Author Topic: eevBLAB #82 - Kickstarter Over-unity Gravitational Power Generator!  (Read 15113 times)
Offline EEVblogTopic starter
Two Japanese guys have been working for 30 years on a "Gavitational Power Generator" over-unity machine that produces 30-100 times the input energy.
The Japanese Patent office disagrees in an hilarious Kickstarter own-goal!
https://www.kickstarter.com/projects/sunteljp/the-gravitational-power-generator-eco-turbine/description
Offline FrankBuss
    • Frank Buss
Re: eevBLAB #82 - Kickstarter Over-unity Gravitational Power Generator!
« Reply #1 on: October 11, 2020, 07:29:22 am »
Why did he built it so big that it costs lots of money to attach a generator? Maybe the sad truth is that he started small and it didn't work, and somehow he thinks it will work when bigger. But the English information about it doesn't mention any upper or lower limits for the construction size.
Offline Domagoj T
  • Country: hr
« Reply #2 on: October 11, 2020, 07:37:17 am »
Like you said it in the video, that's just sad. Those guys had an idea, failed to realize it's impossible and got tangled up in the convoluted mechanism that obstructed their view of the basic fact that pumping water up the hill requires more energy than you can extract by bringing it back down.
The kickstarter goal of just $1000 tells me they're not trying to deceive people, just that they are completely naive, not only in technical aspect regarding conservation of energy, but in regards to economy and finances as well. $1000 for a mechanical project of that size is just ridiculous. If they think that $1000 is going to make a difference, they are in a very deep delusion. Shame, they seem like nice guys, and I really feel sorry for them.
Offline Circlotron
« Reply #3 on: October 11, 2020, 07:50:51 am »
At least they've probably had heaps of fun and excitement with it over the years. From that point of view I'd say it was worth it. Many people live lonely, unhappy and unfulfilling lives. They had a goal, even if it did eventually come to nothing.
« Last Edit: October 11, 2020, 11:06:15 am by Circlotron »
Offline VK3DRB
« Reply #4 on: October 11, 2020, 12:02:13 pm »
This is a sort of Japanese version of an dodgy Australian company called Split Cycle Technology. The dodgy CEO was roofing tiler who became very wealthy out of stock in Split Cycle Technology. They issued reports to shareholders that the motor was tested by NASA :bullshit:, which was misleading. The split cycle motor went nowhere, so Split Cycle Technology then came up with a hare-brained idea of air pressure powered bicycles to solve the world's energy problems, calling for further investment $$$. Split Cycle was a Queensland based company. Queensland is Australia's the home of get-rich-quick schemes and scammers.
I reckon for every 500 hare-brained ideas out there, one might have some substance; and that is being optimistic.
Offline Lord of nothing
  • Country: at
« Reply #5 on: October 15, 2020, 11:32:00 am »
Does such "Machines" not "just" use the Gravity?
I saw many of such Perpeto Mobile who are use the Gravity by shifting a weight.
Well there are many Energy Producing ways who use Gravity like a Hydro Generator who just use a River to give them the Energy.
A real Perpeto Mobile would even work in Space...
Made in Japan, destroyed in Sulz im Wienerwald.
Offline FrankBuss
    • Frank Buss
« Reply #6 on: October 15, 2020, 01:57:53 pm »
Right, hydro generators with rivers work, because they convert some of the potential energy of the water into electric energy. The difference compared to a perpetuum mobile is that it is not a closed system, and initially the sun created this potential energy of the water by evaporating the water.
But another idea: would it be possible to convert the orbital energy of the Earth to electrical energy? Spacecrafts use already this energy for fly-by maneuvers. But is it possible with a small machine on Earth? I guess someone already thought about it and explained why it is not possible, but can't find anything.
  • Country: at
« Reply #7 on: October 15, 2020, 02:58:29 pm »
 ;D Theoretically yes when you count the Moon and the Sea who rise and fall do to the Moon Gravity.
