Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 280358 times)
Offline LovelyA72
  • Kashikoma from Massachusetts!
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #1425 on: April 28, 2022, 03:48:03 pm »
Stock depleting, be quick if you still wanna pick up some PMS150C!
Kashikoma!
Offline LovelyA72
« Reply #1426 on: June 17, 2022, 08:23:57 pm »
There's a new category on Padauk's website called PML series
There are some speculation that it might be a new series of low power (or even single cell battery?) MCU.
Kashikoma!
Offline spth
« Reply #1427 on: June 25, 2022, 06:31:51 pm »
Datasheets for the PML100 have been published. Looks like the L stands for "LED", not "low power", as the PML100 has "One set triple 11bit SuLED (Super LED) PWM generators and timers".
Though operating current at 1 MHz is also 50% lower than for the PMC150. And power save current (stopexe) is much lower than PMC150 (5 µA vs 400 µA). Power down current (stopsys) is slightly higher, though.
P.S.: Interestingly, despite the memory sizes covered by the pdk13 architecture, this is actually a pdk14 device, as we can see from the "ASM_INSTR SYM_85A" in PML100.INC.
« Last Edit: June 25, 2022, 06:39:27 pm by spth »
Offline Slartibartfast123
« Reply #1428 on: August 18, 2022, 03:36:56 pm »
The PFS172/173 series seems to be discontinued and no longer available. The follow up is the PFS122/123 series which only seems to have a 12bit ADC instead of the 8bit ADC. At least the PFS122 is available right now:
https://lcsc.com/search?q=pfs122
Will there be a support in easypdkprog too?
Offline socram
    • Totodile!
« Reply #1429 on: August 19, 2022, 01:16:39 am »
Those look particularly interesting - reading through the datasheet they have a "limited voltage programming mode" where it uses 5.0V volts only, which means a simpler programmer with no voltage shifting shenanigans could be doable.
Offline js_12345678_55AA
  • Country: ht
« Reply #1430 on: August 22, 2022, 02:53:54 pm »
Support can be added as soon as I can get hold of some ICs.
In the development branch you can see already some devices (e.g. PFC151/PFC161/PFC154/PFS172/PFC232) which use limited voltage programing mode.
The main gist of limited voltage programing mode is that VPP is set to 0V during programing phase (only VDD of apx. 4.8V needs to be supplied).
However to activate the special programing mode you still need 2 different voltages for VDD and VPP where VDD < VPP-1.5V
So yes... this would make it possible to omit the DCDC booster, but setting variable output voltages for VDD and VPP is still a thing.
JS
Easy PDK programmer and more: https://free-pdk.github.io
Offline jacola
  • Country: pt
« Reply #1431 on: September 25, 2022, 11:37:03 pm »
Hi JS, do i see this correct that you could have VDD switchable between 3.3V and 5V,
and to activate 'special programming mode' you could do VDD 3.3V, VPP 5V.
Then later set VDD to 5V ?
on-board switching between 3.3V and 5V, with a reasonably low current, could probably even be done with an analog switch ..
I would like to use padauks (PFC154,PFC232,PFS122) in multiple projects now. Ideally programmable in the board, by higher level micro.
Happy to support the development efforts not only with praise but also with material.
We will do a WS2812B output driver and an I2C software slave.
Johannes
Offline hidden
  • Country: cn
« Reply #1432 on: September 26, 2022, 02:31:08 am »
Attachment NY8AO51H Timings
The following users thanked this post: piotr_go
Online piotr_go
    • My Projects
« Reply #1433 on: September 27, 2022, 10:50:23 am »
Thank You.
Now I have working write and read :)
I made BIN decoder.
Start decoding from configuration words (0x76 in BIN; "xdat", 4B len, 32B configuration words, 2048B data....)
Output: 1024W data, 16W config.
