Hi group,
I see a lot of people have winding their own NVTs. I want to share an alternative approach.
You simply buy the B82720H0015A035 EPCOS (TDK) from Digikey. They cost $2.66 USD or $3.66 CDN.
This part is quite small:
Here is the spec:
The magnetizing inductance is 68mH, not as high as the NVTs, but still quite high. The leakage (stray) inductance is 1200nH.
In a 50
test circuit:
The modelling results show a 3dB bandwidth from 60Hz to 13 MHz.
The model does not include any capacitance.
Measured results:
The low frequency 3dB point is 50 Hz
The high frequency 3dB point is 4MHz.
The transformer does not have to be flat in the normal control loop measuring scheme.
This common mode choke, used as a transformer, is suitable for most power supply control loop analysis.
Regards,
Jay_Diddy_B
