Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 642654 times)
Offline alvieboy
  • Country: pt
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #825 on: January 22, 2020, 03:14:49 pm »
Hi all,
I am working on a interrupt-based, timing sensitive project to be implemented on a PFS154 controller. For this project I needed very fast interrupt response, and I needed to evaluate if the interrupt processing, which include pin sampling, could sustain the expected interrupt rate.
This was not easy to test using software, so I wrote a VHDL simulation model for PDK14 (PFS154).  The model should work with any HDL VHDL simulation engine, such as GHDL or Modelsim.
Not every PDK14 opcodes are implemented as of now, but should be fairly easy to implement the missing ones. I have also a PDK15 implementation but it's currently lagging behind.
The simulation model includes GPIO, basic T16 support, Timer2 and Timer3, and PWMG0. It should support all the clock sources for sysclk and for the timers.
You can find the VHDL model here:
https://github.com/free-pdk/fppa-pdk-emulator-vhdl
There is a basic example inside "examples/test" you can run. See the README file inside that folder for details.
I sincerly hope this can be useful to anyone as it is for me. Let me know if you find any issues, or have any feature request.
Best,
Alvaro Lopes
The following users thanked this post: EEVblog, I wanted a rude username
Offline tim_
« Reply #826 on: January 22, 2020, 06:17:18 pm »
I saw it today. Looks like massive work! Is it synthesizable? This could be the foundation for an open-source in-circuit emulator based on any cheap FPGA board. It would ease development for the OTP variants a lot.
I wonder, what is so peculiar about the PFS154 interrupts? Since every instruction is executed in one or two cycles, the interrupts should be fairly quick and with low jitter?
Offline alvieboy
  • Country: pt
« Reply #827 on: January 22, 2020, 08:40:18 pm »
As of now, it is not synthesizable. Mainly because there are a few open questions regading the microcontroller implementation (see the toplevel README, I have a few questions there that need to be answered).
They are quick... but it's hard to understand if you can keep up the pace when the interrupt sources come at only a few microsseconds apart. Simulating this at a lower level allows you to test several scenarios and evaluate whether your design will work or not. What I can tell you is, my first version which was implemented in "C" and built with SDCC was *not* able to keep pace. I found this during simulation, and simulation helped me optimize the (now in assembly) code.
There is something peculiar about how SDCC generates the interrupt handler, though. I ended up with the following sequence which was non-optimal (in addition to the goto statement due to memory location, I presume)
pushaf
mov a, p
pushaf
// Interrupt code
popaf
mov p, a
popaf
reti
I did not require modification of A for the most important part of the interrupt routine. And definitely not using "p". 6 less instructions to execute, 750ns saved. Quite important when you have 3 us between interrupts, and you need to serve them quickly because you need to sample pins from within the interrupt routine.
Alvaro
Offline js_12345678_55AA
  • Country: ht
« Reply #828 on: January 23, 2020, 01:40:14 pm »
pushaf
mov a, p
pushaf
// Interrupt code
popaf
mov p, a
popaf
reti
Alvaro
You also can get rid of the 2 extra cycles from the GOTO statement in case you manually instruct SDCC to place your interrupt code directly to the right position.
Here my example code how to setup a naked interrupt (without pushf/popf) which places the code at int vector location directly:
void naked_interrupt(void) __naked
  __asm
      .area NAKEDINT (ABS)   ;place following code in a new segment 'NAKEDINT' with absolute positioning '(ABS)'
      .org  0x0020           ;set position to 0x0010  (multiplied by 2 since SDCC expects byte pos here)
      ;Interrupt code        ;your interrupt code which takes care of A, flags and virtual 'p' register (RAM location of 1 word @0x0000)
      nop
      nop
      nop
      reti                   ;last instruction must be 'reti' to return from interrupt
      .area CODE             ;switch back to normal segment 'CODE' for following code
  __endasm;
EDIT: To make it work I needed to place the naked interrupt in an extra file which needs to be given to the linker before the file which contains main. Then there was still a problem since SDCC PDK compiler always creates code for an interrupt vector when it finds the main() function in a source file.