"ny_dec(buffer, 16+1024);"
uint16_t nop_bin[16+1024] = {
0xF8E5, 0x269D, 0xE258, 0xBC49, 0x7987, 0xA2DE, 0x4B2F, 0x74E7, 0x5035, 0x3ACD, 0x75A6, 0x55F9, 0xB4DF, 0xA969, 0x74FA, 0x98F6,
0xB372, 0x3850, 0x28FF, 0xFAE5, 0x114A, 0x067A, 0x8AE0, 0x6E5D, 0x5B98, 0x10EE, 0xFC57, 0x018E, 0xAA34, 0x3EEB, 0xB9B1, 0x3FE8,
0x1FB8, 0xF516, 0x8C97, 0x3541, 0xAB8B, 0xAB60, 0xA9EB, 0x9F77, 0x2C11, 0xFBBA, 0x7E49, 0x4A19, 0xB4F9, 0xF44C, 0xFF1D, 0x5725,
0xBB1C, 0x34D9, 0x962D, 0x3EEC, 0x81A8, 0x2291, 0xFD9C, 0x819C, 0xBB93, 0x36F1, 0xD957, 0xE6D3, 0x79BF, 0x5024, 0x30B9, 0xEDE4,
0x1606, 0x17D2, 0x6707, 0x4965, 0x6AFC, 0xA08F, 0xB60B, 0x9F51, 0x7134, 0x705D, 0xB19A, 0x4277, 0xB870, 0x4A9E, 0x3B14, 0xC7C7,
0x9FF7, 0x43A5, 0x79EC, 0xDEE7, 0xA7B7, 0x0791, 0x1AC1, 0x5217, 0xD55C, 0xBFF9, 0x0B5B, 0xEF6D, 0x9B7B, 0xBBB4, 0x4C9D, 0x2C93,
0x1DE9, 0x0832, 0x6721, 0x1440, 0xE11B, 0x6F5C, 0xBE65, 0x93D8, 0xCFE6, 0xB454, 0x2178, 0x669C, 0xCF0C, 0xA55F, 0xDB1F, 0xE1D8,
0xBAF7, 0xA4F8, 0xAA67, 0xB028, 0x2EBF, 0xD59D, 0x137F, 0xB0D3, 0x3ECC, 0xC3DD, 0xCA2C, 0xE482, 0x849B, 0xBB92, 0x11B8, 0xA774,
0xD23A, 0x005C, 0x6BA8, 0xAA92, 0x2512, 0xFFBE, 0x9A8E, 0xE4A4, 0x2027, 0x545F, 0x0767, 0x439C, 0x2851, 0x76D4, 0xB5D0, 0x68D0,
0x68FB, 0xAD46, 0x48A3, 0x5BB8, 0x529B, 0x14EA, 0x1890, 0xAF33, 0x3EEA, 0x9EF8, 0x41CB, 0x2B51, 0x8CF5, 0xB71B, 0xAF6A, 0x637D,
0x42D8, 0x24B7, 0x1CD4, 0x4553, 0xC519, 0xD9A1, 0xBF8E, 0x03F9, 0xF3AC, 0x3A90, 0x8E6F, 0x9190, 0x21EF, 0x9410, 0x5E40, 0x14F4,
0xA98C, 0xA6A9, 0x5743, 0x5B9E, 0x0FBE, 0x9F0D, 0xD743, 0xA75D, 0x3263, 0x202A, 0x85C2, 0xBBB3, 0xA81E, 0xC067, 0x40AB, 0x8376,
0x64C7, 0x01B7, 0xFB89, 0x96D8, 0xABD6, 0x50A9, 0x6D82, 0x0A47, 0x1168, 0xD100, 0xF24B, 0x50E7, 0x2A00, 0x8BF0, 0x5E66, 0x49D1,
0x226B, 0x697A, 0x5F2D, 0x5717, 0xB16C, 0x5B04, 0x47A1, 0x83B6, 0x451F, 0xCFEB, 0x65C9, 0x9DAC, 0x8D1E, 0x273A, 0x9320, 0xEDB9,
0xEDCF, 0xD3BB, 0xF237, 0x741C, 0x4046, 0x2C8D, 0xACF5, 0x01A8, 0x0E88, 0xD126, 0xAF6E, 0xDB00, 0xE5D3, 0x839E, 0x52EF, 0xF703,
0xE662, 0xF998, 0x7BC6, 0x206B, 0x5EAD, 0xBB0F, 0x61BE, 0xA6B6, 0xA242, 0x1C60, 0x0B06, 0x14A4, 0x5F12, 0x2E84, 0x71E4, 0x0629,
