Author Topic: EEVblog #1220 - Siglent SDS5000X 1GHz Oscilloscope Review  (Read 19300 times)
Offline tautech
Re: EEVblog #1220 - Siglent SDS5000X 1GHz Oscilloscope Review
« Reply #50 on: June 18, 2019, 09:18:06 pm »
@tautech: As I wrote in my previous post: so far the Rigol DS1054Z seems to be the only exception. Pehaps you should include the oscilloscope model  WinnieThePooh is testing (the Rigol MSO5000 series) and the problem he describes in you short (likely out of context quote) has nothing to do with sin x/x reconstruction. Don't make the same mistake rf-loop made in his eagerness to make things prettier than they are or make standard features look special. It sounds like a clueless salesperson; 'Look, this Siglent calculator is showing 2 when I punch in 1+1'. Real engineers will be put off by those kind of tactics.
Which is why I included a link to the post, so you can check the context and model.
Yes it seems the 5k series is afflicted by incorrect Dot mode implementation too and this info is from other sources other than rf-loop.  :P
Avid Rabid Hobbyist
Offline David Hess
  • DavidH
« Reply #51 on: June 19, 2019, 07:03:49 am »
But I've got to place some small criticism here -- your input noise comparison is somewhat dodgy (34:00 into the video): Since the R&S had some visible DC offset of the input signal (round about -300µV), this will clearly contribute to the RMS measurement. Try checking noise with the inputs in AC coupled mode. Depending on the internal processing, the average offset will get subtraced in this mode (not sure if it works this way on the R&S, at least the "mature" Rigol products do it like this).
Then I'm sure you'll find that the R&S is at least on par with the new Siglent scope.
AC coupling makes no difference.
But you are right, the DC offset matters.
Just powered it up again and it happened to have almost no DC offset and a I got 107uV RMS, and it's 87uV in standard deviation mode.
After a bit the offset rose and the standard deviation gets rid of it, still around 87uV
Looking at their incomplete manual, at least Siglent included Stdev to compute AC RMS and RMS to compute AC + DC RMS.  But the multimeter has separate AC RMS and DC RMS selections.  Is Siglent always so consistent?
Calculating AC + DC RMS when AC coupling is selected must be a dumb oversight.
87 microvolts RMS over 1 GHz is respectable; many DSOs are much worse.  The lowest noise oscilloscopes I have tested have a slightly lower broadband spot noise than that, about 25% lower.  But with a lower bandwidth, that is expected because higher spot noise comes with higher bandwidth devices.
Maybe I didn't get the point but I can't imagine that any scope on the market isn't interpolating the displayed waveform from "true" sample points. At least in single shot mode there simply isn't any choice, or is it? And in the "digital phospor" / intensity grading modes. I would assume the samples of previous acquisition are not really existing anymore, just the previous waveform(s) must be stored somewhere to process the grading.
Anyway, I still find it puzzling that any kind of interpolation divides the acquisition rate by a factor of four (or more).
Interpolation might be used for the display but not to fill in the acquisition record.
The original DPO mode of operation generated a 3D histogram of the data in hardware at the maximum sample rate with no interpolation.  Modern DSOs tend to generate the histogram (for display or measurement) from the acquisition record with the processor instead of in hardware and the record length then limits the sample rate.  This makes sense when less than the absolute maximum performance is required because processor performance is so much better now than 20 years ago and it makes for less expensive high performance DSO.
But this creates a conundrum.  If interpolation is used, then it corrupts the histogram and any measurements which rely on it like RMS, peak, or whatever if aliasing is present.  I suspect Rigol does something like this explaining various odd measurement behaviors.
Online Performa01
  • Country: at
« Reply #52 on: June 19, 2019, 09:25:23 am »
Yes, it's hard to believe, yet rumours have it that such scopes do exist. You can always calculate something completely new from a number of original samples, which then just get replaced by the result of the computation (like most modern digital cameras do).
Yes, there are some scopes that use only the screen (or some small secondary) buffer for intensity grading.
For Siglent X-series scopes there is one irrevocable standard: In normal mode, it will always show all original sample data from within the last 40ms (if available) on the screen at once. In Sequence recording mode it will even show the complete history buffer, i.e. up to 100000 records  and/or a total of 440 Megasamples at once. This way you can detect any anomaly at a glance.
This is true for normal acquisition mode; Peak Detect might, Average and Eres will replace the original sample data by the corresponding processed data, i.e. min/max data pairs in case of Peak Detect, the sliding average of corresponding samples over a number of subsequent records in case of Average and the result of a FIR lowpass filter operation within one record for Eres. Nevertheless, the number of samples doesn't change though and we still get all the data displayed.
This is by the way the major difference to LeCroy scopes, which never ever manipulate the original sample data, thus cannot have peak detect and implement Average as well as Eres as Math functions.
Now for the mystery of intensity grading, which some confuse with persistence (of course we can have persistence as well, but that has absolutely nothing to do with intensity grading):
It is simply a matter of the number of samples falling into the exact same position on the screen – similar to an analog scope, where intensity is determined by the speed of the electron beam moving over the screen. Since each sample represents a certain time step (1/samplerate) the accumulation of these results in a total time which in turn determines the trace intensity.
For this process, a lot of data is involved in the display mapping. It is the record length multiplied by the number of acquisitions within a span of 40ms (which is the display refresh period).