So following code will work:
nakedint.c
  __asm
      .area   HEADER(ABS)      ;place following code in the segment 'HEADER' with absolute positioning '(ABS)'
      .org  0x0020             ;3 times .org seems to confuse SDCC so it will place later HEADER section with int vector @0x000F
      .org  0x0020             ;this seems to be a bug in SDCC but I did not find any other way to avoid SDCC PDK compiler to place the interrupt vector
      nop                      ;this dummy instruction is located at 0x000F and will be overwritten later from SDCC interrupt vector placement (will become 'reti')
      .area   HOME             ;we place code in 'HOME' area which now begins @0x0010 (the correct interrupt vector location)
      nop
      nop
      nop
  __endasm;
main.c
unsigned char _sdcc_external_startup(void)
  return 0;
void main(void)
  for( ;; );
commands to compile:
sdcc -mpdk14 -c nakedint.c -o nakedint.rel
sdcc -mpdk14 -c main.c -o main.rel
sdcc -mpdk14 nakedint.rel main.rel -o testnakedint.ihx
JS
« Last Edit: January 23, 2020, 04:28:31 pm by js_12345678_55AA »
Easy PDK programmer and more: https://free-pdk.github.io
Offline alvieboy
  • Country: pt
« Reply #829 on: February 01, 2020, 04:18:58 pm »
Restrictions on INTEGS bit manipulation
All,
Is anyone aware of any restriction for bit manipulating INTEGS ?
Let me tell you what I am experiencing. Part is PFS154-S16.
I have a complex interrupt routine that triggers on PA0 edges, but the edge detection changes due to the nature of the algorithm I am using.
For this particular part of the interrupt, PA0 rising edge is being used, PB0 also used as both edges, and T16 is also used as rising edge. This gives a INTEGS value of 0b000_0_00_01., i.e., all bits are zero except for bit 0 (selecting [1:0] as "01" as required for rising edge interrupt).
At some point in the algorithm I need to enable both edges interrupt on PA0, and I need to do this from the interrupt routine (and when processing an PA0 interrupt - also the interrupt is acked immediatly at ISR entrance). For that purpose I manipulate only the bit0 of INTEGS, setting it to '0' to select both edge interrupt. This is done in assembly using:
        set0 _integs, #0  // Activate interrupt on both edges
So far so good, I can see the interruptions coming in when edge changes, either rising or falling.
Now, at another point in the algorithm I need to re-enable only rising edge interrupts (also from within the interrupt routine, and while processing PA0 falling edge interrupt). But when I do this:
        set1 _integs, #0  // Activate interrupt on rising edge only
I lose both rising and falling interrupts. I see interrupts from other sources coming in, but never from PA0.
After some experimentation, I found out that this below does work, though:
        mov a, #1
        mov _integs, a  // Activate interrupt on rising edge only
So this leads me to believe that there are some restrictions regarding bit manipulation of INTEGS register.
Does anyone have any insight on this ?
Best,
Alvaro
  • Country: ht
« Reply #830 on: February 02, 2020, 01:00:32 pm »
Have you set the other bit to 0 before (e.g.  set0 _integs, #1)?
Have you tried to read back the value after using set1 ?
Or.... To setup PA / PB in INTEGS register 2 bits are required to set F/R/B. Maybe the logic inside of the PADAUK CPU is not working correct when changing only one bit out of the 2 bit value.
JS
Offline piotr_go
    • My Projects
« Reply #831 on: February 15, 2020, 02:47:29 pm »
Hi again.
I have 2 questions.
1. I can't read input when PADIER = 0. Tested with PFS154.
Is there some kind of bug, or I'm missing something in the documentation?
__sfr __at(0x03) clkmd;
__sfr __at(0x0d) padier;
__sfr __at(0x0e) pbdier;
__sfr __at(0x10) pa;
__sfr __at(0x11) pac;
__sfr __at(0x12) paph;
unsigned char _sdcc_external_startup(void){
return 0;
void main(void){
paph = (1<<5); // Enable pull-high
pa   = 0; // HI
pac  = (1<<0); // Enable output
padier = 0;//(1<<5); // Enable PA5 wake up event
while(1){
if((pa&(1<<5))) pa |= (1<<0);
else pa &= ~(1<<0);
2. I got strange 2x speed difference between PFS154 and PMS150C.
Both set to 0x80 in IHRCR. PMS150C is 2 times slower (pwm speed and instruction execution time).
I need to set IHRCR really high (0xDA) to get the same results. Is it normal?
Is there a IHRCR factory calibration value for PMS150C in memory?
  • Country: ht
« Reply #832 on: February 17, 2020, 10:38:45 am »
Hi again.
I have 2 questions.
No bug. Just like it is. If you want to use a pin as digital input you have to enable the digital input pin in PxDIER = "Port x Digital Input Enable Register".
On PFS154 default value after reset is 0xFF (all pins input), on PFS173 default value is 0 (no pins input).
So any application using a digital pin as input should always set PxDIER for this pin.
Also nothing strange here. This is just how the ICs are manufactured (big variance from batch to batch from IC to IC).