Maybe: https://de.wikipedia.org/wiki/Gezeitenkraftwerk
Offline Circlotron
« Reply #8 on: October 16, 2020, 05:59:11 am »
 If you had a gyroscope fixed to the ground with its shaft horizontal and pointing east west, spin it up and as the earth rotated it would impart additional rotation to the gyroscope and you  could tap off a bit of energy if it had low enough friction bearings.
Offline james_s
« Reply #9 on: October 16, 2020, 06:32:49 am »
This sort of thing happens all the time, it's one of the classic follies of people trying to build any type of over-unity machine. They keep adding complexity until it is complicated enough that they obfuscate the reasons it cannot work from themselves. Another classic mistake is thinking that it just needs to be scaled up in order for it to work. It can be mathematically proven that no such device can ever work so it's a waste of time to even try.
Offline FrankBuss
    • Frank Buss
« Reply #10 on: October 16, 2020, 07:39:43 pm »
This sounds like a cool idea. I did a quick sketch with Blender:
The black base is mounted to the north pole and the blue cylinder can rotate around the black axis. So when the green cylinder rotates, the whole blue construction would rotate 360° once a day, right? I think with some gears this could drive a generator. If mounted at an angle, it should work for other positions on the earth as well. Might be a good idea to try it with a smaller version first.
The following users thanked this post: daqq
Offline Circlotron
« Reply #11 on: October 16, 2020, 07:55:21 pm »
^^ That would work, but only very slowly of course. My version has the blue base connected firmly to the ground so it cannot rotate. As the earth rotates it imparts addition speed to the green flywheel that is already spinning at a useful rpm.  There is an exercise toy available that uses this exact principle, so it definitely works.
https://en.m.wikipedia.org/wiki/Gyroscopic_exercise_tool
The overall effect, besides slowing the earth’s rotation, would be to eventually tilt the whole earth somewhat, so it would be good practice to have another gyro at the South Pole oriented and spinning appropriately to counteract this tendency!
« Last Edit: October 16, 2020, 08:01:33 pm by Circlotron »
Offline Bud
« Reply #12 on: October 16, 2020, 08:02:57 pm »
They spent all of their retirement money and were short of just a $1000 ?  :bullshit:
Offline joeqsmith
« Reply #13 on: October 16, 2020, 09:41:07 pm »
One Small Engine for Man
One Giant Engine for Mankind
Pictures from my copy of their VHS tape.
Offline IanB
« Reply #14 on: October 16, 2020, 09:48:12 pm »
Of course. It is called tidal power. Not only is it possible, it has been the subject of serious investigation with various schemes proposed to implement it.
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #15 on: October 18, 2020, 07:38:03 pm »
Just love the Idea . :palm:
Found an alternative power source .
Runs off the grid   and uses peanuts to work .
Multi uses as well as per photo.
« Last Edit: October 18, 2020, 07:52:42 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
The following users thanked this post: schmitt trigger
Offline schmitt trigger
  • Country: mx
« Reply #16 on: October 19, 2020, 02:12:52 am »
Does the hamster run the hard drive? :D
Offline ejeffrey
« Reply #17 on: October 19, 2020, 05:29:47 am »
Tidal power mostly takes energy out of earth's rotational kinetic energy, not orbital.  i.e., it makes days longer not years.  But to answer the question as to why it is hard: you have to conserve not just total energy but also angular momentum.  The spinning earth can't just start spinning slower on its own, it needs to transfer that angular momentum somewhere and that somewhere is the moon.  In fact, some of the energy made available by slowing down the earth's rotation has to go to the Moon which is moved to a higher orbit by the effect, increasing its potential energy.  In any case, we really don't have any control over the process and we can't just extract an arbitrary amount of rotational energy from the earth.  Mostly the tides do what they are going to do, and we can either extract a small fraction of the energy or not.
Offline Labrat101
  • Regular
« Reply #18 on: October 19, 2020, 11:39:40 am »
   Of Course it does Direct drive . & There is a gyroscope in a vacuum bell with a horizontal mount pendulum  that rotates in sinc with the planet .
 ( like water always goes anti clock down a drain ) Northern hemisphere .
