Author Topic: EEVblog #1183 - RIFA Madness (Schaffner Repair)  (Read 15261 times)
Online EEVblogTopic starter
« on: February 23, 2019, 11:48:44 pm »
Repairing the Schaffner NSD200E Mains Interference Simulator.
And the dangers of bad mains filters capacitors, and RIFA brand in particular.
Online Wolfgang
    • Electronic Projects for Fun
Re: EEVblog #1183 - RIFA Madness (Schaffner Repair)
« Reply #1 on: February 24, 2019, 12:34:36 am »
It should be forbidden to design these parts into any equipment without a valid blasting and explosives handling license :)
Offline bitseeker
« Reply #2 on: February 24, 2019, 01:18:26 am »
Good ol' RIFA. We know them well.
The Schaffner Simulator, of course, has a Schaffner filter on the IEC connector, which is also famous for going bang. It needs replacing, too.
The following users thanked this post: Towger
Offline sean0118
« Reply #3 on: February 24, 2019, 01:30:40 am »
Dave, you should test the cracked ones to destruction. Maybe outside?   ;)
Offline floobydust
« Reply #4 on: February 24, 2019, 01:31:44 am »
These capacitors are still for sale, today. Vishay offers them, look at PME 271 series.
I'd emailed Vishay and said WTF are you doing still selling these? No response. The epoxy seems to shrink with age.
Offline wraper
  • Country: lv
« Reply #5 on: February 24, 2019, 01:35:51 am »
Because they have those Rifa caps inside as well.
Online Andy Watson
« Reply #6 on: February 24, 2019, 01:55:58 am »
Another victim of the Rifa virus!  :-DD Its starting to look like ordeal by Rifa caps is a rite-of-passge for anybody tempted by older equipment. :)
Offline bitseeker
« Reply #7 on: February 24, 2019, 02:03:29 am »
Yep, some of those filter modules even have a circuit diagram stuck on that shows that those caps are inside.
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #8 on: February 24, 2019, 02:40:32 am »
Rifa  madness  great   title  ! 8) The question is , does  Dave have the munchies ?
It would be awesome if you connected that  test  device into a flat  screen  television or some other sensitive  electronic  device you found in the  dumpster room.  You can  see how those A/C  pulses  effect  the electronic  equipment under  test  conditions
I use Surgex   surge  protectors  to protect  all my computer  equipment. The manufacture  states that  devices  under  load  can withstand  6KV  pulses using  Surgex  and have  proven that  fact in many   videos destroying  M.O.V.'s .  The  testing equipment  used to test Surgex  products  probably is very  similar to  the pulsing  device in this video.
I  do  believe  that Surgex  products  have  X/Y  filter capacitors on the main board , since  as  Dave would say " I take them  apart"
https://www.ametekesp.com/surgex
ESP Surge Demonstration
https://youtu.be/g0VFziFCM1c
« Last Edit: February 24, 2019, 02:58:08 am by johnlsenchak »
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #9 on: February 24, 2019, 02:47:02 am »
Reefer RIFA MAdness ! The TEA group knows all about it.  :-DD
He's holding one that just blew up -
Offline bitseeker
« Reply #10 on: February 24, 2019, 05:02:13 am »
 :-DD
Offline joeqsmith
« Reply #11 on: February 24, 2019, 05:04:54 am »
Nice job with the repair.  Hope to see a part III with it in action.   2.5KV at 10ns and it looked like a 50 ohm source, will the 121GW survive??
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #12 on: February 24, 2019, 09:27:18 am »
I am in process of repairing two PSUs from HP 8594E.
They contain 3 RIFA caps which I want to replace.
Can someone please guide me on how to find correct replacements?
Thanks,
Vitor
Offline Towger
  • Country: ie
« Reply #13 on: February 24, 2019, 10:14:58 am »
Hi Dave,
Did you get this one in the other module:
Don't forget the mains input filter, it will need to be replaced as well.
« Last Edit: February 24, 2019, 10:17:21 am by Towger »
« Reply #14 on: February 24, 2019, 10:25:16 am »
Hi Dave,
Damn, completely missed that, thanks.
Offline madires
  • A qualified hobbyist ;)
« Reply #15 on: February 24, 2019, 11:49:24 am »
After the "big bang" Schaffner went for a different cap manufacturer for their line filters. Apparently it was a case of unplanned obsolescence. Also beware of NOS Schaffner line filters from that era. They provide an instant bang for the buck quite often. ;D
« Last Edit: February 24, 2019, 11:51:42 am by madires »
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #16 on: February 24, 2019, 12:11:17 pm »
You know what is funny (or in fact is not)?
That the bloody ELEKTRO AUTOMATIK GMBH still uses these piece of shit capacitors in their premium priced power supplies.
Offline HighVoltage
« Reply #17 on: February 24, 2019, 01:01:50 pm »
I had a fire in the lab once because of these RIFA capacitors an a Philips counter.
Luckily I was in the lab and could extinguish it.
Since then I always open up old equipment and exchange the parts.
Offline Kleinstein
« Reply #18 on: February 24, 2019, 01:35:34 pm »
The RIFA caps are not the only ones to fail. Back in the 1970's there where several similar caps going bad. I faintly remember that there was a recall of TV sets because of faulty caps, that did not deserve the  X rating, as they sometimes failed with fire (not just smoke).
One still sees X-class caps used across the line in something like power tools fail - quite often when the motor turns bad an produces more spikes, but also without an obvious reason. Too much humidity seems to be not the only failure mode.
The newer RIFA caps should be OK - though it's odd to still find the same old series.
Offline Zbig
« Reply #19 on: February 24, 2019, 04:29:24 pm »
Gee, must have sucked to be a RIFA employee. 10 out of 10, that's something... I feel for them. Just imagine this:
A grandson, wants to become an EE: "Grandpa, what did you do when you were younger?"
Grandpa: "I was working for R... I was a pimp."
Now I'll see myself out.
Offline tchicago
« Reply #20 on: February 24, 2019, 05:10:59 pm »
Dave, the sine wave on the scope looks significantly distorted. Is this normal for the mains voltage?
Offline bsfeechannel
« Reply #21 on: February 24, 2019, 05:11:16 pm »
I don't get the RIFA madness reference. Can some good soul explain it?
Offline Zbig
« Reply #22 on: February 24, 2019, 05:17:30 pm »
Come on, admit it, you haven't even tried: https://en.wikipedia.org/wiki/Reefer_Madness
The following users thanked this post: bsfeechannel
Offline joeqsmith
« Reply #23 on: February 24, 2019, 05:20:06 pm »
Or you can watch the whole movie on YT.
https://youtu.be/zhQlcMHhF3w
Offline Towger
  • Country: ie
« Reply #24 on: February 24, 2019, 05:48:19 pm »
100% failure rate.  I send Dave some New Old Stock RIFA suppression caps I had in a parts draw for EEVsmoke, about a year back.
