Author Topic: EEVblog #1125 - Amazing $500 Soldering/Inspection Microscope!  (Read 107515 times)
0 Members and 14 Guests are viewing this topic.
Offline charliex
  • Car Hacker
Re: EEVblog #1125 - Amazing $500 Soldering/Inspection Microscope!
« Reply #150 on: January 12, 2020, 02:34:30 am »
did not realise there was a hacking going on in here too, my contribution then  https://www.eevblog.com/forum/reviews/eakins-auto-focus-microscope-camera/
« Last Edit: January 12, 2020, 05:47:07 am by charliex »
Offline Southerner
Offline texaspyro
« Reply #152 on: January 12, 2020, 04:08:34 am »
link gives 404 - not found error
Offline charliex
  • Car Hacker
« Reply #153 on: January 12, 2020, 05:46:51 am »
Offline charliex
  • Car Hacker
« Reply #154 on: January 14, 2020, 05:35:33 am »
i built a .ko for my RTL8152 based usb to ethernet adapter and was able to put the camera directly on the network, added the .ko to my github
still adding notes here
https://charliex2.wordpress.com/2020/01/14/eakins-camera-hackery-pokery-and-the-legend-of-measuretwice/
so now i can just write the IPC commands directly over tcp/ip to a port rather than issuing commands over the serial port terminal, there's also a network streamer available for this chipset/camera
Offline nigelwright7557
    • Electronic controls
« Reply #155 on: January 14, 2020, 05:41:30 am »
For those trawling ebay the magic search terms seem to be "hdmi microscope imx290", I got mine for ~US$520 including Australian GST, with the 180x lens and a ring light.
I just use 2.5 reading glasses and x20 magnifier for SMD work and they cost me $10.
Offline Southerner
« Reply #156 on: January 14, 2020, 05:49:44 am »
That is pretty much what I linked:
https://www.qsl.net/k9ac/solderScope
It uses a cheap ($30 usd or so) magnifying visor like dentists use (but cheap) that has a 420mm focal length then the linked article ( https://www.qsl.net/k9ac/solderScope ) made a cardboard tube (or old 35mm film canister) as a tube that has the lens (cut to match your cardboard or film tube) from a 2x or 2.5x cheater glass.  Because it has a 420mm focal length they are easier to use than my  Nikon SMZ645 microscope that has to be too close to the business end of my soldering iron for my comfort!
Offline MR
  • Country: tw
« Reply #157 on: August 31, 2021, 11:40:40 am »
My Eakins microscope broke 2 times - first they have replaced the PCB for free - second time we had a closer look ourself. The memory chip wasn't soldered properly (so watch out if you get or start to get glitches on the hdmi screen).
The first PCB shows up the same symptoms, I also tried to resolder some chips but didn't touch the BGA memory chip back then... so this might be a common issue.
Now I have a question about the power consumption, my microscope needs around ~5W can anyone confirm that? (no USB or SD Card attached).
« Last Edit: August 31, 2021, 11:49:48 am by MR »
Offline pitfermi
« Reply #158 on: December 07, 2021, 07:31:09 am »
i read this camera uses a rolling shutter. how good is it when moving around objects? are the objects deformed or bent noticeably? can someone provide a video sample demonstration? thanks
Offline MR
  • Country: tw
« Reply #159 on: February 04, 2022, 07:48:24 am »
You wouldn't notice it's rolling shutter (at least I did not).
« Reply #160 on: June 03, 2022, 01:27:10 am »
You can pay all sorts of silly money SMD kit.
I use £15 soldering iron, £20 hot air gun and £1.50 2.5 reading glasses, £3 tweezers and a £2 magnifying glass.
Strange thing is I have few problems with that kit.
Offline Southerner
« Reply #161 on: June 03, 2022, 04:03:41 am »
Nigel is correct. You can pay silly money for smd tools and equipment...or you can go cheap.  A Hakko 858D clone hot air station is about $40usd and up to about $60usd.  With that and a magnifier you can do what you need to do.  I use a 2" UltraOptix 7x lit magnifier to check the work.  It helps if you can get a solder mask template (stencil) for your board. That makes applying solder paste a snap.  Then place all the parts. They do not have to be exactly aligned and hot air will mostly pull them into place.  You can go cheap on the hot air gun too as a stamp embossing gun that sells for about $10usd at places like Hobby Lobby will work too.  The 858D allows setting the desired temperature though.  Just be sure to make sure the air output is not set too high or the smd parts will go into outer orbit never to be seen again.  Places like Harbor Freight sell a "jewler's loupe" set for about $5 usd.  I use the 10X from that set.  I do also have the cheap dental student magnifiers that have the 420mm focal length and they work well and are about $30usd.  So you can spend lots of money or a small amount.
