firewalkerTopic starter
  • Country: gr
« on: November 23, 2011, 09:00:52 am »
It seems like they wanted a removable sd card first?
Offline EEVblog
Re: Amazon Kindle Fire Tablet Teardown - EEVblog #219
« Reply #1 on: November 23, 2011, 10:31:32 am »
I thought that for a second, but that's not like any SD card socket I've seen.
3G module perhaps?
Dave.
Offline timelessbeing
« Reply #2 on: November 23, 2011, 11:25:22 am »
Does the metallic tape simply shield what is directly beneath it, or does create a conductive link from the large shield to something else?  If it's the latter, how did you restore it?
Offline amspire
« Reply #3 on: November 23, 2011, 12:08:33 pm »
3G module perhaps?
Dave.
I suspect it is for a connector to an EEPROM emulator. I think the development time for the Fire was very tight, and I suspect the hardware had to be in production before the software was finished.
Flashing the eeprom to test the final unit can be slow, and if there are bugs, unreliable, so  it makes sense they test with a flash memory emulator.
Richard
Offline codeboy2k
« Reply #4 on: November 24, 2011, 05:29:44 pm »
3G module perhaps?
Dave.
Richard
The flash could be a disk-on-chip device (a flash module with an IDE interface)  and the 40 pin connection
is for an external IDE hard drive only used during development, as Richard noted.
