Author Topic: EEVblog #1105 - Custom LCD Design - Part 3  (Read 14319 times)
Offline EEVblogTopic starter
« on: July 16, 2018, 11:40:54 pm »
The $100 low cost custom LCD finally arrives!
Will it work as intended?
The following users thanked this post: SeanB, MT
Offline Muttley Snickers
  • Cursed: 679 times
Re: EEVblog #1105 - Custom LCD Design - Part 3
« Reply #1 on: July 17, 2018, 12:19:05 am »
Interestingly all of the segments on the four digits directly below for the current display appeared rock solid in comparison, the only difference between the two was that you had the CV icon activated the entire time on the voltage display.
« Reply #2 on: July 17, 2018, 02:35:53 am »
Yeah, when you get marginal drive voltage like this on complex multiplex displays, they aren't exactly consistent.
Offline Bud
« Reply #3 on: July 17, 2018, 03:46:23 am »
Nice looking display after the voltage mod! Perhaps you could play with backlight to get a feeling how it may look with bbacklight on in the final product.
Offline SilverSolder
« Reply #4 on: July 17, 2018, 04:03:33 am »
Looks awesome - very interesting what is possible these days!
What kind of price range would one expect for higher quantities of this kind of thing?
Offline mk8038
« Reply #5 on: July 17, 2018, 06:48:26 am »
Mr. Jones
Please note, the LCD bias generator of HOLTEK's device is supplied from a dedicated pin VLCD.
I would suggest to slightly increase this voltage while maintaining VDD at its nominal.
Please observe data sheet block diagram and application circuits
Offline FrankBuss
    • Frank Buss
« Reply #6 on: July 17, 2018, 08:44:14 am »
In case someone was confused like me that 6 o'clock is not 180°, this is the description:
http://www.hantronix.com/files/down/v-angle.pdf
It also explains that changing the voltage can improve 6 o'clock viewing for 12 o'clock displays and vice versa, but it reduces quality for the indented viewing direction at bit. I guess it is a good idea to use a digital pot, and allow even the user to change it.
The following users thanked this post: bitwelder
« Reply #7 on: July 17, 2018, 10:33:27 am »
Mr. Jones
You can't (or shouldn't) increase  VLCD above VDD.
Offline radit68i
  • Country: bg
« Reply #8 on: July 17, 2018, 04:32:46 pm »
name of manufacturer, website?
Offline ckambiselis
« Reply #9 on: July 17, 2018, 07:19:17 pm »
Dave do you have another test bed, just in case the problem is on the testing kit?
Offline WN1X
« Reply #10 on: July 17, 2018, 08:43:37 pm »
Dave,
I assume you have tested all of the prototype displays to see if they exhibit the same problem?
- Jim
Offline mk8038
« Reply #11 on: July 17, 2018, 09:26:48 pm »
My bad.
There is an appropriate note in data sheet I missed.
Offline richnormand
« Reply #12 on: July 17, 2018, 09:29:08 pm »
I remember seeing a similar issue years ago with nematic custom LCDs.
The issue was variable between panels to non existent on some.
I also remember that it was non-linearly temperature dependent. So the panels behaved differently in a colder room. You might want to look at that.
A partial solution was found by using a different formulation of liquid crystal in the assembly.
It will be nice if the company gives you permission to identify them.
Nice video  :)
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline siealex
  • Country: ua
« Reply #13 on: July 17, 2018, 10:27:56 pm »
Is it possible to order an exact copy of an old clock LCD? Of course, with given pinout and segment map, but not necessary with exact copying the shape of segments.
« Reply #14 on: July 18, 2018, 12:07:24 am »
Sure, they will make anything you want.
But if you just want one they will charge you a lot.
« Reply #15 on: July 18, 2018, 12:08:07 am »
Yes, all basically the same.
« Reply #16 on: July 18, 2018, 12:09:40 am »
Not yet. But it's very unlikely to be the hardware.
Of course it could be the HT1622 chips drive capability or some such, and it may very well be different with a different LCD controller, but that's beside the point.
Offline Andrew McNamara
« Reply #17 on: July 18, 2018, 12:45:08 am »
Given how well that single digit test worked with the common open-circuit...  :P
The following users thanked this post: JJalling
Offline Mr. Scram
  • Display aficionado
« Reply #18 on: July 19, 2018, 07:07:00 am »
Ever since the last episode I've been wondering whether this is a loss leader for them. Dave weighs in on the matter in the video and considering the not very impressive costs of it all I tend to agree with him. More to the point I've been wondering whether I could buy custom LCDs from someone without lying to them about potential future orders. It'd be awesome to be able to buy LCDs like you can buy PCBs right now. I think they could double the cost and it'd still be interesting, though I have no way to judge whether that would make sense to them.
I think that any company specifically advertising with this ability might enjoy a lot of interest. It'd not be PCB cheap, but I think many people will consider $100 to $250 acceptable for custom LCDs. I don't think anyone is actually doing this at the moment, right?
Offline boffin
« Reply #19 on: July 19, 2018, 07:27:29 am »
My question on all of these custom LCDs is why does everyone use such small decimal points?  With big zeros, it's often easy to lose the decimal place.
Offline Maveltjes
Improved design (i hope)
« Reply #20 on: July 21, 2018, 09:55:22 pm »
I took the liberty to improve the display design.. It's a hobby of mine that I picked up recently.
I hope I don't stab the original designer in the back, and as well hope that Dave sees this.
Too late of course, but perhaps I could help with a future project. (I am not very technical, I just like old school LCD's....)
There are several subtle improvements, but the most obvious are the 'Casio style' digits, and the bigger decimal points.
And note the cute battery indicator ;)
It should be completely compatible with the existing design (other than re-drawing all connections etc.)
I can't attach the Illustator *.ai file but could send it when requested.
The following users thanked this post: thm_w, vinicius.jlantunes
Offline boffin
Re: Improved design (i hope)
« Reply #21 on: July 22, 2018, 01:48:47 am »
Love the bigger decimal places.
Offline ivanjh
« Reply #22 on: July 23, 2018, 02:14:31 am »
I see the datasheet says "The voltage applied to VLCD pin must be lower than VDD." It doesn't say why, or how much lower.
Their own example has a 1V drop: "Adjust VR to fit LCD display, at VDD=5V, VLCD=4V, VR=15k+/-20%."
The LCD common/segment sink test conditions on the D.C. Characteristics all seem to have 0.3/0.5V for VOL (output low) (I'm not sure if that was measured during testing, or to be expected).
Is the HT1622 capable of "full rail-to-rail" output? Does 3.3V VDD & 3.3V VLCD provide +/-3.3V at the LCD? Or is there some drop/head room required between VDD & VLCD?
Offline bitwelder
« Reply #23 on: July 23, 2018, 09:35:34 am »
Reading the 'Casio style' expression made me think: generally speaking, is there any copyright on the LCD outlook, the way there is e.g. for certain typographic fonts?
Offline Maveltjes
« Reply #24 on: July 23, 2018, 11:17:43 am »
For using fonts for static items (like AC, min, max in this case) there is no problem as long as you know the font(s) are licensed for any purpose.
The 7 segment LCD was invented very long ago, the very first design was actually an 8 segment.
My segment design here has rounded edges and separation angles similar to many Casio devices, but is not literally a copy. This is a quite common 7 segment design also used by other brands.
« Last Edit: July 23, 2018, 11:20:03 am by Maveltjes »
