Author Topic: EEVblog #1129 - Creating a Nice Readable Schematic  (Read 22045 times)
Offline rrinker
Re: EEVblog #1129 - Creating a Nice Readable Schematic
« Reply #50 on: October 10, 2018, 02:17:38 pm »
 Video length when actually teaching something doesn't bother me. I just watched it over 2 sessions.
While I have 0 industry experience, I can't imagine making a schematic as horrible as that. I've torn up and redrawn DaveCad-style schematics because I drew myself into a corner and would have had to draw lines all over the place to connect things. here's just no excuse when using a computer program, it's too easy to align things, rotate them to face the same way. etc without needing to completely start over. That's just lazy, not incompetence. I do a lot of network and system diagramming with Visio for my job, and I'm just OCD enough that everything HAS to line up horizontally and vertically or else it just doesn't look right. No weird steps in lines connecting things. I may not draw the most professional schematics for my projects, but my resistors all line up, the wires all come out straight and don't cross through components, and the grounds all face down so the electrons drain properly.
Offline Sudo_apt-get_install_yum
« Reply #51 on: October 16, 2018, 08:38:52 am »
Nice and long video Dave!
Does anybody know how to add "grouping frames" to your schematic in eagle? I know Dave is using Altium but I’m wondering if there is a way to do the same in Eagle.
Currently I just stick a frame around everything and use different sheets if it’s a more complex design, but I think it would be nice if I have a small design that I just want to group together in "modules".
PS: I know Eagle has a new modules function but that not really what I’m looking for.
Online Smokey
  • Not An Expert
« Reply #52 on: October 18, 2018, 09:20:38 am »
I always make the footprint/symbol name visible, especially for passives.  If you make the name short and put the package size in the name (ie. R0402 for an 0402 resistor) then it's not much extra clutter and it's super useful for confirming the correct package is used when doing a schematic review.
The following users thanked this post: nctnico
Offline artag
« Reply #53 on: November 04, 2018, 01:45:57 pm »
The thing I hate most is when people just plop down all the symbols, with net names but no interconnect wires at all & call it a schematic.
THIS, in buckets !
I guess it's easy to follow the signals if you're in the schematic editor. But if you don't use that same editor and are using a printout or electronic copy, it's utterly useless, especially if you use multiple pages. You can never find where the signal goes and, worst of all, if you find the matching name, you have no idea if it goes more than one place. DON'T EVER DO THIS !
Seems like some people aren't trying to draw a schematic. They're just using the schematic editor to create a net list.
Well, why bother with the picture ? Just enter the net list as text and save a whole lot of effort.
And don't imagine you're created a useful schematic :)
Offline artag
« Reply #54 on: November 04, 2018, 01:50:39 pm »
@Cerebus
Good point. But while the diff pair is easily recognisable and what I'd tend to use, I really like that alternative you've shown. So much neater without the wire that turns around and goes backwards. I wish that the second form were common enough that it was also instantly recognisable as a standard circuit.
Online Smokey
  • Not An Expert
« Reply #55 on: November 04, 2018, 08:22:12 pm »
THIS, in buckets !
...You can never find where the signal goes and, worst of all, if you find the matching name, you have no idea if it goes more than one place....
This is why, in my opinion, Altium Ports are superior to Nets.  You can turn on that feature for Ports that shows what pages they are used on.  It shows up right next to the port like "2,4,5".
Offline Clear as mud
    • Pax Electronics
« Reply #56 on: November 06, 2018, 03:16:43 am »
Someone asked for a link to the technical standards for reference designators and electronic component symbols.  IEEE-315 is one of them.  Also see the references at the end of the Wikipedia article Reference designator.
Someone else mentioned that the standards can be expensive for a hobbyist.  I found that there wasn't much need for the actual entire standards book.  The more common designators are easy to remember, and whenever I'm working with some weird component and I don't know what letter to use for a reference designator, I can just do a web search and usually find some comment or document that tells what the standard designator is.
Offline jfitter
« Reply #57 on: March 19, 2019, 07:46:29 am »
Re the nano wars. This is just my 2c worth, but I have a corporate standard and it is important to pick a standard and stay with it.
1. I never use units. A capacitor is in Farads, so why clutter up the schematic with the unit; resistors are in Ohms, etc.
2. Multipliers replace decimal points, always.
3. Trailing zeros are unnecessary.
4. I never use lower case except for comments.
Examples;
Resistors 100R, 1R5, 10K, 1M, 1M5, 0R002
Capacitors 10P, 100N, 100U, 6U8, 2U2, 3N3, 1N
Inductors 100U
This keeps the drawing clear, legible, and resistant to duplication noise.
Of course there are exceptions which can be dreamed up. If you must use M for milliFarads, which I hate, how do you differentiate it from mega. You do it with common sense. If it's a capacitor and your circuit is smaller than a dumpster then it is not megaFarads.
Offline eti
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« Reply #58 on: December 04, 2021, 06:59:56 am »
Well the designer is certainly a "maker" - he made a real pig's ear of that.
Offline Jester
« Reply #59 on: December 04, 2021, 02:42:42 pm »
I have “cleaned up” far too many schematics that started out as indecipherable 10 or more pages to just a few pages or even just one large page. The ability to tweak the pin arrangement in Altium easily and have numerous variations of the same component really helps. Yes it takes time up front but the payoff is well worth it in the long run especially if others less familiar with the circuit will rely on it for troubleshooting etc.
I also find comments and expected waveforms at critical test points helpful.
I prefer to have a well organized and commented (even if congested) single page schematic than having to bounce from page to page to page.
For the last 10 years or so I have been relying on different Color’s for digital IC’s (yellow) vs. analog (blue), a specific Color for voltage regulators etc. it helps “paint the picture” of the circuit at a glance when you go back years later. Yes I have a shade of OCD.
My 2c
« Last Edit: December 04, 2021, 11:06:05 pm by Jester »
