No pocket multimeter to take out the guess work?
Dud switch with dry contacts probably bent/shattered cheap metal bits inside shorted to buggery,
which turned the unit into a wannabee soldering station
Pry the switch apart and likely that's the deal
I'll bet it started to get stiff and or wonky beforehand
Just what you need, leaving kids to play with innocent looking and transparent plastic based toys
and copping a worst case scenario = something catches fire, like a bed...
OneHungLow Inc. have outdone themselves on this one,
one wonders what .0000? percentage of 1 cent that switch cost to produce
Wack in a new or quality salvaged switch, check that it's ok and lubed
and maybe an inline protective measure for 'next time' (not!)
EDIT: the soldering process may have weakened the switch's cheap/flimsy internals, so a fail was bound to happen even with occasional use
