Author Topic: EEVblog #1078 - World's Thinnest Calculator Teardown  (Read 5259 times)
Offline EEVblog
« on: April 24, 2018, 11:32:06 pm »
A look at the amazing construction techniques used in the world's thinnest calculator by Casio
Destructive teardown on the Casio SL800 credit card calculator from 1983.
It's more interesting than expected!
The following users thanked this post: SeanB, ez24
Offline DeanCording
    • GitHub
Re: EEVblog #1078 - World's Thinnest Calculator Teardown
« Reply #1 on: April 25, 2018, 12:13:58 am »
Those caps would probably be for power storage for the solar cell.
Online Bud
« Reply #2 on: April 25, 2018, 01:13:20 am »
I've seen iso 7816 cards that make sound, cards with Red 7-segment LED looking display, and cards with a fingerprint sensor  :-+
Offline Mr. Scram
  • Display aficionado
« Reply #3 on: April 25, 2018, 01:54:12 am »
It pains me to see it destroyed, but it was for the benefit of us all.
Online Rerouter
« Reply #4 on: April 25, 2018, 02:28:48 am »
So now the question falls to you dave, can you find glassless LCD's and build using reccessed capacitors to make a V2 of your prototype with a much tighter PCB sandwitch
On the topic of very thin boards, How would you describe to a PCB house to have a routed out area that does not cut through the entire board cross section, a dip or a void with the opposite surface left intact?
Offline Tek_TDS220
« Reply #5 on: April 25, 2018, 03:18:42 am »
Looks like a layer or two of prepreg to me, not flat-flex.  You can tell by cutting through the board.  You'll see fibers if it is prepreg.  A variety of prepregs are commonly available down to 60 um (with 106 glass).
Offline EEVblog
« Reply #6 on: April 25, 2018, 04:47:29 am »
Oh boy, don't me started...
Two ways:
1) Controlled depth route. Not very effective/useless on thin boards. But cheap'n'cheerful.
2) Tell them to route the pre-preg layers first before they glue them. This will incur extra cost, but it will give you a perfect recess. Easy if you are already doing a multi-board, especially with bling /burried vias. On a standard double sided board they'll have the make up the board thickness with multiple pre-pregs. Something easy would be say 0.8mm + 0.8mm with 0.8mm depth route.
Offline Fungus
« Reply #7 on: April 25, 2018, 04:59:54 am »
Regarding the buttons:
Wouldn't the resistance change with pressure even if the carbon pads were always touching? Maybe they work by looking for changes in resistance.
Edit: Now watch the prices of these skyrocket on eBay.
« Last Edit: April 25, 2018, 05:19:00 am by Fungus »
Offline gamalot
  • Correct my English
« Reply #8 on: April 25, 2018, 05:21:24 am »
I once had one Casio look like this when I was in high school in the late 80s.
Offline EEVblog
« Reply #9 on: April 25, 2018, 05:22:19 am »
I wouldn't want to engineer it like that. The spacing seems quite deliberate.
Offline Fungus
« Reply #10 on: April 25, 2018, 05:48:41 am »
You might not have a choice if the requirement is "0.8mm".
I don't see why it would be more difficult than the capacitive sensors on your watch.
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #11 on: April 25, 2018, 05:55:57 am »
Isn't it the time for engineering calculator shootout? I used to own a Casio (a silver one) which costs around 25$. I wonder what is the best these days for someone to buy, this could be a nice topic for a new video.
I think credit-card sized calculators are nice, but are they practical? I mean, do people really use them instead of real calcs?
Offline Fungus
« Reply #12 on: April 25, 2018, 06:06:23 am »
a) What do you define as "engineering"?
b) Isn't there an app for that?
c) It wouldn't be impartial, Dave is very brand-biased.  :popcorn:
GOTO 27m40s
I remember people using them back in the day. Mostly they were freebie/promo giveaways like the on in this video.
These days people use their smartphones.
« Last Edit: April 25, 2018, 06:09:14 am by Fungus »
Offline EEVblog
« Reply #13 on: April 25, 2018, 07:53:00 am »
Totally doable with separated distance in 0.8mm IMO.
Also, if all the keys touched all the time, that's a lot of extra current draw in idle, plus the requirement to measure it in a meaningful amount of time if it's high resistance.
Online TheSteve
  • GHz
« Reply #14 on: April 25, 2018, 08:29:26 am »
Not in the same ballpark thickness wise but probably inspired by the calculator.
The Motorola "Confidant" numeric credit card pager.
VE7FM
Online Rerouter
« Reply #15 on: April 25, 2018, 11:14:45 am »
Well to get you started, it appears there are single color, flexible reflective lcd's on alibaba that resemble the one shown in the video.
