Author Topic: ANNOUNCEMENT + GIVEAWAY - EEVblog 2021 Survey  (Read 5244 times)
Offline EEVblogTopic starter
« on: August 31, 2021, 05:48:07 am »
It's EEVblog survey time again!
Plus a giveaway of a BM235, BM786, 121GW, HVP70, and CP2100B
Thanks in advance
Survey link: https://forms.gle/e4fwzjMvgFjUHaWN7
The following users thanked this post: Muttley Snickers, DC1MC, sandalcandal, grrmachine, Labrat101
Offline sandalcandal
  • MOAR POWA!
Re: ANNOUNCEMENT + GIVEAWAY - EEVblog 2021 Survey
« Reply #1 on: August 31, 2021, 06:44:44 am »
Response submitted!
Disclosure: Involved in electric vehicle and energy storage system technologies
The following users thanked this post: EEVblog
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #2 on: August 31, 2021, 07:29:05 am »
FYI the form seems to require the respondent to be signed in to a Google account. Not sure if this is an option on the form, or something Google decides on a case-by-case basis, but I haven't needed to sign in to a Google form before. People without Google accounts obviously won't be able to, which is likely to create a selection bias (of a different sort to the selection of EEVblog viewers).
Offline tszaboo
« Reply #3 on: August 31, 2021, 11:52:00 am »
I really like the advanced tutorial videos. For example, last year I decided to make my own LCD, and the reason to do that was that you showed the process and the required work with it.
The issue is, they probably will get less views, and require a lot more effort to do. I mean, Greatscott, can "connect a battery to a FET to a motor" and get a million views, while your custom Heatsink design video has 60K.
There is no justice.
Also, how dare you  :D : Solar roadways.
« Last Edit: August 31, 2021, 12:15:10 pm by tszaboo »
The following users thanked this post: rsjsouza, voltsandjolts, Jacon
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #4 on: August 31, 2021, 12:12:11 pm »
I like the advanced tutorials, as well as other more detailed videos. However, I also like some of the entertaining ones as well. The fundamental difference is that more people want to be entertained than educated. Such is life.
I noticed that with my channel as well, and that also ties to the popularity of the Mailbag: elements of surprise entice the curiosity of the audience. In a multi-part series restoring a radio (Philips BX462A), the most popular video was when I had a setback and put it in the title.
All this is fascinating, and explains well the formula of successful "reality TV".
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #5 on: August 31, 2021, 05:46:29 pm »
Survey filled out & submitted.
@Dave The Lbry / Odysee Version of this video doesn't work.
Offline Bipolar
  • Country: aq
« Reply #6 on: August 31, 2021, 06:23:26 pm »
Same here. It wants a Google account (which I don't have). Maybe next time.
Offline andy3055
« Reply #7 on: August 31, 2021, 07:08:52 pm »
Done, at last, I used my Google account for something constructive!
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #8 on: August 31, 2021, 07:30:02 pm »
Completed the survey . & submitted . I don't normally do surveys but for You Dave I made a special exception
As this forum is a Winner winner chicken Dinner    :popcorn:
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline joeqsmith
« Reply #9 on: August 31, 2021, 08:08:22 pm »
Done! You beauty! Thanks.
You're welcome.
Online janoc
« Reply #10 on: August 31, 2021, 08:26:13 pm »
Filled  ;)
Offline thm_w
  • Non-expert
« Reply #11 on: August 31, 2021, 08:55:08 pm »
Works for me https://odysee.com/@eevblog:7/announcement-+-giveaway-eevblog-2021:7
Offline Barny
  • Country: at
« Reply #12 on: September 01, 2021, 06:58:22 pm »
Strange.
Within the Lbry-App, I get following Link: "lbry://announcement- -giveaway-eevblog-2021#7"
It looks like the "+" is messing up something.
When I try to start the video, I get the message that nothing is there at this position.
Offline james_s
« Reply #13 on: September 01, 2021, 08:39:07 pm »
It costs nothing to get one and you don't have to use it, you don't even have to use your real name. I always sign out immediately after I finish doing whatever I'm doing that requires it.
Offline richnormand
« Reply #14 on: September 01, 2021, 09:11:23 pm »
What ever happens from the survey be careful: don't mess with success....!!!
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline ssander
« Reply #15 on: September 01, 2021, 09:53:42 pm »
I'm in  :-+
Offline rsjsouza
  • Eternally curious
« Reply #16 on: September 02, 2021, 12:16:37 am »
Just don't forget to use privacy mode when you do it. Google will track your browser.
Offline Brumby
« Reply #17 on: September 09, 2021, 03:34:16 am »
Is the survey closed yet?
Offline james_s
« Reply #18 on: September 09, 2021, 05:56:39 am »
They'll do that anyway, Google has so many tentacles that resistance is futile. I just try to pollute my data profile with enough garbage to make it useless for marketing, and I block all ads anyway so it's kind of irrelevant.
« Reply #19 on: October 23, 2021, 11:16:36 pm »
« Reply #20 on: October 23, 2021, 11:18:32 pm »
The following users thanked this post: Labrat101
