If anyone decides to try and build a set of the laser probes, you will need some Write Once Read Never memory. I am the sole source in the US for WORN memory, but my prices are quite reasonable! The really nice thing about WORN memory is that the clock specs are easily achieved. It is so easy to use, I have never had an instance of anyone being unable to meet the specs for setup time. (t_setup = 150ns +/- whatever)
So, feel free to email me for your WORN memory needs! Available in DIP and surface mounts, in 1-128 bit word sizes, as well as every serial access version known, as well as several unknown versions.
