Author Topic: EEVblog #1114 - NEW TS80 USB Soldering Iron Review  (Read 22575 times)
pjhomchick and 1 Guest are viewing this topic.
Offline joric
Re: EEVblog #1114 - NEW TS80 USB Soldering Iron Review
« Reply #50 on: February 16, 2019, 10:25:01 am »
can confirm now using a usb c to usb a adapter on the power supply, and using a usb a to usb c cable, the iron turns on and works at full power with qc3.0 support
I don't get what's the point? Basically all A-C cables are QC, all C-C cables are PD. You've used C-A adapter + A-C cable? Which power source? Which adapter? Does it just dumb down Type-C to 4 wires electrically without logic conversion?
« Last Edit: February 16, 2019, 10:38:20 am by joric »
Offline joric
« Reply #51 on: February 16, 2019, 10:28:33 am »
the xiaomi works with multiple phones that support qc3.0/2.0 In theory it should work with the ts80 too.
I have exactly that Xiaomi PD power unit and it's stock C-C cable and it DOES NOT WORK with TS80, the latter doesn't even turn on.
Xiaomi laptop and Xiaomi phones work though (they even report the quick charging mode somehow, I though it's just PD mode supported by those phones).
This is weird, article lists USB PD 2.0 and QC3.0/2.0 support simultaneously (isn't it supposed to be called QC4?) for the Xiaomi power source but I swear to god, phones work, TS80 DOES NOT. I don't know maybe it needs C-A "adapter" but hell knows which type of "adapter" your're using, there are a lot of those including full blown PD to QC power converters.
« Last Edit: February 16, 2019, 10:45:30 am by joric »
Offline oh2hyt
  • I lurk mainly
« Reply #52 on: February 18, 2019, 09:54:06 am »
You can try hack: Add 5.1kohm pulldown resistor between each CC-pin and signal ground in TS80, this should make C-C cable (which follows spec) and C-psu (whic follows spec, but has also QC 2.0 / 3.0) to work. I have not tested.
Edit 2019-02-19: Clarification: Two 5.1kohm resistors, one from CC1-pin to ground and one from CC2-pin to ground. If it didn't come clear from above. And do not connect CC-pins directly to each other. This is a device so it needs resistor from both CC-pins as C-C cable has only one of CC-pins connected between cable ends.
Simplified:
Charger or anything having female USB type-C connector is not allowed to supply voltage on Vusb pins before connecting pulldown resistor(s) to CC-pin(s). C-A (and C-B) cables and adapters have a resistor (only one CC pin, value 5.1kohm pulldown or 56kohm pullup) telling if their type-C male connector of cable/adapter is power sink or source. type-C charger/psu detects this resistor and if there is power sink connected, then starts to supply voltage to Vusb.
(I skipped PD communication via CC-pins, b/c it is not relevant with TS80 or when there is type A or type B connector in game)
There was/is a lot of adapters/cables with wrong resistor or it connected wrongly. These can damage your devices!
« Last Edit: February 19, 2019, 12:32:52 pm by oh2hyt »
Offline joric
« Reply #53 on: February 18, 2019, 10:37:25 pm »
I think it's possible to solder that resistor inside TS80, it's 12-pin Type-C connector definitely has those CC pins. Not sure it will work though I afraid to kill it maybe someone else tries.
Those CC pins are probably not even soldered because TS80 DOES NOT and WILL NOT (according to manufacturer) EVER support PD negotiation and PD power source.
« Last Edit: February 18, 2019, 10:43:50 pm by joric »
Offline salavat
  • Country: ru
« Reply #54 on: March 14, 2019, 09:42:51 am »
I need some help - my TS80 shows 130-140 C lower temperature, than actual one. I read all the debug menu values, all seems OK, checked D25 tip (4.45 Ohm, seems to be in range), done reset and calibration few times already, changed firmwares. etc.
Looks like it is a hardware problem, temp sensor chip probably. I can do reflow of the board (also probably I can request change for iron from the seller), but:
- I do not know whether chips are sensitive on temperature (afraid to burn out)
- which one to reflow
- whether it could be possible to return TS80 after that and whether it will fix the issue.
Any advice?)))
Offline S53SG
  • Country: si
« Reply #55 on: July 04, 2019, 08:26:27 pm »
I am looking for cable only, which comes with "pro" package. It's really good cable, so I would like to use it in other projects... does anybody know any part number of similar cable?
Offline oh2hyt
  • I lurk mainly
« Reply #56 on: July 14, 2019, 06:39:07 am »
I'm interested too. Even the cable is not so good: resistance is high and conectors' shields aren't connected together  :--. Well, it's partially so flexible because no shielding (or so I assume - I haven't cut one to see inside).
I have seen Banggood selling the cable + the charger combination.
Offline joric
« Reply #57 on: December 31, 2019, 06:19:46 am »
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #58 on: December 31, 2019, 08:42:09 am »
I just joined the TS80 cult lately, and I have to say, besides being a cute little pocket iron, it's really not a particularly good one.
I have mine set to 24W, and it indeed draws more than 22W when heater is on, but it's not very powerful at all.
For desoldering the same pads, it constantly behaves worse than my 14W JBC Nano, and the Nano was undervolted (it's a 120V model, which I fed 110V to it).
Offline screwbreaker
« Reply #59 on: January 03, 2020, 08:06:13 pm »
... it constantly behaves worse than my 14W JBC Nano ...
Yes, but is portable. You don't have to compare it with a soldering station. It is not a replacement.
But, as a portable soldering iron, it perform very well.
Offline salavat
  • Country: ru
« Reply #60 on: January 16, 2020, 12:04:20 am »
What kind of tip do you use?
PS - does it really gets to 12V on TS80?
Have you tried custom firmware (aka Ralim at github)?
Except for high termal tip on my JBC T245 powered by "true" 130 watts (transformer at 24V and current limit of 6A in firmware) by Unisolder, peformance of TS80 is not too far away from T245.
The following users thanked this post: blueskull
Offline blueskull
  • Country: cn
« Reply #61 on: January 16, 2020, 03:02:39 am »
I was using a 9V power bank, it actually outputs ~10V at 22W (measured using a USB power meter).
I was using off the shelf FW, and I should upgrade it to a more aggressive custom FW.
I'll report back.
Offline blueskull
  • Country: cn
« Reply #62 on: January 16, 2020, 03:29:23 am »
Wow, at 12V it became much more powerful. I just tried it on a copper substrate board, and it worked!
