Author Topic: EEVblog #1176 - 2 Layer vs 4 Layer PCB EMC TESTED!  (Read 13290 times)
Offline tszaboo
Re: EEVblog #1176 - 2 Layer vs 4 Layer PCB EMC TESTED!
« Reply #25 on: February 03, 2019, 10:35:35 pm »
Since then, 4 layer boards have been pretty much mandatory on all new products.
Pretty much. I havent designed a 2 layer PCB in this decade, unless I could keep the entire bottom side as ground. Most of the stuff I design nowadays require some impedance control, and making a 50 ohm trace on a 1.5mm thick board is just ... inconvenient.
Offline mrpackethead
  • D Size Cell
« Reply #26 on: February 04, 2019, 12:19:29 am »
yeah, 2.5mm wide tracks are possibly going to make it hard!
Offline EEVblogTopic starter
« Reply #27 on: February 04, 2019, 02:05:45 am »
I did watch through the video, and  find it astounding that you can get any work done while simultaneously & continuously talking & reading & responding to that text thing on the left.
If you had 5% of the experience with KiCad compared to Altium this would have been 2 minutes of work.
It was not meant to be a work video, it was just me playing around with KiCAD whilst doing some live chat whilst I just happened to do what I want. It is what it is, and no, you can't effectively get work done whilst doing such a thing, that's why it wasn't about me getting work done in any kind of effective way. You don't have to like that style of video, and that's fine. And there is no point telling me the issues with that, trust me, I know.
BTW, I did make some very valid usability points in the video and someone on the KiCAD team actually thanked me for that.
« Last Edit: February 04, 2019, 02:09:10 am by EEVblog »
Offline Neilm
« Reply #28 on: February 04, 2019, 07:55:55 pm »
I can think of only one advantage of two layer boards over four, removing devices during repair is a lot easier.
It is also cheaper. If I can make a board that passes EMC requirements on 2 layers then why would I want to make it 4 layer?  I will admit the only boards I have ever done 2 layer were electrically very simple but I have done them.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline boffin
« Reply #29 on: February 05, 2019, 03:22:00 am »
Would be interesting to see emission differences between same designed boards in which one is smt the other dip.
Wouldn't be any different if the layout remains otherwise identical.
Would anyone be interested in a 6 layer version with grounds on the outside layers?
I'd actually be curious to know if it's any better if you place the power/ground  on the outside layers, and run the data tracks on the buried layers.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #30 on: February 05, 2019, 03:36:54 am »
It would be, though a design like this is still dominated by the size and thru-hole shape of the DIPs used.
An SMT build isn't much better, because you still have via rings on the back side.
In both cases, VCC will be chopped up by inevitable too-good-to-miss-out-on routes, between adjacent and nearby pins.
For DIP, pour around all pins is quite feasible, but hard to maintain for SOIC (plus a via per pin, on average, more or less), and impossible for TSSOP or smaller.  So the rows of pads in the latter case will cause a void in the VCC pour.
Consequently, you'll want to space things out somewhat more than you would even for a 2-layer build (with no particular attention to EMC, that is), which means you aren't saving any size going to four layers here.  So, your motivation is now, just to say you could, more than anything.
The best you could do, is to opt for blind vias ($$).  Then you could build top side components and VCC on top layer, drop vias to Mid1 for priority routes, then route intersections and low priority routes on Mid2+.  Ground vias are regular thru vias or pads.  This would give you 100% solid bottom ground (except for vias), which is excellent shielding for frequencies well above the skin depth of that copper thickness (so, for 2oz, some MHz).
One possible advantage of this kind of construction: the majority of traces/routes are fully encapsulated, making corrosion a somewhat lower risk.  Vias, pads and connecting traces are still vulnerable; vias can be plugged/capped (for another dollarsign more; we're already not caring about fab cost, so what the hey ;) ), and we can do double layer of soldermask, or fill silk everywhere*.  Or both, why not.  And obviously, there's always the boring answer, conformal coating. :P
*Oh that's something I should try some day, do an inverted silk board.  Text can be drawn with inverted labels, and the negative space inbetween can be filled without too much futzing (possibly a polygon can fill it, but I kind of doubt that Altium at least calculates poly clearances that way, on non-copper layers that is, hmm).
