Author Topic: EEVblog #1160 - Weller Responds  (Read 167930 times)
Online Wolfgang
    • Electronic Projects for Fun
Re: EEVblog #1160 - Weller Responds
« Reply #750 on: January 05, 2019, 06:26:04 am »
... if you insist, *ugly* fanboys.  :)
Online IanB
« Reply #751 on: January 05, 2019, 06:51:14 am »
Oops...  I forgot to include bigclive's appropriate response to the 120->240V mishap video above:
Classic Clive...  :)
Actually, BigClive is wrong. The primary saturated and ran well beyond 4 times normal power dissipation, and then likely went into accelerated melt down as the enamel was burnt off and the primary turns shorted.
The comment is about the toaster, not the soldering station. 120 V --> 240 V on heating elements ==> 4x the power.
Instead of glowing a dull red like normal, the heating elements lit up brightly like a bulb. The toaster was glowing like crazy.
The following users thanked this post: Andrew McNamara
Offline Fungus
« Reply #752 on: January 05, 2019, 07:46:40 am »
Another would be to add a primary fuse and to see whether that protects the unit completely from 230V.
Of course it would.  :palm:
People seem to think I'm arguing one way or the other. I'm not. I'm seeing claims being made about the station being dangerous without a fuse.
At least one of them went up in smoke without it.
Wouldn't you at least want to know it won't do that?
Offline timelessbeing
« Reply #753 on: January 05, 2019, 08:14:58 am »
It's easy enough to ensure by not taking it to another country.  :horse:
Offline Fungus
« Reply #754 on: January 05, 2019, 08:25:02 am »
We know of at least one that went up in smoke.  :horse:
And we know about mains surges in your country.  :horse:
And you can avoid having to wear a seat belt by simply driving carefully....  :horse:
« Last Edit: January 05, 2019, 08:27:11 am by Fungus »
Offline floobydust
« Reply #755 on: January 05, 2019, 08:25:29 am »
Appliances I have seen or repaired that do not have a primary fuse - only light fixtures and 1960's car battery chargers, vintage tube radios.
Possibly a few old wall warts, although I'm not sure as I didn't unwind the transformer looking for a thermal fuse. Even in the 1980's there were thermal fuses in consumer electronics (small tranformers). I used to repair clock radios, ghetto blasters, stereos, TV's etc. in a shop, not casual numbers.
In low <~20VA transformers, fine primary copper wire does end up being a fuse at the bobbin lead-in. I have seen two melt there, say smaller than #28 AWG. Inductance leading to an arc in the bobbin, can't be a good idea with this method. It's odd the UL standard does not allow it but the IEC standard seems to:
IEC 61558-1; 15.3.5 intentional weak part. "may be an... inaccessible weak point in a winding."
UL 1585; 18.2 "Crossed or reduced cross-section conductors shall not be used as a protective device. A nicked conductor is a form of reduced cross-section conductor."
Offline Electro Detective
« Reply #756 on: January 05, 2019, 08:44:31 am »
...And we know about mains surges in your country.  :horse:
It may have been asked before but just where is 'that' country ?  :-//
seeing as Weller Fellas timelessbeing and Mr. Scram  are from Country: 00 or is it Country: OO ?
« Reply #757 on: January 05, 2019, 08:47:22 am »
Feel free to show us a case where a mains surge caused it to "go up in smoke".
The alternative to not wearing a seatbelt is death. You're not very good at this analogy game are you? The fuse is more like wearing a helmet to walk your dog.
« Last Edit: January 05, 2019, 08:53:29 am by timelessbeing »
Offline Fungus
« Reply #758 on: January 05, 2019, 09:30:23 am »
LMGTFY.
Looks like this thread's over. All that's left is trolls and people who refuse to see common sense.
« Last Edit: January 05, 2019, 09:32:40 am by Fungus »
The following users thanked this post: TheDane
« Reply #759 on: January 05, 2019, 09:42:59 am »
 :palm: For this iron.
Looks like this thread's over. All that's left is ... people who refuse to see common sense.
I completely agree.
« Last Edit: January 05, 2019, 09:44:43 am by timelessbeing »
Offline Fungus
« Reply #760 on: January 05, 2019, 10:08:17 am »
I completely agree.
Given a free choice: Wouldn't you prefer to have a fuse on the back?
Me? I don't think it's a lot to ask in a $100+ tool.
(or do you really think it would make soldering more awkward and uncomfortable?)
Offline drussell
  • Hardcore Geek
« Reply #761 on: January 05, 2019, 10:11:36 am »
Classic Clive...  :)
That particular comment was in regards to the toaster video, not your Weller video(s).  I should have been more clear.
The point is that 120V appliances and devices are often not designed in such a was as to fail completely silently and smoke-free when plugged into 240V.  It is simply not something that is generally considered an important factor and is normally deemed to be an infrequent enough probability of occuring that things like the enclosure containing most of the mayhem is considered enough in standard design.