0x91EB, 0x12CC, 0xF9D8, 0x6BFC, 0x4060, 0x71A8, 0x2712, 0xCE7B, 0x06E6, 0xDDAF, 0x11BC, 0x1F09, 0x7531, 0xA775, 0x2593, 0x18C2,
0x0669, 0xDF87, 0x5EC6, 0xC736, 0x8D26, 0xD5C0, 0xE8B6, 0x74BA, 0xABFC, 0xFEA4, 0xE096, 0x6880, 0x9E65, 0x256B, 0x6E04, 0x060F,
0xCCCE, 0x992B, 0x360B, 0x6392, 0x4CE9, 0xCF7A, 0xE31B, 0x5E99, 0x220D, 0xAAD3, 0xFE7D, 0xFF02, 0x532E, 0x8275, 0xC2CE, 0xCB49,
0x68A6, 0x568F, 0x8CCA, 0xCE88, 0x6FE2, 0x3E50, 0x9492, 0xB5CD, 0xA013, 0xE144, 0xE0B0, 0x35A5, 0x1582, 0xEAB8, 0x666A, 0x0A86,
0x721C, 0x5D22, 0xA6E9, 0x4779, 0x3B95, 0x20BB, 0x0310, 0x7886, 0x070D, 0x4D8E, 0x2DF6, 0x91CD, 0xDA26, 0x5079, 0xCB70, 0x298D,
0x8336, 0x2AAB, 0x4DBD, 0xC567, 0x7002, 0x3E76, 0xC9B7, 0x3E2A, 0x6FC0, 0xE92A, 0xEC39, 0x8B77, 0xD18B, 0x7A5A, 0x4281, 0x7DFA,
0x9DDD, 0xBD29, 0x80F6, 0x6279, 0xDCC8, 0xF330, 0x6DDF, 0xF18E, 0xD501, 0x4430, 0xCF32, 0x7A5D, 0xA602, 0x910E, 0xC09F, 0x366D,
0x8310, 0x778E, 0xC65A, 0x0AB4, 0x786C, 0x32FF, 0x7765, 0xFA23, 0xFF22, 0xCDC1, 0x9B45, 0x64B6, 0x3180, 0x5C45, 0x6781, 0x9AA7,
0x4E56, 0xD3E6, 0x09FE, 0xB075, 0xD576, 0x11F4, 0x864F, 0x8DAA, 0x1476, 0x4FDF, 0xD0D2, 0x7A7B, 0xFB27, 0x1AE9, 0x0F4C, 0x3E03,
0x8F99, 0xC95C, 0x0253, 0x9A56, 0x5C87, 0x4583, 0x98A4, 0x1A28, 0xD93D, 0xE8C1, 0x7C18, 0xB73D, 0x5F4F, 0xD54D, 0xB58D, 0x9319,
0xAC92, 0x3876, 0x75DA, 0x7102, 0xDE99, 0x0E14, 0x8669, 0xD08F, 0x9F91, 0x800C, 0xD8BC, 0x76F2, 0x45F5, 0xDEE0, 0x9FAE, 0x1AE8,
0x9FF7, 0x43A5, 0x79EC, 0xDEE7, 0xA7B7, 0x0791, 0x1AC1, 0x5217, 0xEC2E, 0x16DE, 0x1A38, 0xB0BC, 0x7C78, 0x2BB1, 0x16F2, 0xECB8,
0x743E, 0x07AD, 0xCDE1, 0x63C8, 0x55B2, 0x5621, 0xFAE4, 0x0666, 0xF694, 0x1D73, 0x301B, 0x394D, 0x280F, 0x355A, 0x8170, 0x21F3,
0xD320, 0xAB67, 0x00A7, 0xC7A0, 0x9A16, 0xECE0, 0x57FE, 0x256D, 0x07BE, 0x6AFA, 0xDB4F, 0xBB53, 0x6398, 0x2B97, 0x4BD7, 0x675F,
0xBBED, 0x0FC3, 0xC168, 0xDD1A, 0x91BB, 0xC6C3, 0xDE0F, 0x711A, 0x1955, 0xFD78, 0x1604, 0x1C4D, 0xCF52, 0xE6D1, 0xEFBF, 0xA8FB,
0x012C, 0xA2D9, 0xE263, 0x2C30, 0xE632, 0x2D97, 0x5C11, 0x3A8D, 0x0798, 0x37DF, 0x50A8, 0x7480, 0x6BF6, 0x271E, 0xF505, 0xA356,