Most production lots of PMS150C I bought need a much higher value in IHRCR than PFS154.
Only the flash based ICs (PFSxxx) do have a factory calibration value for IHRCR (@16MHz, @5.0V, @20°C).
Since variation of ICs is so big you always should include a tuning procedure after writing.
EasyPDK programmer and PADAUK_WRITER both support IHRCR calibration. You can find code examples how to use calibration inside of the release of EasyPDK programmer.
Have fun,
JS
Offline piotr_go
    • My Projects
« Reply #833 on: February 17, 2020, 11:43:10 am »
Thank you for answer.
I thought PxC register is input/output switch and PxDIER is for wake up enable. There is nothing about input in bit definitions.
"Enable PA7~PA3 wake up event. 1 / 0 : enable / disable.
These bits can be set to low to disable wake up from PA7~PA3 toggling."
There is also nothing about it in "IO Pins" chapter.
"...all the pins can be independently set into two states output or input by configuring the data
registers (pa), control registers (pac) and pull-high registers (paph)......
If user wants to read the pin state, please notice that it should be set to input mode before
reading the data port....
When PMS15A/PMS150C is put in power-down or power-save mode, every pin can be
used to wake-up system by toggling its state. Therefore, those pins needed to wake-up system must be set to
input mode and set the corresponding bits of registers padier to high."
Only after analyzing "Hardware diagram of IO buffer", the reader may state that the description is incorrect.
The behavior of the chip also does not match the mentioned diagram. Read is always HI when PxDIER is LOW. If there is an AND gate, the read should be LOW.
Padauk put this AND gate in wrong place. It's a bug.
Exactly 2x speed difference looked too suspicious, so I asked.
« Last Edit: February 17, 2020, 01:42:23 pm by piotr_go »
  • Country: ht
« Reply #834 on: February 17, 2020, 02:16:49 pm »
I also learned it the hard way... spending a lot of time why PFS173 input pin sampling was not working... which was caused by default reset value of 0x00 in PxDIER on PFS173 vs. 0xFF on all other ICs I tried before (e.g. PMS150C/PFS154/PMS154B/...). PADAUK "fixes" this in their always inserted init code (MOV A, 0xFF , MOV PADIER, A) on PFS173.
JS
Offline gaganchd2000
  • Country: in
« Reply #835 on: February 20, 2020, 02:37:49 am »
Hi
I am using PMS171B chip which Has ADC. I want to read the analog on one of the pins. first I tried to use Code generator feature of the IDE. On compilation I get this error.   "ADCC can't be 0x80 (Enable, 0x0:??)"
Expert can you please help and let me know what is the reason for error.
here is the standard code generated by IDE.
      // 1   :   All Assembly
      mov      A, 80h;
      mov      ADCC, A;         //   $ ADCC   Enable, PB0;  ( error is here)
      set1   AD_Start;
      .wait1   AD_Done;
      mov      a, ADCR;
      mov      buf[0], a;
Offline greenpossum
« Reply #836 on: February 22, 2020, 08:28:43 pm »
Thanks for the code. I seem to have an endianess problem somewhere.
I am using linux, but the IDE doesnt work with wine.
So I used windows to make and convert the file. Somehow bytes got swapped  :palm:
Just to mention that I installed Padauk's FPPA IDE 0.88 under Wine 3.7 on openSUSE Leap 15.1 and so far what I tested seems to work. I cloned Jay Carlson's bike light project from his Github repo and built it and it generated OBJ files. Or course when I tried to debug the program it couldn't find an ICE. I also ran Writer.exe and it started but it couldn't find a programmer on USB.
I hope this helps someone in case they need a working Padauk IDE on Linux to experiment with or whatever.
I don't actually have any Padauk MCUs, ICE, or programmer, I'm just playing around. Waiting for some module manufacturer like Elecrow to make and sell the open source Easy PDK programmer .
Sounds exciting. Great work, guys.
The following users thanked this post: icraftcrafts
  • Country: in
« Reply #837 on: February 24, 2020, 09:32:59 pm »
Finally fix the issue myself. Was configuring incompatible values.
Offline tim_
« Reply #838 on: February 26, 2020, 06:16:43 pm »
There is an article on Digitimes about our favourite MCU manufacturer:
https://www.digitimes.com/news/a20200225PD209.html
Taiwan-based MCU maker Padauk Technology expects its shipments of MCU products to grow by over 20% on year to reach 1.3 billion units in 2020, according to company Tang Tsan-bih.
Despite growing concerns about the stability of related supply chain caused by the coronavirus outbreak, Tang said that he believes demand for MCUs will remain strong, particularly from sectors including 5G base stations, servers and other cooling fan systems.