Things like inverter/chargers are far more of a problem, where things like sparks and burning material are almost certain to spew out upon a semiconductor failure (almost always a short) given the thousands and thousands of amps available, especially on the DC side, even with protective fuses and/or circuit breakers fitted in the DC battery lead.  You're specifically supposed to take care to install it in such a way and pay attention to the surrounding materials below, etc. to limit the chances of combustion when a failure occurs and the molten material fountain blasts burning stuff all over your inverter closet.  :)
Does anyone have a copy of that Motorola modem ad from the 80s/early 90s where they show the unit that UL flame tested the chassis on?  I'll have to dig up a copy.  :)
I really don't appreciate being railroaded onto Weller's side. Let's stop fishing, baiting and framing and get back on topic.
Neither do I, especially this "if you don't agree that a fuse must be mandatory in every case, you must be a corporate apologist or paid shill." nonsense.
« Reply #762 on: January 05, 2019, 10:18:08 am »
Since you're offering it to me for free, then of course I'll take it. But since it would just sit on my bench, plugged into a 120V socket, it wouldn't make any difference. If it's a choice between irons, then I would focus on more important things. The Weller takes way too much space for example.
« Last Edit: January 05, 2019, 10:20:42 am by timelessbeing »
Offline drussell
  • Hardcore Geek
« Reply #763 on: January 05, 2019, 10:27:10 am »
I don't think anyone is saying that they don't think it should have a fuse, just refuting the idea that not having a fuse on something is automatically a complete fail.  There is a wide chasm between those ends of the spectrum.
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
« Reply #764 on: January 05, 2019, 10:45:24 am »
At 16 pages: :horse: :horse: :horse: :horse: :horse: :-// :horse: :horse: :horse: :horse: :horse: :=\
« Last Edit: January 05, 2019, 10:52:22 am by Quarlo Klobrigney »
Voltage does not flow, nor does voltage go.
Offline EEVblogTopic starter
« Reply #765 on: January 05, 2019, 12:11:04 pm »
Because the enamel melts and the turns short out, and this likely happens in a progressive accelerated fashion, effectively feeding on itself in a thermal runaway of sorts.
... until it goes open circuit. Right?
Nope, mine didn't.
« Reply #766 on: January 05, 2019, 12:11:40 pm »
What happened to the Remi video I posted? People liked it.
I removed it. Stop spamming this thread.
« Reply #767 on: January 05, 2019, 12:14:54 pm »
When your competition (including the $20 clones) have it, and most of Weller's own products have it, it's hard not to see it as a fail.
This entire thread is about context in terms of Weller and their decision, not absolute technical right/wrong devoid of context detail.
The following users thanked this post: thm_w, Fungus
« Reply #768 on: January 05, 2019, 12:18:48 pm »
I'd argue it should be if you use a universal IEC mains input connector.
This never would have passed mustard at any company I've ever worked at.
I haven't seen anyone say that here.
The following users thanked this post: Kean
Online Wolfgang
« Reply #769 on: January 05, 2019, 01:13:59 pm »
Dave, would you be availabe for a test where a Weller unit is *not* removed from mains after it started smoking ?
Some Weller fanboys here say that there is no safety issue because no open flames occurred.
« Reply #770 on: January 05, 2019, 01:17:13 pm »
Nope, I'm done.
But anyone who wants to do this, I'd say that there are large variables in this, so testing just one and getting a negative result doesn't tell you much, you need to test a number of them.
« Last Edit: January 05, 2019, 01:19:25 pm by EEVblog »
The following users thanked this post: Andrew McNamara, Electro Detective
Online Wolfgang
« Reply #771 on: January 05, 2019, 01:25:26 pm »
Nope, I'm done.
OK Fair enough. I agree that just one unit is not enough, but my question is if convincing some hardcore fanboys is worth buying 10 Wellers and then blowing them up.  >:D Not sure. IMHO, the parrot is dead and stays dead.  :horse: Only buy stuff with a fuse !
« Last Edit: January 05, 2019, 02:06:52 pm by Wolfgang »
Offline Fungus
« Reply #772 on: January 05, 2019, 01:55:34 pm »
my question is if convincing some hardcore fanboys is worth buying 10 Wellers and the blowing them up.
Nope. They'll still say "Well, don't use them on 240V then!" and "I never had a problem!"
It might only be 1% fail from a technical viewpoint, but it's a complete fail from a marketing and user-confidence-generation viewpoint.
And... that's what this thread is supposed to be about. Go watch the video again, see Wellers pages and pages of "Safety first!" advertising, etc.
 :horse:
The following users thanked this post: Wolfgang
Offline Fungus
« Reply #773 on: January 05, 2019, 01:58:51 pm »
Well, there you go! Everybody would like a fuse, ideally, but Weller is failing to provide one.
Marketing 101: "Exceed your customer's expectations".
Offline Mr. Scram
  • Display aficionado
« Reply #774 on: January 05, 2019, 03:35:24 pm »
Then why do Weller bother to fit fuses to most of their other products in the same functional category?
If there is any argument here at all, this is it.
Again, Weller are allowed to sell a (certified) product without a mains fuse, that's not an issue, but why do some of them have a fuse and some don't?
The answer is still the same as the last times it was discussed.
The following users thanked this post: coppercone2