0x2B0F, 0x2B28, 0xB614, 0x32DB, 0x71B0, 0xE0DC, 0xFB0F, 0x9647, 0xCADE, 0x93B7, 0x9F0C, 0xCE41, 0xC6EC, 0x0415, 0x042F, 0xD4DF,
0xC05B, 0xA936, 0xFD83, 0x2C16, 0xBB17, 0xA670, 0x93C2, 0x32E3, 0x0B11, 0x890D, 0x94A1, 0xE462, 0x4F1D, 0x5062, 0x1AC4, 0x435D,
0x0D10, 0x0E28, 0x5149, 0xE150, 0x1F7F, 0x69D4, 0x2903, 0x9FF9, 0x281A, 0x7827, 0xE328, 0x0F36, 0xCD03, 0x1BF5, 0x0409, 0x89FA,
0x4BBC, 0x66E5, 0xF5ED, 0x209F, 0x05C5, 0x6279, 0x0320, 0x1608, 0x7C6D, 0x66CC, 0x74AA, 0xC27D, 0x6A1D, 0xB73F, 0xC94F, 0x2D92,
0x8418, 0xDC24, 0x58F7, 0x0394, 0xF4EF, 0x15F0, 0xE874, 0x9416, 0x37FA, 0x7801, 0xBE0D, 0x84D1, 0x02D0, 0x139B, 0x0880, 0x3728,
0x8FB5, 0xF607, 0xD106, 0x57E3, 0xEA04, 0x8272, 0x253F, 0x3308, 0x9B30, 0xB547, 0x1A65, 0x4B75, 0xB811, 0xBE81, 0x2B8B, 0xC602,
0xF83C, 0x1D53, 0x5318, 0x1C74, 0xF4C9, 0x48D5, 0x6393, 0x5BC5, 0x3F94, 0x7488, 0x00DF, 0x40D8, 0x9232, 0x3770, 0x7FFC, 0xD8E9,
0x6FBE, 0xD018, 0xF406, 0xB0BE, 0x398F, 0xECBD, 0xAC37, 0xE104, 0x928E, 0x5783, 0xF1F5, 0x3751, 0x7966, 0xB56E, 0x346B, 0xC624,
0xA519, 0x96B4, 0x9CCB, 0x141A, 0xF840, 0xF607, 0xA79A, 0xCB27, 0x1B7F, 0x03F4, 0xEF1E, 0xA0D3, 0xB42D, 0x1270, 0x98A1, 0x0B62,
0x0171, 0x5910, 0x260A, 0xB900, 0xDB4B, 0x072D, 0xD013, 0x2073, 0x9961, 0x4863, 0xF1D3, 0x6A74, 0xF281, 0x7ABD, 0x3C05, 0xCAAD,
0x1BCB, 0x52BD, 0x0C29, 0x30F1, 0x8F3C, 0x19C6, 0x4791, 0xED38, 0x3E7F, 0xE4A9, 0x3C95, 0xCE1C, 0x3D25, 0xC07C, 0x911F, 0xE9A6,
0xEAE1, 0x2534, 0xE77D, 0xB2EF, 0xC4AB, 0x070B, 0x8D36, 0xAB94, 0x56B2, 0x400D, 0xFD5A, 0xD4A6, 0x3688, 0xEA5F, 0x18EE, 0xBDD1,
0xF40A, 0xB2B6, 0x2A36, 0x15F1, 0x6861, 0xCA4D, 0x295E, 0x6430, 0xEC73, 0xED17, 0xDE51, 0x258C, 0x4101, 0x010B, 0x9AF0, 0xF646,
0xEAC7, 0x7811, 0x6C9A, 0x7D3C, 0xCCC5, 0x0B82, 0x33E4, 0x6F9D, 0xC650, 0x64E6, 0x8A26, 0x3B67, 0xD683, 0xCC40, 0x3DEE, 0x5A8C,
0x2781, 0xDC79, 0xA33E, 0xC7FD, 0x61DF, 0x2889, 0xC2CE, 0x1814, 0x2D04, 0xE6F8, 0xC1B1, 0x25AA, 0x1C24, 0x8AEC, 0x5523, 0xFE28,
0xE64E, 0xC6C3, 0xA893, 0xEDDE, 0xE82E, 0x7CFE, 0xDC25, 0x8F96, 0xE04F, 0x41E6, 0x6D7B, 0xE8EC, 0xB84C, 0x4548, 0xEFE2, 0x5332,
