Car speedos and aircraft instrumentation are designed so a pilot or driver can take a quick glance and roughly see if everything is ok or not.
For my hobby I have a 100k, 60k and 10k DMM, but in my boat I still have this 60 year old AMM from my dad which is perfect there:
- Never empty battery (biggest advantage for a meter hardly used)
- Excellent to see if there's a voltage or if the battery is full or empty
It is so convenient if you just need basic functions and no precision
Car speedos and aircraft instrumentation are designed so a pilot or driver can take a quick glance and roughly see if everything is ok or not.Agreed for aircraft. For cars you do not need the speedometer to get a rough measurement of your speed. Just look out throug the windshield!
Amazingly enough: You can power a digital meter from the boat battery itself, no need for a separate battery to power it!
If your analog meter falls in the sea, will you go looking for another old meter or will you install one of these for $2?
But that doesn't help you much if you need to fix something. If something doesn't work anymore you want to be able to figure out where the problem is
Analog meters are obsolete. Period.So is my old 486 computer running Windows 3.11 - but I still can't type faster than it can handle.
Quote from: oldway link=topic=106744.msg1462199#msg1462199e date=1522059297Analog multimeters are not safe at all, never use them on high energy circuits.....
What do you imagine we used before DMMs?
The AVO 8 & the like were very well engineered, with large clearances, heavy insulation, & thick Bakelite cases.
Because they were large, meters of this class were not used handheld.
Instead, they were placed on the floor, rested on a "Tech's stool", or hung up by the handle.
In any case, the operator could be a metre or more away from the meter & still read it clearly, which reduced the possibility of injury in the very unlikely event of the meter case being breached.
In more than 40 years working at high power Radio & TV transmitter sites, I only saw one AVO 8 which had been "blown up".
The Bakelite case was not breached, the movement was clearly charred, the dial glass was cracked, but not
shattered.
DMMs are mostly used handheld, & have lightweight cases, so your chances of escaping injury are that much less.I think you do not know at all the subtleties, or especially the weaknesses of the Avo 8 .....
First of all, I learned to drive with my father's Simca Aronde: this car had no seatbelts, no airbags, no ABS and was not crash tested ... and yet, everyone was driving with such insecure cars.
Safety standards have changed and it would be forbidden to drive today with such a car.
With regard to electrical safety, it's the same thing.
So to argue that we used in the past analog multimeters on high energy circuits, it's simplisly stupid.
You can't ignore actual safety rules.....
The avo 8 is very dangerous because it is the same terminals that are used for both the voltmeter and ammeter function .... an error can easily be made.
In addition, the so-called cutout protection does not protect anything because:
1) the breaking capacity of this cutout is very low
2) the protection is activated by the needle arriving at the end of scale stop ..... but if you are in range DC amps and you measure AC current, the needle does not move at all and does not cause the opening of the cut out.
Then, the principle that there is no danger because we do not hold the meter in hands is totally wrong and shows that you do not know anything about electrical safety.
In a high energy circuit, the risk comes from creating an arc that becomes explosive.
This arc is formed at the contacts, that is to say the test probes held by the operator and ionised air let the arc to close between phases with consequences of serious burns, damage to the eyes and a risk of electrocution.
With high energy circuits, every simple error have very serious consequences and it is not for nothing that the digital multimeters have special fuses with high breaking capacity in the current inputs.
I never argued that the speedometer should be removed, broken or something similar. End.Car speedos and aircraft instrumentation are designed so a pilot or driver can take a quick glance and roughly see if everything is ok or not.Agreed for aircraft. For cars you do not need the speedometer to get a rough measurement of your speed. Just look out throug the windshield!
shattered.
DMMs are mostly used handheld, & have lightweight cases, so your chances of escaping injury are that much less.I think you do not know at all the subtleties, or especially the weaknesses of the Avo 8 .....An unbiased observer might think that using the things every day, for decades, often in "high energy" circuits would give me a pretty good handle on its subtleties.QuoteFirst of all, I learned to drive with my father's Simca Aronde: this car had no seatbelts, no airbags, no ABS and was not crash tested ... and yet, everyone was driving with such insecure cars.
Safety standards have changed and it would be forbidden to drive today with such a car.In most Countries it is not, & you can still drive such old vehicles.
In any case, none of those things, except perhaps ABS adds one bit to the primary safety of the car, but only come into play if the driver does not avoid a perilous situation.Quote
You can't ignore actual safety rules.....As I pointed out, the AVO was inherently safer because of very heavy construction & proper engineering, whereas DMMs are handheld devices with quite flimsy construction.
CAT ratings were introduced after the introduction of DMMs.
"Safety rules" are more to do with how the testing is done, rather than the rating of the testing device.Quote
Many thousands of these instruments were used over decades without injury, mainly because the people using them followed correct safe operating procedure.Quote
Then, the principle that there is no danger because we do not hold the meter in hands is totally wrong and shows that you do not know anything about electrical safety.So now I'm both stupid & know nothing?
Like all those thousands of other Techs, EEs, & Electricians that used AVO 8 meters?
Do you often have these feelings of superiority?QuoteIn a high energy circuit, the risk comes from creating an arc that becomes explosive.
This arc is formed at the contacts, that is to say the test probes held by the operator and ionised air let the arc to close between phases with consequences of serious burns, damage to the eyes and a risk of electrocution.In most cases, it is possible to clip the probes in place & not have to "hold them".
OK, perhaps in the high energy circuits we tested it was usually possible to isolate the incoming Mains, connect the meter, then re-apply the power.Quote
The trick, (which isn't that hard), is to not make "simple errors").
Quote from: oldway link=topic=106744.msg1462199#msg1462199e date=1522059297Analog multimeters are not safe at all, never use them on high energy circuits.....What do you imagine we used before DMMs?
No. I wrote that to get a rough estimate of the speed you just look outside the window, something you are supposed to do anyhow (uber drivers excepted). If you need a more exact speed you obviously look at the speedometer. The argument was that the speedometer on a car doesn't have to be designed to give quick rough estimates compared to an environment where no other means to determine speed might not be available, such in an aircraft under certain conditions.
You used what was available, obviously.
That didn't make it safe though.
By cons, on this forum, you are in a public space and it is not acceptable that you publicly give advice contrary to safety.
"Analog multimeters are not safe at all, never use them on high energy circuits....."
when it comes to the safety, my opinion is that awareness of danger is more important that safety of the device itself. The more the device is "safe", the less cautious operator is.
