Author Topic: EEVblog #1109 - Spectrum Analyser Design Walk-through  (Read 3810 times)
Online EEVblogTopic starter
« on: July 23, 2018, 11:15:25 pm »
A step-by-step walk-though of a typical modern low cost 3GHz "All Digital IF" spectrum Analyser design.
Offline JS
  • Country: ar
Re: EEVblog #1109 - Spectrum Analyser Design Walk-through
« Reply #1 on: July 24, 2018, 03:05:11 am »
At the end you mentioned nyquist, but as its already a band pass filter could very well be doing oversampling, and rhe IF being centered at 30MHz or 50MHz makes a ton of sense, as it could be at 10MHz and nyquist it is.. Checking the ADC datasheet should tell how high oversampling can go, usually limited by the sampling time but also the use of decimation and anti aliasing filters.
JS
If I don't know how it works, I prefer not to turn it on.
