Author Topic: EEVblog #1038 - Uni T UPO2104CS Oscilloscope Teardown  (Read 26641 times)
Offline EEVblogTopic starter
« on: November 16, 2017, 06:57:26 am »
What's inside the 4CH 100200MHz entry level Uni-T UPO2104CS oscilloscope?
« Last Edit: November 16, 2017, 12:15:13 pm by EEVblog »
The following users thanked this post: AlanS
Online ataradov
    • Personal site
Re: EEVblog #1038 - Uni T UPO2104CS Oscilloscope Teardown
« Reply #1 on: November 16, 2017, 07:27:09 am »
Video went down?
Alex
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #2 on: November 16, 2017, 07:33:12 am »
Why is there 20 seconds of dead air between 2:35 and 2:55?
Offline chriswebb
« Reply #3 on: November 16, 2017, 07:35:04 am »
The display artifacts were because the gradient was using black on the low range. When you made it one color, you saw that it was the signal and not a bug in the display.
Always learning. The greatest part of life is that there will always be more to learn.
Offline OzOnE
« Reply #4 on: November 16, 2017, 07:42:35 am »
@technix
Haha - I KNEW Dave couldn't let that go.
(may have been some other missing sections maybe?)
Looks like he's re-uploading the vid, and just when I was about to post an "amusing" comment. lol
Interestingly, I could still watch a fair bit of the vid as it was cached, but I made the mistake of refreshing, thinking that the error while posting the comment was a networking issue.
Oh well. I'll await the re-upload.
OzOnE
Online ataradov
    • Personal site
« Reply #5 on: November 16, 2017, 07:43:59 am »
It was not a mistake, I was just watching the video and it just abruptly stopped anyway.
Alex
Offline OzOnE
« Reply #6 on: November 16, 2017, 07:51:33 am »
Do you mean it stopped before the end anyway?
Ahh, OK. Just a rendering glitch then. No biggie.
OzOnE.
Online ataradov
    • Personal site
« Reply #7 on: November 16, 2017, 07:52:29 am »
Yep, stopped mid sentence, and static, and "Video is no longer available" or something like that.
Alex
Offline OzOnE
« Reply #8 on: November 16, 2017, 07:54:31 am »
Yep, that's where Mr Dave is likely re-uploading.
OzOnE.
Offline nidlaX
« Reply #9 on: November 16, 2017, 08:26:37 am »
Good to finally see a teardown of this scope, I recall there was a lot of speculation over its capabilities and OEM when it was released.
Offline iceisfun
« Reply #10 on: November 16, 2017, 08:34:55 am »
Are the function lockout messages at the end because independent time bases are enabled?
« Reply #11 on: November 16, 2017, 08:57:59 am »
Yes, you can't turn off any of the channels with the ind timebase enabled.
Offline snoopy
    • Analog Precision
« Reply #12 on: November 16, 2017, 10:56:17 am »
« Reply #13 on: November 16, 2017, 12:15:48 pm »
Fixed video is now back up.
Took a while, had to come back into the office after dinner and re-render.
Offline ChrisLX200
« Reply #14 on: November 16, 2017, 12:20:48 pm »
Thanks for the great review! I think at that price point I would wait to see the Siglent offering though. Did I see a date of April 2017 on your example? Maybe Uni-T already fixed some of the display issues you noted, but even so, too expensive to compete I think.
Offline tzok
« Reply #15 on: November 16, 2017, 02:32:47 pm »
I think he meant the Function Disabled for Decode due to Independent Mode enabled.
Offline tszaboo
« Reply #16 on: November 16, 2017, 02:44:59 pm »
Dave, you call a bunch of resitors around 10:50 termination resistors.  I would've guessed they are for configuration. First, only 1 of each pair is on the board. Also, all of them are 01C = 10KOhm. Maybe this scope can be hacked for higher speed/more memory very easily??
Offline Ondre
« Reply #17 on: November 16, 2017, 03:14:30 pm »
I saw that UNI-T is using thermal reliefs on the vias. Is there a good reason to do so? I usually connect them directly to the plane, unless I plan to solder bodge wires to them :-)
Offline don.r
« Reply #18 on: November 16, 2017, 04:54:49 pm »
If you do a shootout, please include the Micsig in there.
Offline NivagSwerdna
« Reply #19 on: November 16, 2017, 05:25:28 pm »
Too many bodges for me.  UniT won't be on my Christmas list.  (Nice sqiggles though)
Offline Hydron
« Reply #20 on: November 16, 2017, 05:44:14 pm »
Hi Dave,
The Analog Devices "DAC" part you found is actually an ADCMP562B (i.e. the bit after ADCMP looks similar to 5628). This is a "Dual High Speed PECL Comparator", which makes sense for a trigger section.
Thanks for the teardown, always interesting to see how they've spent their money in low cost stuff like this.
Edit: regarding the channel bias, my RTB2004 has a "Zero Offset" control in the vertical menu, which seems to do the same thing. I've found it handy a couple of times dealing with active probes with (small) output offsets - no idea of the range of the control.
« Last Edit: November 16, 2017, 05:57:37 pm by Hydron »
Offline smashIt
« Reply #21 on: November 16, 2017, 08:15:55 pm »
I'd guess that the "bodge" at minute 20 is just a flipped resistor.
Offline Someone
    • send complaints here
« Reply #22 on: November 16, 2017, 10:13:45 pm »
Same as the GW Instek GDS-1000B the power supply earthing connection (and other aspects of the mains wiring) don't meet Australian basic safety standards from AS3100, and would fail other regions standards too. No wonder you don't find many sellers for it.
Online nctnico
« Reply #23 on: November 16, 2017, 11:53:43 pm »
I've also found a bias control in a Yokogawa DSO but in the end it it controlled the same DAC as the trace offset.
Offline kcozens
« Reply #24 on: November 17, 2017, 04:06:08 am »
We know that Bob's your uncle but who is this Flynn person?  ;)  The two DDR memory chips were upside down. I was waiting for you to point out the electrons are going to fall out.
The UNI-T has better colour choices for the four traces vs the colours used by the Rigol 1054Z. I wonder if the 50 second boot time is due to the UNI-T possibly running a version of Windows based on it having a PrtScr button. For proper price comparison you have to look at the Rigol 1104Z. It has a price of $619 for the Rigol 1104Z so the UNI-T is only $20 less. The Rigol 1054Z wins on price if a user hacks the scope to enable its full capabilities. Have you hit the Display button to see if it has the XY display mode?
« Last Edit: November 17, 2017, 04:07:54 am by kcozens »