Find one in the right form factor, and you may be set for a very thin screen.
https://www.alibaba.com/product-detail/flexible-transparent-display-flexible-transparent-lcd_60667954126.html?spm=a2700.7724857.main07.141.26471f05NcMM24
Combine it with the printable solar panel flims like mikeselectricstuff reveiwed and you could just pull of a modern version.
Then using something like this for power (not insane power density, but for an LCD calculator, it should be low)
https://www.digikey.com/products/en/capacitors/electric-double-layer-capacitors-edlc-supercapacitors/61?k=&pkeyword=&pv1500=1231&FV=ffe0003d&quantity=0&ColumnSort=0&page=1&pageSize=25
Offline Skashkash
« Reply #16 on: April 25, 2018, 01:43:42 pm »
 Air pressure helps to provide a "spring" effect to keep the conductive carbon away from the pcb contacts.
  It's why you have that inner spacer layer with channels between buttons to equalize the pressure between the switch "cells" when you press a button.
Had similar (but much larger) keyboards on some equipment back in the 80's. If the plastic got punctured over one of the buttons, the top layer would actually deflate and we'd have to toss whole keyboard.
Offline blackjetrock
« Reply #17 on: April 25, 2018, 03:15:07 pm »
You can get at the die with a torch, no acid required:
Also, I have an Olympus like yours (I got it after I saw yours...) and I have a nice XY slide holder so you can move stuff around. Did yours not come with one? They are available on ebay quite cheaply.
Offline Fungus
« Reply #18 on: April 25, 2018, 04:01:24 pm »
Ok, I can't claim to be an expert there.
Not necessarily true if it's doing a matrix scan - not all the keys will be powered up all the time.
Plus: Does it matter in a solar powered device? So long as it works under normal conditions (single keypresses) then it's fine.
But, whatever. If you don't see any problems with tolerances for the keypads then we'll do it that way.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #19 on: April 25, 2018, 06:08:09 pm »
You gave me something to think about. I recall that if you pressed several keys on some old calculators the LCD would dim considerably - I never thought that power consumption could be a possible cause.
Dave, you rave about Casios and I grew up loving them as well, but in terms of durability they leave a lot to be desired. They seem to have embraced more than anyone the zeitgeist of disposable electronics of the 80's: I have several 1980 and 1990's calculators/scedulers/gizmos from them (including a "film card" SL760, several fx-39, among others) that have their crappy membrane keyboards partially or totally inoperative after 15, 20 years of age. Multiple HPs and TIs of the time are still running quite strong.
Offline Fungus
« Reply #20 on: April 25, 2018, 07:06:31 pm »
There was a time when they were really good. I remember my FX-180P fondly.
After that they went downhill IMHO, especially the keyboards.
I'm not a TI fan but HP made some good, solid, basic scientific calculators that have lasted. The calculators I use today are old HPs.
nb. I'm not a fan of graphing calculators in general, I only need a basic scientific model for what I do.
This thread is now doomed to turn into a flamewar.
« Last Edit: April 25, 2018, 07:23:41 pm by Fungus »
Offline rsjsouza
  • Eternally curious
« Reply #21 on: April 25, 2018, 07:49:38 pm »
My units are older than this and their keyboards started to fail some 10~15 years ago... :(
To me the TI calculators of the 70's-80s still have good working condition keyboards (TI-30, a couple of TI-59s, a TI-66). I also have a pair of HP11Cs and HP48S and GX (well into the 90's) which are still pretty solid.
:-DD :-DD :-DD
Offline Fungus
« Reply #22 on: April 25, 2018, 08:08:00 pm »
I'm not sure what happened to my FX180P. Lost in the mists of time somewhere.
I've got the obligatory HP11C but I really like my HP 20S. It's not a famous model but it has all the right functions and layout for me. It does hex/dec/bin conversions with very little fuss. I don't know any other calculator which does those without half a dozen keypresses or you have to go into a special mode first.
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #23 on: April 25, 2018, 10:47:03 pm »
Thats a thin as calculator right there. I just skipped a bit when Dave destroyed it   ::).
I also have something similar...its an "IMA" branded calculator, Model No. LC-684. Maybe late 1980's to 1990's era. It is also solar powered but its like 2mm thick so I think it still doesn't beat Daves one. ;D
Don't mess with an Electronics Engineer, it Megahertz!
Offline chickenHeadKnob
  • doofus programus semi-retiredae
« Reply #24 on: April 26, 2018, 01:21:03 am »
Sharp EL-540d vintage approximately 1984, does conversions with 2 key presses. First press yellow shift key then select desired (->bin) (->hex) ect. Also has (AND) (OR) (NOT) (XOR) (XNOR). Not RPN or graphing or programmable but good and under appreciated. Last calculator I ever bought. I started out as  a calculator nerd teenager/young adult and then the urges slowly left me for good.
Here is a pic:https://www.ebay.com/itm/MINT-RARE-Sharp-EL-540D-Solar-Power-Scientific-Calculator-MANUAL-EL540-/162937868447
