Author Topic: EEVblog #1258 - MORE Dumpster Wandel And Goltermann  (Read 2299 times)
Offline EEVblogTopic starter
« on: October 31, 2019, 09:45:22 pm »
Another dumpster Wandel And Goltermann bit of kit torn down. The PMG-3 Transmission Test Set
The following users thanked this post: johnlsenchak
Offline Ketturi
    • Ketturi Electronics
Re: EEVblog #1258 - MORE Dumpster Wandel And Goltermann
« Reply #1 on: October 31, 2019, 10:24:35 pm »
All W&G gear comes with teardown tools! Look behind of the previous one, there should be a gray box that contains spare fuse, hex key and usually hook for lifting boards. You also should be able to lift whole internal cage out after the top cover is removed. These are absolutely fantastic gear, sadly most of them were made for analog and early digital POTS network measurements, so many of them are obsolete at least in their original use case. I have disassembled couple of W&G T-carrier analyzers, both had failed due leaky NiCad batteries. I still have the cases around as I was planing to make kick-ass computer case out of them.
Ketturi electronics: http://ketturi.kapsi.fi
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #2 on: October 31, 2019, 11:44:27 pm »
Couldn't you use  that  frequency  oscillator  to  test  audio  equipment  like a  tube  amplifier  since  it goes down to 20 hertz ?
Service  Manual !
https://elektrotanya.com/wandel.and.goltermann_pmg-3_sm.pdf/download.html     8)
« Last Edit: October 31, 2019, 11:49:44 pm by johnlsenchak »
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #3 on: November 01, 2019, 09:21:31 am »
Just an FYI: I have two PCM-4's of which one is in auction. But if a member in good standing in the EU (prefereably close enough to Belgium) (yes, the UK still counts for the moment) is in interested in a good teardown I'm willing to send one free of charge. For the fun of it. I'd send it to Dave but it would cost me a arm, a leg and possibly one of my daughters to ship and then it would probably only arrive in bits and pieces anyways. So, if anyone's interested..
Offline jonovid
    • JONOVID
« Reply #4 on: November 01, 2019, 10:34:56 am »
need do something about backlighting that display.
can't see a thing on it.  :o
however the sound is just marvelous, not since my fathers shortwave radio.
as it got to warm up.  :clap:
Hobbyist with a basic knowledge of electronics
Offline SNGLinks
« Reply #5 on: November 02, 2019, 11:05:24 am »
Here are my two W&G units. Rather smaller than your's :)