0xC545, 0x37E9, 0xDF1A, 0x068A, 0x6A30, 0x3769, 0xC2E8, 0x4531, 0xA6E3, 0x292B, 0xC9DF, 0x2923, 0xA2F6, 0x4EE5, 0xC5C1, 0xDAC3,
0x9132, 0x2902, 0x4898, 0xCBC1, 0xCD2E, 0x9BA3, 0x0FAE, 0xE159, 0x6947, 0x93EA, 0x64C5, 0x0A28, 0x53DC, 0x396C, 0x2E95, 0x58DD,
0xDAA5, 0x37CF, 0x823F, 0x8D6D, 0xA5E3, 0x3F07, 0xCE61, 0xFBE3, 0x62EA, 0xB9C9, 0xED34, 0x5E5F, 0x4D37, 0xAEEE, 0xE3DE, 0xFFC3,
0x766F, 0xFA89, 0x2657, 0x42C9, 0x1F22, 0x921D, 0xED6A, 0x0AC9, 0x1563, 0x529D, 0x6F2A, 0x15C8, 0x53FA, 0x6449, 0xA572, 0x970E,
0xD2CB, 0x3B46, 0x3CED, 0x4964, 0x3501, 0x1BEC, 0xB91D, 0x1422, 0x82E1, 0x9FD6, 0xC834, 0xB902, 0x9EBC, 0xC021, 0x6AD6, 0x2DCF,
0x7FD1, 0x184D, 0xCDC7, 0x3EED, 0xDE55, 0x99F2, 0xF28A, 0x0AEF, 0x4846, 0xD97A, 0xA0F9, 0x1DA6, 0x5F73, 0xDA9B, 0x617B, 0x07EC,
0xF620, 0x4C3A, 0xD32C, 0xA96F, 0x131E, 0x3EEC, 0x5E40, 0xC7A9, 0xEC2E, 0x16DE, 0x1A38, 0xB0BC, 0x7C78, 0x2BB1, 0x16F2, 0xECB8,
0x2B0F, 0x2B28, 0xB614, 0x32DB, 0x71B0, 0xE0DC, 0xFB0F, 0x9647, 0xCADE, 0x93B7, 0x9F0C, 0xCE41, 0xC6EC, 0x0415, 0x042F, 0xDADF
uint8_t reverse_bits(uint8_t b) {
uint8_t mask = 0b11001100;
b = (b & mask) >> 2 | (b & ~mask) << 2;
mask = 0b10101010;
b = (b & mask) >> 1 | (b & ~mask) << 1;
return b;
void ny_dec(uint16_t *data, uint16_t cnt){
uint16_t i, t[1024+16];
uint8_t a, b;
for(i=0; i<cnt; i++) t[1023+16-i] = data[i] ^ nop_bin[i];
for(i=0; i<cnt-16; i++){
a = t[i];
b = t[i]>>8;
if(a == 0xf6 || (a&0x30) != 0x30) a = (a >> 3) | (a << (8-3));
else a = reverse_bits(a);
b = (b >> 5) | (b << (8-5));
data[i] = a<<8 | b;
data[i] &= 0x3FFF;
for(; i<cnt; i++){
a = t[i];
b = t[i]>>8;
b = (b >> 2) | (b << (8-2));
a = (a >> 6) | (a << (8-6));
data[i] = a<<8 | b;
https://youtube.com/watch?v=HRjVPssgL48
« Last Edit: September 28, 2022, 09:59:10 am by piotr_go »
Offline hidden
  • Country: cn
« Reply #1434 on: September 29, 2022, 07:19:25 am »
I don't know how to privately send you attachments on this site,
At this time, please download the attachment I re-uploaded.
Also I don't understand English, I used google translate.
