Other small point, inverters don't cause a phase change. Only circuits with an inherent time delay can do that. I avoid saying things like that because it confuses beginners.
It may look like a phase change on a scope, but that is only the case with a symmetrical waveform. A pulse put through an inverter doesn't come out shifted in time by half the pulse interval. It comes out at the same time, opposite polarity.
Oh, and you're ignoring the inherent delay in any inverter, so its output is inverted and there's a phase change. If you're going to be unnecessarily pedantic, please do the job properly...
The scope projects an image of a 10 volt signal because it is unaware that the point of reference has shifted.
The scope projects an image of a 10 volt signal because it is unaware that the point of reference has shifted. ( when it shows -5 on the display it actually measures 0 volts but with its 'ground' tied to +5 volts... so it shows '-5'. When it shows +5 volts its 'ground' is tied to 0 volts. )
Here's the thought that popped immediately into my head...Would you be able to use this technique to power a dual supply op amp from a DC supply?
Be nice. I ask with genuine curiosity
Yes and there are chips specially designed to do it, they are called charge pump. You can either double the voltage or generate a negative voltage. The advantage by using a chip is higher output current and lower component count.
I think pouinting out that it is a full H bridge might help people to understand. you get to have negative voltages without a negative supply at the expense of floating the load. Widely used in controlling brushed motors and the basis of VFD's in the form of 3x 1/2 H bridges.
No you don't ! you can not rectify this signal. this is NOT how charge pumps work ! you need multiple capacitors for a charge pump and a switching system.
take that inverter put a bridge rectfier across it and see if you get 10 volts out of it ... you won't. this is not a 10vpp signal ! it looks like one bcause the reference is bouncing around and the 'moment in time' view of the scope let's you think ( it is visual persistence ) that this is 10 vpp. It is not. this is a case where the scope lies to you.
So I think maybe my question still remains unanswered...
Yes, your question still unanswered.
would you be able to use this configuration to convert a DC signal into an AC signal for powering a dual supply op amp?
I say no... Someone show a schematic if disagreed.
Doesn't this count as a bipolar signal? Wouldn't this allow the op amp to swing from positive to negative rails?
I say no negative voltage available... unless adding a 'rail-splitter' ?.
This is the way I've explained this to myself:
I'm in a two story house. I'm on the first floor and I measure up to the next floor and get +10 ft. Then I (change my reference and) go up stairs. Now I measure the distance to the bottom floor and get -10 ft. The difference (Vpp) between the two measurements is 20.
Think about that and watch the double NOT gate part again.
It is amazing how difficult it is to convince people of the facts. (Insert global warming here.) The popular "ping" ultrasonic sensors use a neat trick to get (almost) 40 V from a 5 V supply since they use outputs from a TTL to RS-232 converter, each at +/- 10 V. An inverse pair of these driven across the transmit piezo device is +/- 40 V in the ideal case (the charge pumps inside the MAX232 are not perfect, so its likely more like 35 V or so).
So there's this guy "Emil" who did a service to the world and reverse engineered these cheap modules on his site (see https://uglyduck.ath.cx/ep/archive/2014/01/Making_a_better_HC_SR04_Echo_Locator.html), but he would not believe me when I tried to explain this fact to him and he actually deleted my comments!I have a screen grab before he deleted the exchange somewhere here...
One question regarding the max232 output voltage -
if T1OUT swings between -10V to +10V while T2OUT sends opposite phase pulses of +10V to -10V, then when any of these outputs is taken as reference, the other pin voltage is +/-20V.
That shouldn't be considered a 40Vpp output ?
Thanks
Emil Submitted at 21:59:41 on 21 September 2016
Vpp means "point to point" - when one voltage is 10V above ground the other is 10V bellow ground so the absolute difference between them is 20V not 40V.