 The Vacuum bell not shown as its a patented secret  :-DD
Offline CoteRotie
« Reply #19 on: October 19, 2020, 03:55:00 pm »
Yeah, this is nothing but sad, poor guys.
Years ago I worked in a little industrial park- There was a real estate office a few doors down.  When the head of the real estate office found out we were engineers he asked us over to show us his "invention".
He led us into the back room where he had built a motor-generator set he'd worked on for five years with a switch so that once the motor spun up he could power it from the output of the generator, and tap off that for the "free energy".
Of course it didn't work YET, but he was close to making it work (any day now).
No matter how much we tried to tell him about efficiency, the second law, entropy, etc. he never gave up.  He might still be at if for all I know.
At least in his case it was a hobby and he didn't spend his life savings on it.
Offline Bud
« Reply #20 on: October 19, 2020, 04:58:53 pm »
A device working on this principle will still not be an overunity power generator, as there will be external power applied to it.
Offline Pulsepowerguy
« Reply #21 on: October 19, 2020, 05:42:30 pm »
This idea was described to me by a rather eccentric inventor in 1979. He had calculated the minimum necessary diameter of a hollow steel sphere as well as the angle needed to draw energy. He tried to get a patent on the idea, but the USPTO examiner rejected it as impossible. I think it is workable, and yes, it will draw energy form the earth's rotation, thus slowing it down.
Offline FrankBuss
    • Frank Buss
« Reply #22 on: October 31, 2020, 10:19:26 pm »
Cool, do you have details? How fast does it need to rotate? How much energy does it generate for a given size? Did the calculation consider friction etc.? Maybe if the inventor would build a prototype, the patent office would accept it.
Offline Labrat101
  • Regular
« Reply #23 on: October 31, 2020, 11:20:00 pm »
So you want to slow the Planet Down. Good idea ..  |O
 If we haven't got enough Hair brain scientist trying to do that already .
 Plan 'B' back up Planet is only 100 light years away .
 There Is No Free Energy. it always come at a dangerous Price.
 I would work on making a Rocket that can travel 10 time the speed of light first .
 So at-least you will survive the boring journey & a packed Lunch  :-DD
 & lot of big books to read.
 Or Just Make a vaccine for the Real Problem   ..
« Last Edit: October 31, 2020, 11:31:56 pm by Labrat101 »
Offline FrankBuss
    • Frank Buss
« Reply #24 on: November 01, 2020, 05:43:24 am »
World energy consumption per year is 5.7*10^20 J. Rotational kinetic energy of the Earth is 2*10^29 J. So you could power the whole world for 350 million years until the spinning stops. If we would do it only a few decades, until fission or whatever works, the rotation wouldn't slow down more than maybe a second per day. Doesn't look dangerous to me.
Offline Labrat101
  • Regular
« Reply #25 on: November 01, 2020, 09:18:56 am »
OMG
First you can just pull fictitious Numbers out of a Hat.
 Just slowing the Planet by a second . would cause an orbit change . If your not aware the polar
ice is melting this due to an imbalance of the planet. Water is heaver than ice .
 Rising the oceans helps natural forces to stabilise rotation.
If the Planet slows by just a few seconds ''as you say it."
 Orbit change & reversal of poles. would happen .
 If the Poles reverse it would not be .. As you said 350 million years .
 More Like 350 days .
 There is also an old saying.  IF it ain't broke, don't fix it ..
I suggest to stick to the simple things . LEGO would be fairly safe for you ..
Offline Circlotron
« Reply #26 on: November 01, 2020, 10:45:32 am »
^^ According to Encyclopedia Britannica tidal power is 3000 GW so that's 9.4608×10¹⁹ Joules per year slowing the earth down whether you like it or not.
And the same source quotes *electrical* energy consumption in 2016 as 21,000 terawatt-hours, so that's 5.83×10¹⁵ Joules.
If the rotating earth has 2x10^29 Joules that's enough for 34,285,700,000,000 years.