Seven Transistor Labs, LLC
Offline srce
« Reply #31 on: February 15, 2019, 03:34:37 pm »
A while ago, I was playing around with COMSOL to get a feel for how a 4-layer PCB reduces crosstalk. You can model any combination of materials you want:
Then calculate the electric potential. Here for 2-layer PCB then 4-layer, both with the same thickness (1.6mm):
The closer ground plane on the 4-layer PCB considerably reduces the potential on the parallel wire (from about 0.15V to 0.01V). You can get better results for the 2-layer board by making it thinner.
Going back to the subject of this thread, if we look at the field in the air above too, we can see how that is also reduced:
Obviously, it's better still if you have 6 layers and can sandwich it between two planes:
« Last Edit: February 15, 2019, 04:13:45 pm by srce »
The following users thanked this post: LapTop006, thm_w, tcottle
Offline WanaGo
« Reply #32 on: January 28, 2020, 02:55:05 am »
I have two questions in mind:
1) Does anyone have a reference for the probes and the preamp?
Sorry for the dig up on this, but does anyone know the answer to this?
I saw the spectrum analyser he used is the Rigol DSA815, but I didn't spot the pre-amp or what the probes are exactly.
We are wanting to get a test setup like this at work so the engineers can do some testing before sending them off to the lab, it might save us some time and money being able to see real problem areas of the prototypes.
Thanks
« Reply #33 on: January 28, 2020, 03:35:16 am »
https://www.tekbox.com/product/tekbox-tbps01-emc-near-field-probes/
Near field testing can help detect issues, but nothing beats a proper far field antenna test which is what they will do at the lab. A decent far field antenna will cost more than the entire near field rig including the spectrum analyser though.
This is one of the cheapest ones you can get:
https://www.aaronia.com/products/antennas/BicoLOG-30100-X/
« Last Edit: January 28, 2020, 03:39:28 am by EEVblog »
The following users thanked this post: WanaGo
Offline nctnico
« Reply #34 on: January 28, 2020, 10:54:07 pm »
The 'RF explorer' near field probes are even cheaper compared to the ones from Tekbox.
But still don't expect much from doing near field probing to check whether your device will pass EMC testing. The biggest problem usually is emissions from wires and in some freaky situation the casing. So you better get some current clamps to measure RF leakage going through cables. A LISN is also a good investment to check conducted emissions in the power supply. I never needed to use a pre-amplifier for EMC trouble shooting.
When it comes to emissions you really should do a pre-compliance measurement at a test lab. Then you can get a graph with the problem areas in the frequency spectrum. From there you can hunt down the source using near field probes and current clamps. Otherwise you will be literally taking a stab in the dark.
« Last Edit: January 28, 2020, 10:59:42 pm by nctnico »
Offline julian1
« Reply #35 on: April 09, 2024, 11:29:09 am »
At 5.20min, for the test setup-up,
For someone who knows little about spectrum analyzers - what is the reason both attenuation (to prevent input saturation) and the pre-amplifier (to add gain) both turned on?
Offline thm_w
  • Non-expert
« Reply #36 on: April 09, 2024, 08:36:09 pm »
As you said, attenuation is first which can prevent input saturation, or maybe damage to the instrument.
https://electronics.stackexchange.com/questions/345515/what-does-the-attenuation-setting-do-in-an-rf-spectrum-analyzer
https://saving.em.keysight.com/en/used/knowledge/guides/spectrum-analyzer-buying-guide/how-to-read-a-spectrum-analyzer-like-a-pro
https://www.keysight.com/blogs/en/tech/rfmw/2020/05/28/spectrum-analysis-basics-part-2-whats-in-a-spectrum-analyzer