Good luck.
Offline rthorntn
« Reply #162 on: June 05, 2023, 01:27:14 am »
Sorry for the thread necro.
I just have this bare camera for use in my stereo microscope eyepiece socket but I would rather use it standalone, so the question, which stand and lens should I pick up for this, to use as a soldering inspection scope?
Thanks.
Offline thm_w
  • Non-expert
« Reply #163 on: June 05, 2023, 10:05:58 pm »
Thanks.
If you read the thread you can find lots of lens suggestions. Around 120x seems to be common. Although if you go with the very cheapest 120x lens it does not have a zoom adjustment, you have to manually move the camera up and down to zoom.
For a stand I used a microphone boom arm stand w/ 1/4" mount. Pro is that its very easy to move around and reposition, but, it can shake if you don't have it solidly mounted or buy a cheap one.
The following users thanked this post: rthorntn
Offline rthorntn
« Reply #164 on: July 06, 2025, 02:16:36 am »
Apologies again for the thread necro, even though this thread is old its probably still the best one out there.
Is anyone using this with something like a Raspberry Pi to command it to take a bunch of photos at different focus points and then have them automatically stacked and the image perhaps dropped on a file share?
Thanks.
Richard
Offline img999
« Reply #165 on: October 12, 2025, 07:07:44 pm »
I've finally had the time to probe around J50.
Hi Finbarry!
Can you upload the dump of the Macronix 25L25645G, if I ask you nicely? :)
I have the same hardware (HI3516A + IMX290 with 2 USB ports, but no TF slot), without the autofocus feature. The camera worked flawlessly for 5 years and yesterday it started resetting (?) the HDMI connection continuously. The monitor detects the camera on the input, but immediately goes into power saving mode because the camera resets (?) the connection or other anomaly happens. Then the monitor wakes up and detects the camera again, but that immediately goes into power save mode (again) and the circle restarts.
I reflowed the camera's PCB with hot air, resoldered the HDMI port, tested with multiple cables and multiple monitors, all with the same outcoming (no dice).
The 32.768 kHz crystal and the 24 MHz oscillator works as expected.
There was a 3V RTC button battery on the PCB but it depleted to 2.6V so I removed that, it has no effect on the issue. I soldered a CR2032 to the PCB but also no improvement.
There are 4 resistors connected the HDMI connector: 2x 2.7 kOhm (R7 &R8) pull up on pin 15 & 16 (SCL & SDA), and what is suspicious for me is 36.5 Ohm (R13) on pin 18 (+5V) because it is a bit high for 33 Ohm. And also there is 47 kOhm pull down resistor (R6) on pin 19 (Hot Plug Detect, it goes directly to the SII9022A pin 54) but if I measure it with reversed polarity it is just 13,5 kOhm (interesting). Can you measure your corresponding values?
I need your dump because I want to sort out the possible firmware issue before replacing the SII9022A and the Hi3516A.
I guess the FIFO error not full messages does not effect the working state of the camera because I seen on the internet that the same error messages appeared in the logs of perfectly working cameras too. Is your camera was connected to the monitor wen you logged it?
My camera's log:
U-Boot 2010.06 (Nov 25 2020 - 11:31:36)
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC2 0x20 0x19 0xC2 0x20 0x19
Spi(cs1): Block:64KB Chip:32MB Name:"MX25L(256/257)35(E/F)"
Check Nand Flash Controller v610 ... found
Special NAND id table Version 1.36
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
32768 KiB hi_sfc at 0:0 is now current device
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.4.35
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2986672 Bytes = 2.8 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.4.35 (root@linux-5w9i) (gcc version 4.8.3 20131202 (prerelease)
(Hisilicon_v300) ) #2 Fri Jan 13 17:00:54 CST 2017
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3516a
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: mem=128M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfst
ype=jffs2 mtdparts=hi_sfc:1M(boot),3M(kernel),28M(rootfs)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 124028k/124028k available, 7044k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc054a000   (5384 kB)
      .init : 0xc054a000 - 0xc056c434   ( 138 kB)
      .data : 0xc056e000 - 0xc059d800   ( 190 kB)
       .bss : 0xc059d824 - 0xc05bc9f8   ( 125 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128
sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms
Console: colour dummy device 80x30
Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x8041e4a8 - 0x8041e500
dummy:
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
hi-spi-master hi-spi-master.0: with 1 chip select slaves attached
hi-spi-master hi-spi-master.1: with 3 chip select slaves attached
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource timer0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.18)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 242
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
Spi id table Version 1.22
SPI nor flash boot mode is 3 Bytes
Spi(cs1):
Block:64KB
Chip:32MB
spi size: 32MB
chip num: 1
3 cmdlinepart partitions found on MTD device hi_sfc
Creating 3 MTD partitions on "hi_sfc":
0x000000000000-0x000000100000 : "boot"
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000002000000 : "rootfs"
Found Nand Flash Controller V610.