Boasting a group of strong supply chain partners, including Magnachip Semiconductor and Powerchip Semiconductor Manufacturing (PSMC) for wafer foundry and Greatek Electronics for IC backend services as well as inventories of needed components for up to three months, Padauk is readied to support product roll-outs of its clients, Tang stated.
For individual product category, shipments of 8-bit MCUs for BLDC (brushless DC) motors will account for about 30% of its totals sales in 2020, up from 23% a year earlier, Tang revealed.
Meanwhile, the company is also expected to see its shipments of MCUs for TWS (true wireless stereo) devices expand significantly in 2020, having shipped about 20 million units to the sector in 2019, according to an estimate of industry sources.
The sources also estimated that Padauk will see its 2020 revenues grow over 10% from the NT$522 million (US$17.17 million) it recorded a year ago.
Shares of the MCU maker is scheduled to debut on Taiwan's OTC securities market in the second half of March.
So they sell 1.3 billion units on 17.17 million revenue. That means their average selling price is just $0.013 USD! They must sell plenty of $0.01 USD microcontrollers... Also, 10% YoY ASP erosion. These guys are playing with fire - exactly the opposite of what every other company would do.
Offline gir
  • Country: at
« Reply #839 on: March 07, 2020, 02:06:41 pm »
Is anyone selling JS' programmer yet? I'd also be happy to buy a one-off made one (used too, as long as it's working) from any of you people.
Offline ali_asadzadeh
« Reply #840 on: March 18, 2020, 12:06:32 pm »
JS, I want to know how we enable options in the SDSC, for example in the PFS173 Datasheet there are these options regarding clocking tim2 and Comparator usage,
GPC_PWM which can Enable Comparator controls all PWM outputs, and TMx_Source  When tm2c[7:4]= 0010, TM2 clock source = IHRC*2 = 32MHZ and PWM_Source  When Pwmgclk.0= 1, PWMG clock source = IHRC*2 = 32MHZ
There are these defines in the pfs173.h
#define ROP_TMX_6BIT                   0x00
#define ROP_TMX_7BIT                   0x10
#define ROP_TMX_16MHZ                  0x00
#define ROP_TMX_32MHZ                  0x20
#define ROP_PURE_PWM                   0x00
#define ROP_GPC_PWM                    0x40
#define ROP_PWM_16MHZ                  0x00
#define ROP_PWM_32MHZ                  0x80
how we should use them? I want to change the TIM2 clock to 32MHz and use the Comparator  to control the PWM.
Take a look at this picture from the PFS173 Datasheet
Thanks
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
  • Country: ht
« Reply #841 on: March 20, 2020, 08:37:49 am »
Thanks
The defines in the .h files for the ICs always begin with the SFR name.
In order to set the "options" (this is just a marketing name from Padauk, in fact these are values in ROP SFR and other SFRs) you just assign them to the SFR like this:
  //setup + tune your SYSCLK (e.g. EASY_PDK_INIT_SYSCLOCK_8MHZ(); EASY_PDK_USE_FACTORY_IHRCR_16MHZ(); )
  //set ROP values
  ROP =  ROP_TMX_7BIT | ROP_GPC_PWM | ROP_TMX_32MHZ | ROP_PWM_32MHZ;
  return 0;
As you can see you can not set TM2 and TM3 differently => TMX is used to reflect this.
JS
« Last Edit: March 20, 2020, 08:39:29 am by js_12345678_55AA »
The following users thanked this post: ali_asadzadeh
« Reply #842 on: March 20, 2020, 09:55:46 am »
Thanks JS, I want to do a simple buck controller with these options, have you done any DC/DC converter with these padauk MCUs?
Also there is nothing mentioning ROP register in the Datasheet, how did you find it?
« Last Edit: March 20, 2020, 09:59:47 am by ali_asadzadeh »
  • Country: ht
« Reply #843 on: March 21, 2020, 04:04:31 pm »
Sorry, I never made a DC-DC myself, I always used dedicated ICs for this purpose.
