Author Topic: EEVblog #1160 - Weller Responds  (Read 52672 times)
Offline coppercone2
Re: EEVblog #1160 - Weller Responds
« Reply #150 on: December 19, 2018, 11:58:39 am »
your  not supposed to blow breakers. your not supposed to shut down an entire work bench and possibly room lights and smoke the joint up because of a 50 cent part. whoever designed this standard is a fucking moron
They were drafting an electrical safety standard. Not a convenience standard.
tripping a breaker is a safety issue. so is toxic smoke.
you got a double wammy with that piece of shit. its devoid of common sense.
« Last Edit: December 19, 2018, 12:02:38 pm by coppercone2 »
Offline TheAmmoniacal
  • Country: no
  • Cut me some slack, I'm a biochemist!
« Reply #151 on: December 19, 2018, 12:04:45 pm »
Anyone able to find the manufacturer of this transformer? Someone should buy a pair, plug it into 230/240V outside with and without a fuse just to demonstrate the difference $0.2 makes. Photonicinduction style?
I collect [corporate] mugs.
MTBF ~ 700.000 h
Offline coppercone2
« Reply #152 on: December 19, 2018, 12:08:39 pm »
yea i wanna see this tested with and without a fuse on a proper 240v line thats low impedance with a bypassed breaker, feeder breaker only at 50 or 100A
« Last Edit: December 19, 2018, 12:11:24 pm by coppercone2 »
  • Country: no
« Reply #153 on: December 19, 2018, 12:12:55 pm »
With the station placed next to your jar of rubbing alcohol-soaked tissues.
MTBF ~ 700.000 h
Offline Fungus
« Reply #154 on: December 19, 2018, 12:13:06 pm »
What we really need is another one of these and not pull the plug after six seconds. See what happens if it's left alone.
This thread has nothing to do with "standards", it's here because:
a) Weller should know better than to sell an unfused device that could easily end up in a different country in 2018 (eg. ebay has been around for over 20 years).
b) The letter they wrote was pathetic. Clearly written by some management type using third-hand information.
Anybody quoting standards at each other has clearly missed the main point: Weller knows better than to do this, but didn't.
The following users thanked this post: Grapsus
Online drussell
  • Hardcore Geek
« Reply #155 on: December 19, 2018, 12:15:39 pm »
whats going to short out at 450W and current limit itself? :wtf
parts are just gonna fail to a happy impedance like that? its probably gonna trip. What part is going to make plenty of smoke like a giant transformer winding dissipating 500W @ 0.3 ohms on a 12V rail?
You've really never seen anything fail in a way that was not a direct, low-impedance short?   :-//
why did it blow the breaker if its supposed to fuse??
Wait...  What?  Who blew what breaker now?   :-//
The following users thanked this post: timelessbeing
Offline TheDane
« Reply #156 on: December 19, 2018, 12:16:39 pm »
Anyone able to find the responsible manager(s)? Someone should fire up that board instead.
Offline Fungus
« Reply #157 on: December 19, 2018, 12:16:44 pm »
PS: Does anybody know why these things even use old iron transformers instead of switch-mode supplies?
It's just a simple 12V heating element (or 24V, or whatever).
Online drussell
  • Hardcore Geek
« Reply #158 on: December 19, 2018, 12:20:07 pm »
Wait, you're saying that all electronics, appliances, etc. should be built to some mythical worldwide standard that covers all situations, all regulations in all jurisdictions?
Online drussell
  • Hardcore Geek
« Reply #159 on: December 19, 2018, 12:22:24 pm »
I think you answered your own question.  :)
Personally, I would much prefer the simple, reliable transformer in such a device rather than some silly switching supply.
The following users thanked this post: Electro Detective
Online Mr. Scram
  • Display aficionado
« Reply #160 on: December 19, 2018, 12:22:43 pm »
Dave mentioned it in the original video. Something to do with switchers not liking the high current on and off switching of a heating element.
Offline Fungus
« Reply #161 on: December 19, 2018, 12:23:51 pm »
It only takes a $0.10 fuse...  :horse:
Offline Fungus
« Reply #162 on: December 19, 2018, 12:25:27 pm »
It's only 60W or so.
I find it hard to believe that manufacturing/shipping something with a heavy iron transformer costs less than a decent filter capacitor.