« Last Edit: November 01, 2020, 11:17:07 am by Circlotron »
Offline nctnico
« Reply #27 on: November 01, 2020, 11:42:48 am »
OMG
That is overly dramatic. Look into leap seconds and why we need them. The earth's rotational speed isn't constant at all: https://en.wikipedia.org/wiki/%CE%94T_(timekeeping)
Offline Labrat101
  • Regular
« Reply #28 on: November 01, 2020, 12:37:00 pm »
OMG
That is for our time keeping . (true)
 Not for the universal laws that govern the physical placement of the log spiral & helical plains that
 keeps our planet in about the correct orbit . Which Albert Einstein tried hard to get scientist to
Understand .. and still don't Get it . because one needs to know and understand 7D mathematics.
 Simple Example if you move 1 planet 1 degree all the others will follow at a log degree displacement .
 i.e. we would move closer to the sun .. That in turn would raise the temperature of our climate by the same ratio to the Log scale so 1 degree change could be about 10c and so on .
 Causing a chain reaction of equal and opposite damage .
 No I am not going to explain these physics & how they works .
 One reason why the world governments Don't tell people the WHOLE story .
 That includes NASA .  Too Much info is dangerous .
 So diversionary theory's are created to distract G.P.
« Last Edit: November 01, 2020, 02:04:52 pm by Labrat101 »
Offline Circlotron
« Reply #29 on: November 01, 2020, 12:52:48 pm »
For the world's governments to collude to hide something they would have to be united.
Over-unity is more likely than that.
Offline nctnico
« Reply #30 on: November 01, 2020, 11:38:38 pm »
OMG
That starts to sound interesting but somehow I don't think the effect is that dramatic (at least on a timescale less than a million years); there is so much happening in 'our' solar system that an equilibrium which is extremely sensitive would have failed a long time ago. For example: our own moon has shifted it's orbit a lot over time and nothing bad has happened. A link would be nice.
And we're back to conspiracy theories making what you wrote above so uncredible that I'm not going to bother to look it up.
« Last Edit: November 01, 2020, 11:41:50 pm by nctnico »
Offline james_s
« Reply #31 on: November 02, 2020, 11:24:56 pm »
The government can't even suppress the knowledge to break copy protection on DVD or bluray media, they haven't succeeded in stamping out file sharing of copyrighted music or movies, they hardly made a dent in it despite huge amounts of money behind the effort. Information has a tendency to get out and once the cat gets out of the bag it's impossible to put it back in. If somebody figured out how to circumvent the laws of energy, it would not take long at all for the knowledge to spread.
« Reply #32 on: November 03, 2020, 02:02:06 am »
OMG
Talk about pulling things from a hat. Such a lot of hand waiving, and no data to support it. Might as well predict that dogs and cats will sleep together.  :-DD
BTW, the rotation of the planet is reduced, not its orbit; water is denser than ice, not heavier. Rising oceans stabilize Earth's rotation?!!?!?! Are the oceans rising because of rocks falling into them?  :-DD
Offline Brumby
« Reply #33 on: November 03, 2020, 02:27:03 am »
Rocks falling into water would reduce the moment of inertia as (most) rocks are denser than water  Due to the conservation of angular momentum, this means the angular velocity must increase.
So there's your solution - just dump the densest, most useless material you can find into the sea.
Politicians come to mind - closely followed by over unity proponents.
The following users thanked this post: james_s
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #34 on: November 03, 2020, 07:54:24 am »
I would give you that advice actually. Leave this thread now or I will ban you from the whole forum for good!
The following users thanked this post: Pulsepowerguy
Offline steerex
« Reply #35 on: July 06, 2021, 10:02:03 pm »
didyou notice one guys name was "Takeshite" and the other "Ohno"?
Offline Labrat101
  • Regular
« Reply #36 on: July 07, 2021, 09:59:09 am »
One second is enough to set off more volcanic eruptions as the earth's core & and crust are already getting unbalanced .
If you hadn't heard about global warming etc.  Landslides.  Toronto's . flooding. And seas rising.  Messing with nature is not a good idea.
The mathematical formula is  . .
Pure speculation.
