Hi JS, do i see this correct that you could have VDD switchable between 3.3V and 5V,
and to activate 'special programming mode' you could do VDD 3.3V, VPP 5V.
Then later set VDD to 5V ?
on-board switching between 3.3V and 5V, with a reasonably low current, could probably even be done with an analog switch ..
I would like to use padauks (PFC154,PFC232,PFS122) in multiple projects now. Ideally programmable in the board, by higher level micro.
Happy to support the development efforts not only with praise but also with material.
We will do a WS2812B output driver and an I2C software slave.
Johannes