Edit: Maybe there's a video in this for Dave.  :popcorn:
« Last Edit: December 19, 2018, 12:32:02 pm by Fungus »
Offline kosine
« Reply #163 on: December 19, 2018, 12:27:10 pm »
There's no such thing as "proper "tool grade" PA6" - it's just marketing noise.
PA6 is softer and weaker than PA66, and melts at a much lower temperature. Typically 200-220C versus 250-280C. Glass-filled versions are better, but harder to mould and quite abrasive on the tooling.
Main reason for using PA6 instead of PA66 is the cost. It's easier mould and resin prices have increased enormously in the last couple of years due to supply issues. PA6 is the cheaper option, hence its prevalence. Both will burn nicely if they get hot enough. (Fire retardant plastics are very expensive and little used.)
Offline TheDane
« Reply #164 on: December 19, 2018, 12:32:07 pm »
Must be isolated from mains - expensive
More components to fail - warranty expenses
- every sub-cent apparently counts, I guess this is why a transformer is used.
Corp'ies - dead entities, no guilt or remorse. Will kill you at any chance. Go after management, just like the walking dead - only a head shot counts  :popcorn:
Online drussell
  • Hardcore Geek
« Reply #165 on: December 19, 2018, 12:34:26 pm »
There are a hundred other ways for a typical device to fail that a simple fuse won't magically solve.  In most countries it is technically illegal to plug an incorrectly certified, out-of-region device into the mains.  Certainly if it does burn down your lab and your insurance company finds out you were using non-conforming electrical devices that you imported from some other jurisdiction, they're not going to pay your claim.
Don't get me wrong.  I'm surprised that this station doesn't have a primary fuse and would put one there if I were designing it, but the exaggerated claims about being death-trap level junk because it doesn't have a primary fuse are unfounded.
There are other, far sketchier devices out there.  Many of them are even legitimately tested and certified.  :)
Offline Fungus
« Reply #166 on: December 19, 2018, 12:40:48 pm »
Make a list. We can start on those after we finish with this one.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #167 on: December 19, 2018, 12:41:31 pm »
AFAIK safety standards only address fire, so it can probably put out as much smoke as it likes as long as it doesn't set something on fire, wouldn't surprise me if it didn't even mention toxic fumes.
Day Job: Mostly LEDs
Offline Fungus
« Reply #168 on: December 19, 2018, 12:43:29 pm »
The full experiment hasn't been done yet.
We only have a single preliminary experiment that was terminated before conclusions could be drawn.
Offline Fungus
« Reply #169 on: December 19, 2018, 12:52:16 pm »
You think switch mode supplies aren't isolated from mains?
Cost of copper. Cost of iron cores. Cost of shipping them based on weight. It all adds up.
« Last Edit: December 19, 2018, 12:56:15 pm by Fungus »
Online Mr. Scram
« Reply #170 on: December 19, 2018, 12:58:50 pm »
What makes you think the people working on cost optimisation in these huge firms haven't thought of that?
Offline Fungus
« Reply #171 on: December 19, 2018, 01:01:18 pm »
Maybe their customers are old-fashioned and think that heavy iron power supply = quality/reliability.
(there's already a few examples of that in this thread)
Offline David Hess
  • DavidH
« Reply #172 on: December 19, 2018, 01:07:24 pm »
None of the hand held line voltage soldering tools have fuses and all are compliant to the Australian standards and have Australian electrical approval.
I know from personal experience that the 120 volt AC line voltage soldering pencils fail by having the heater go open when 240 volts AC is applied.  They are safe but expensively fragile.
Online zucca
  • EE meid in Itali
« Reply #173 on: December 19, 2018, 01:21:10 pm »
Louis Rossmann joined in the rant... check his YT channel.  :box:
Offline eugenenine
« Reply #174 on: December 19, 2018, 01:23:29 pm »
Your home stereo, wall warts, clock radio etc. consumer electronics all require a primary fuse of some sort in the power transformer.
Seeing that fuse on Hakko and other Weller products, Metcal etc. is common sense - but too bad the politics of a fuse are at play.
I have opened a lot of wall warts and small electronics (clock radio, etc) and very few have a fuse, it is not a requirement.
The following users thanked this post: timelessbeing, drussell