The .h files from the original PADAUK IDE contain all this information :)
Have a look at: "C:\PADAUK_Tool\0.88\INC_PDK\PFS173.INC" :
.Assembly   OPTION_ROP   1   Interrupt_Src0   PA.0   PB.5
.Assembly   OPTION_ROP   0   Interrupt_Src1   PB.0   PA.4
.Assembly   OPTION_ROP   6   GPC_PWM         Disable   Enable
.Assembly   OPTION_ROP   7   PWM_Source   16MHz   32MHz
.Assembly   OPTION_ROP   5   TMx_Source   16MHz   32MHz
.Assembly   OPTION_ROP   4   TMx_Bit      6BIT   7BIT
   ROP      IO_WO:OP      0x67 (0x2A)
      $ 7   :   PWM_16MHz, PWM_32MHz
      $ 6   :   PURE_PWM, GPC_PWM
      $ 5   :   TMx_16MHz, TMx_32MHz
      $ 4   :   TMx_6BIT, TMx_7BIT
      $ 1   :   PA0, PB5
      $ 0   :   PB0, PA4
JS
Offline tim_
« Reply #844 on: April 05, 2020, 12:08:28 pm »
I finally got around documenting my last project with the Padauk MCU. It's a chainable 7 segment disaply, where each segment is controlled by PFS154.
It's not too exciting, but I thought it was a suitable application for a 3 cent MCU and is a nice testbed to play around with networking protocols.
You can find a writeup here: https://cpldcpu.wordpress.com/2020/04/05/addressable-7-segment-display/
Btw, one nice trick I found during the design was to use a SOIC8-clamp for programming (see attachment). All Padauk MCU have their supply and programming pins arranged in a way that easily allows doing this. No need to add any ISP connectors. You can get these very cheap on aliexpress and ebay.
« Last Edit: April 05, 2020, 05:00:34 pm by tim_ »
The following users thanked this post: edavid, zitt, icraftcrafts
Offline spth
« Reply #845 on: April 05, 2020, 04:16:16 pm »
Since the Padauk all only have a single interrupt, and none all seem to have user program immediately after it, this should always work.
So I opened a feature request for SDCC:
https://sourceforge.net/p/sdcc/feature-requests/673/
Philipp
Offline LovelyA72
  • Kashikoma from Massachusetts!
« Reply #846 on: April 12, 2020, 03:58:06 am »
A quick dumb question. Will EasyPDK computer side software work with official padauk programmer? Or do I have to build an EasyPDK programmer hardware?
Kashikoma!
Offline zitt
    • Pinball-Mods.com
« Reply #847 on: April 12, 2020, 07:33:33 am »
Hoping one of you Padauk experts can help me "get started" with these tool sets:
https://www.eevblog.com/forum/microcontrollers/padauk-pfs154-getting-started/
  • Country: ht
« Reply #848 on: April 14, 2020, 08:31:14 am »
Hello LovelyA72 and zitt,
both of your questions are related to the possibility of mixing the free and open Free-PDK stuff (SDCC + EasyPDK programmer) with the legacy (closed/missing internal documentation) manufacturer tools (PADAUK IDE / WRITER / ICE).
A lot of work has been done to liberate the PADAUK ICs, so a free open source compiler (SDCC) supports it and a cheap to build programmer (EasyPDK programmer) is available now.
The focus was and is on adding better support to the free and open stuff, so not much effort on supporting the legacy manufacturer tools.
I feel your pain not to have a debugger. But there is just no way to connect both worlds right now.
Converting .ihex to .PDK and .PDK to .ihex is not difficult at all. The problem is that the PADAUK IDE compiler inserts a lot (>150 instructions) of invisible magic code at the start which is used to tune the IC during writing. The original WRITER then implements special procedures to do the tuning and altering the firmware based on the result for every single IC written. So when you convert from .ihex to .PDK you will not have the massive PADAUK tuning code (>150 instructions) inside of the firmware (EasyPDK requires just 10-12 instructions for the tuning procedure). This will result in untuned ICs which means instead of 8MHz system clock you end up with something between 5 - 10 MHz (different for every IC you write). Such a massive variation in system clock will cause problems in your program which might use a timer for serial output or something else. The conversion from .PDK to .ihex has the problem that the inserted startup code from PADAUK IDE must be found, disabled and replaced by a EasyPDK tuning procedure. This is possible, but the big amount of different startup code inserted from PADAUK IDE (which also changes from IDE version to version) makes identification + replacement a labor intense task with not much benefit.
There is a project from alvieboy which implements a PFS154 in VHDL. This might be the foundation for a FPGA based hardware emulator in the future. Right now it is for software simulation only.
JS
Offline LovelyA72
« Reply #849 on: April 15, 2020, 04:31:03 am »
Thank you for your detailed explanation! The major issue that I am having is that it is extremely difficult to obtain an EasyPDK programmer. STM32F072C8T6(and some other parts) becomes out of stock on LCSC for a long time(it means no jlcpcb SMT assembly). Also I found that assemble this programmer is really hard for people that lacks SMT soldering experience.
« Last Edit: April 15, 2020, 04:45:41 am by LovelyA72 »
Kashikoma!