Higmac dma_sg_phy: 0x87a00000
higmac_mdio_bus: probed
PHY mdio0:01 not found
ETH0: rgmii, phy_addr=1, mii_name=mdio0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed!
hisi_i2c hisi_i2c.1: Hisilicon [i2c-1] probed!
hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed!
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
usb 1-1: new high-speed USB device number 2 using hiusb-ehci
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 136K
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Not recognise ACTION:change
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S90hibernate
Password for 'root' changed
Auto login as root ...
Jan  1 00:00:03 login[888]: root login on 'ttyS000'
Welcome to HiLinux.
His3516a_LoadDrivers Start.....!
None of nfsroot found in cmdline.
~ # Hisilicon Media Memory Zone Manager
Module himedia: init ok
hi3516a_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
load sys.ko for Hi3516A...OK!
load tde.ko ...OK!
load region.ko ....OK!
load vgs.ko for Hi3516A...OK!
ISP Mod init!
load viu.ko for Hi3516A...OK!
load vpss.ko ....OK!
load vou.ko ....OK!
load hifb.ko OK!
load rc.ko for Hi3516A...OK!
load venc.ko for Hi3516A...OK!
load chnl.ko for Hi3516A...OK!
load h264e.ko for Hi3516A...OK!
load h265e.ko for Hi3516A...OK!
load jpege.ko for Hi3516A...OK!
load vda.ko ....OK!
load ive.ko for Hi3516A...OK!
hi3516a_io driver init start
hi3516a_io driver init successful!
insmod /komod/io_f10x.ko
insmod: can't insert '/komod/extdrv/wdt.ko': No such file or directory
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x200f0050: 0x00000000 --> 0x00000001
[END]
0x200f0054: 0x00000000 --> 0x00000001
[END]
0x200f0058: 0x00000000 --> 0x00000001
[END]
0x200f005c: 0x00000000 --> 0x00000001
[END]
0x2003002c: 0x00090007 --> 0x00090007
[END]
mipi_init
init phy power successful!
load hi_mipi driver successful!
0x200F00B8: 0x00000001 --> 0x00000000
[END]
0x200F00F0: 0x00000001 --> 0x00000000
[END]
His3516a_LoadDrivers Finish.....!
***COPYRIGHT 2016 tagye technology****
software:v2.4.2
DATE:Sep  2 2020,TIME:12:47:50
linear mode
--IMX290 1080P 60fps LINE Init OK!----
Entering the cmos_fps_set!
HI_MPI_VPSS_GetChnNR----------nr:1
vout start finish
card disconnected!
 read first 128 bytes of EDID ROM
hi_i2c_wait_txfifo_notfull->260:
transmit error, int_raw_status: 0x750!
hi_i2c_wait_txfifo_notfull->262:
tx_abrt_cause is 1.
open success:fd0 ===== 3
FBIOPUT_VSCREENINFO over !!!
tx_abrt_cause is 1.
Initializing QFontEngineQPF failed for /qt_lib/fonts/DroidSansFallback.ttf
initLineSetting
accept client1 connect request
The log stops at this point with no further information or error code, just the monitor's restart circle repeats itself. If I disconnect the monitor nothing happens on the camera's side just the monitor stays in power saving mode, if I reconnect them the camera logs:
tx_abrt_cause is 1.
tx_abrt_cause is 1.
And the monitor jumps into the on/off circle again.
The photo is not mine but the same PCB (except the fact that is with with autofocus components populated).
Update, 2 days later: I found that the camera is working with only one old Samsung TV (UE40D5500, 1080p), but with the previously tested 1080 x 1200 monitors it is still not working.
Update: finally the case solved. I bought a Dell U2312 which is native 1080p (not 1200p like the U2709 models what I previously used for the camera). Although I also bought the components (HI3516A RBC V100 and SII9022ACNU) for the camera, but finally I didn't replaced them because the monitor change resolved the problem and in addition the camera's on screen menu also works better (it wasn't displayed correctly before because it is shown only in halfway on the U2709's 16:10 screen). Overall, changing the monitor instead of repairing the camera itself was a better idea for this (way better) outcoming.
« Last Edit: October 22, 2025, 07:39:03 pm by img999 »
