Author Topic: eevBLAB #8 - New Tektronix AGO3000 Oscilloscope  (Read 34968 times)
Offline c4757p
  • adieu
Re: eevBLAB #8 - New Tektronix AGO3000 Oscilloscope
« Reply #50 on: March 31, 2015, 10:31:14 pm »
Yes, Cpt. bigsky Obvious, many of us have.
Offline pickle9000
« Reply #51 on: March 31, 2015, 10:37:49 pm »
The next stage is quite obvious: Relativistic effects compensated oscilloscope - you choose your frame of reference, enter your speed, the speed of the measured system, any additional gravitational fields in place and you're in!
Star Tek
Online Lightages
  • Canadian po
« Reply #52 on: March 31, 2015, 11:25:15 pm »
This might explain why the traces on my DS1054Z are a bit above the center line. I am at 2500m altitude and the gravity is a bit less here. Oh well, time to hurt my wallet again.
Offline Trey
« Reply #53 on: March 31, 2015, 11:54:14 pm »
I think this video might have been published a little too early for us west of Greenwich!
D'oh!  :palm:
A problem well-understood is a problem half-solved.
The most important tool in your toolbox is your brain.
KC3BSY
Offline pickle9000
« Reply #54 on: April 01, 2015, 01:02:02 am »
So you obviously had some "Teknical" help. It's nice to see a company with a sense of humor.
Offline Smokey
  • Not An Expert
« Reply #55 on: April 01, 2015, 02:21:16 am »
I bet they get the extra memory bandwidth by using a bunch of these babies!
http://repeater-builder.com/molotora/gontor/25120-bw.pdf
Offline ozwolf
« Reply #56 on: April 01, 2015, 03:42:50 am »
Gotta get me some of that write only memory.
I reject your reality and substitute my own.
Offline ProBang2
« Reply #57 on: April 01, 2015, 04:26:26 am »
Conspiracy!!!    :-DD :-DD :-DD
Offline taylor12
« Reply #58 on: April 01, 2015, 08:30:32 am »
no wonder i cant decode my rs232 signal..........its got to be my DSO's time base is off right  |O
Offline yym
« Reply #59 on: April 01, 2015, 08:50:01 am »
It was about time, this scope is exactly what I need.
I needed better accuracy for some old project and no existing oscilloscope had gravity compensated oscillator. Compensating for the other stuff is relatively easy temperature, humidity, time of the day and such, but compensating for gravity it is more difficult.
I’ve found a DIY solution to achieve gravity compensation. Basically we fixed the oscilloscope in a device which allowed it to spin on one axis. After some experiments we’ve found that about 3000 rpm gave the best gravity compensation. It was difficult to get the power supply and signals to the spinning oscilloscope but it was doable. Reading the display was solved by using the simplest solution available, we just used a 3D TV active glasses and synchronized to the spinning frequency of the oscilloscope so it let light through only when the oscilloscope’s display was in the right position.
This improved much the oscilloscope’s accuracy but still was not quite enough for our project. So new ideas were developed, e.g. spinning the oscilloscope on all 3 axes should improve the measurements by at least an order a magnitude, but now we don’t need all that, thanks to Tektronix.
Does anyone know when this will be available, I would need it soon.
Offline rollatorwieltje
  • I brick your boards.
« Reply #60 on: April 01, 2015, 09:38:01 am »
Finally the T&M industry is catching up. High end watches have had gravity compensated oscillators since around 1800.
I wonder when they will introduced a cloud based solution. No more reference oscillator in your device, it could all be pulled from the internet.
Offline ornea
« Reply #61 on: April 01, 2015, 11:02:10 am »
I have had some success experimenting with connecting several crystal to a PIC (16F628) to improve accuracy by averaging out the ppm errors of the individual crystals.
After watching this eevBLAB I had a brainwave and have decided to connect a total of 6 crystals.  A pair in each x-y-z plane but in opposite orientation in an attempt to totally eliminate the effects of gravity.  Again the initial results look quite promising.  A side effect is that the PIC does not always startup properly after a power reset.
As with calibration, it takes quite some time to allow the experiments time to settle and ensure long term stability and the effects of gravity are actually cancelled.  Also need to ensure the results are repeatable and fix the startup issues.  I am hopeful experimenting with the crystal bypass caps may help.
« Last Edit: April 01, 2015, 11:03:48 am by ornea »
Offline mxmarek
« Reply #62 on: April 01, 2015, 11:32:57 am »
Hmm, never used a scope in a plane before.. should try it :)
Offline electr_peter
  • Country: lt
« Reply #63 on: April 01, 2015, 11:39:19 am »
I would not be surprised that Tektronix may have some interest in public/private space exploration, aircraft, etc. - offering scope compensated to gravity effects is a smart move.
Online Fungus
« Reply #64 on: April 01, 2015, 12:59:31 pm »
You also need to take relativistic effects into account for space travel (or even on the ISS), not just gravity.
Offline bitwelder
« Reply #65 on: April 01, 2015, 02:15:14 pm »
Hmm...
EEVblog #597 - Fluke 114 Kit Multimeter + Sparkfun/Fluke Rant: released on March 30, 2014
 :-X
Offline DH2ID
« Reply #66 on: April 01, 2015, 04:36:19 pm »
Hi Dave. I like your video about the great new Oscilloscope.
It's time someone constructed one to compensate gravity.
Well, I'm an obstetrician and I constructed one,
which compensates for gravidity also and makes a good coffee!
Alex
Online Fungus
« Reply #67 on: April 01, 2015, 05:42:33 pm »
Hmm...
The multimeter kit was a good one. Love the anti-static bags with their labels, etc.
Offline calexanian
    • Alex-Tronix
« Reply #68 on: April 01, 2015, 06:27:22 pm »
So I guess this means its Spring. What next. The infinite improbability scope?
Charles Alexanian
Alex-Tronix Control Systems
Offline schopi68
    • My stuff page
« Reply #69 on: April 01, 2015, 09:06:50 pm »
I wonder how the engineers in Tektronix compensate for these other variations, some of which cause 10x as much effect as gravity?
i am wondering too. They are using a TCXO with a better stability than any OCXO i know. Even aging is better - how did they do that (well okay - aging is mostly linear, maybe it's software-compensated)?
Offline JNB
« Reply #70 on: April 02, 2015, 02:41:26 am »
Actually I put a lot of high density bricks around my oscilloscope it really helps to attenuate and dampen the gravity aberrations where I live.  I have been doing this for years now and I am very happy with the results.  I am still working on compensating for the tidal variations from the sun and moon.
« Last Edit: April 02, 2015, 02:44:55 am by JNB »
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #71 on: April 02, 2015, 08:55:27 pm »
So...
Was that an April 1st video, or is it a real product?
I'm in Chile now, which is also upside down, but the date is N+1(+-50%), so i can't quite figure out if there was April 1st anywhere back then or not.
Tektronix page does look fishy...
Offline qno
« Reply #72 on: April 03, 2015, 07:24:56 am »
Its a winner.
I'll buy one if is equipped with the unique Tektronix patented
Write Only Memory (WOM) and the gold plated bi-stable switch glands.
I looked in the option list but I cannot find the 3 phase 400V AC version!
Why spend money I don't have on things I don't need to impress people I don't like?
Offline casinada
« Reply #73 on: April 03, 2015, 03:45:49 pm »