With the explanation given above, we could measure/calculate the data rate for different timebase settings:
200ps/div => 120kpts/s => 4.8kpts/frame;
20ns/div => 110Mpts/s => 4.4Mpts/frame;
1ms/div => 950Mpts/s => 38Mpts/frame;
So while at even slower timebases we can exceed 1Gpts/s, there seems to be no dedicated graphics processor to handle such an amount of graphic data in a fast and efficient way.
The amount of additional dots required for interpolation depends on the signal amplitude, waveform and frequency. This can easily lead to a multiple of the original data to be drawn on the screen. This seems to be the bottleneck and both position mapping and interpolation require additional processing time.
Well, these are different worlds, I suppose. Experienced DSO users should be familiar with the Stdev measurement (even though I’ve come across “experts” who confuse it with the standard deviation in the measurement statistics), whereas on a DMM the terms AC RMS (often just RMS) and AC+DC RMS are common. But that’s irrelevant, because other than a true scope meter, a pseudo DMM is just a marketing gimmick in my book, that doesn’t belong into a DSO – not in the midrange class anyway. Yet since it was introduced by one of the big boys, every manufacturer feels the need to offer one as well. I think Siglent is the last one to follow that trend.
Online nctnico
« Reply #53 on: June 19, 2019, 11:55:33 am »
Another option could be that Siglent is making the intensity grading actually useful. There is not much use to hide a small glitch in 255 shades of yellow because you won't see it (just like on an analog scope). 8, maybe 16 shades is more than enough to distinguish between often and more rarely occuring signals.
Offline rf-loop
« Reply #54 on: June 19, 2019, 12:17:34 pm »
Let's hope master of magicians protect us from this devastation of performance.
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline David Hess
  • DavidH
« Reply #55 on: June 20, 2019, 05:19:04 am »
The documentation does not even discuss the difference and then of course there is the standard deviation calculation of the measurements so that is three different names for the same calculation on different data.  I think standard deviation for automatic measurements and AC RMS and DC RMS for acquisition record measurements by both the DSO and digital multimeter would be less confusing.  As evidence I present Dave having to go back and make the noise measurement a second time.
Some old oscilloscopes had a real digital voltmeter coupled to the vertical inputs with real digital voltmeter performance.
Online Performa01
  • Country: at
« Reply #56 on: June 20, 2019, 07:03:12 am »
You're right, the documentation could certainly be improved.
Apart from that, it should be obvious that Siglent is heading more in the direction of LeCroy (and R&S), so we certainly shouldn't confuse professionals by arbitrarily changing names of measurements they have long been familiar with. Not after all that time anyway.
I take it that professionals would know that standard deviation is the same as RMS without the DC component and that RMS includes DC by definition.
The misleading terms have been widespread for DMMs as well, with names like "True RMS". What's a "true" RMS (as opposed to just RMS)? Well, I remember at least one company that used RMS for Standard Deviation and "True RMS" for RMS.
Yes, we know that.
But these options used to be separate devices in a special housing, bolted on top of scopes that were prepared to display the DMM measurements. I think I've even seen some with their own display, back in the days when scopes didn't support alphanumeric readout on the CRT. In any case they had individual 4mm sockets. So pretty much the same as a scope meter, the latter with good portability for service technicians - and that certainly makes sense.
Apart from students on a tight budget, who would like to have as many features for as little money as possible in a single device, I cannot imagine anyone wanting a bolted-on or even integrated solution in a scope over a proper separate and independent device in a lab.
« Last Edit: June 20, 2019, 07:05:19 am by Performa01 »
Offline tinhead
« Reply #57 on: June 20, 2019, 09:23:13 am »
- External brick (forget the SAG1021.. there's going to be the SAG1021I where "I" stands for isolated, +/-42V of isolation
giving the problematic offset with SAG1021, Siglent should replace all already sold devices by SAG1021I.
Offline EEVblogTopic starter
« Reply #58 on: June 20, 2019, 09:45:47 am »
"True RMS" came about because all meters on AC are calibrated to display an RMS value, but one without "True RMS" are only valid for pure sine waves.
Offline David Hess
  • DavidH
« Reply #59 on: June 20, 2019, 04:57:16 pm »
Yes, we know that.
No No No!  I am referring to oscilloscopes where the DVM was coupled directly into the vertical input and measurements are made through the oscilloscope probe!
The example below is from the Tektronix 2236.  Coupling to the DVM occurs immediately after the high impedance buffer through R20 as marked.  Further, the state of the input attenuators, probe coding (x1 or x10), and input coupling (AC or DC), are also forwarded to the DVM as marked.  (1)
Tektronix produced a special x10 probe for this model to preserve the accuracy of the DVM since standard oscilloscope probes are typically no better than 1% and are often worse.  Tektronix also made probes which could be trimmed for DC accuracy but except for the ones LeCroy inherited from Preamble and is discontinuing, I know of no such thing being made now.
(1) The vertical input coupling selection literally determines whether the DVM makes an AC RMS or average DC measurement and the schematic is even marked to indicate this.  Ambiguity was not a virtue back then.  The RMS converter is AC coupled to remove any DC offset from the internal circuits.
I would have said this if you had not.
"AC" makes sense, "RMS calibrated" makes sense, and "True RMS" makes sense.  But "RMS" alone sometimes confusingly could mean either or even AC + DC RMS as we have discovered.
« Last Edit: June 20, 2019, 05:03:10 pm by David Hess »
Offline tautech
« Reply #60 on: November 02, 2019, 12:03:28 pm »
For those that might find this thread, the ongoing and latest discussion is here:
https://www.eevblog.com/forum/testgear/at-last-siglent_s-sds5054x-touchscreen/
Avid Rabid Hobbyist
