Author Topic: EEVblog #1263 - Mailbag  (Read 1965 times)
Offline EEVblog
« on: November 20, 2019, 02:19:35 am »
Mailbag time!
SPOILERS:
Automated Factory robot laser scanner teardown
Siemens & Schneider Electric safety timer switch teardowns.
18:54 HTC Vive VR Base Station Teardown
37:35 40W 180V Nixie tube driver: https://www.tindie.com/products/nexus/40-watt-high-voltage-nixie-power-supply/
https://neonkev.com/2019/10/15/success-201-boost-at-40-watts-without-a-transformer/
45:07 Hadou-CAN USB CAN adapter: https://www.tindie.com/products/suburbanembedded/hadou-can-usb-can-fd-adapter/
The following users thanked this post: rounin, DenCraw
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
Re: EEVblog #1263 - Mailbag
« Reply #1 on: November 20, 2019, 04:35:21 am »
Great Scott Outback Dave ,  at   18:36 minutes  you incorrectly  called   the IRF840  a  transistor, it's  actually  a  MOSFET  8) 8) 8)
https://components101.com/sites/default/files/component_datasheet/IRF840-Datasheet.pdf
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Online maginnovision
« Reply #2 on: November 20, 2019, 05:22:43 am »
metal–oxide–semiconductor field-effect transistor
The following users thanked this post: colinza, SparkyFX
« Reply #3 on: November 20, 2019, 05:41:00 am »
Good  call  it may  say it's a transistor, but it's does  say "field-effect transistor"  and  acts   more like a  vacuum  tube, then a straight   dual P/N   junction  transistor that's either  NPN  or PNP    I'm  just defining  the difference  between  the two even though  they both  either switch  or do gain
Sort of  like a  Triode  and a Pentode , both are " Vacuum  tubes" , and they both either   switch  or do  gain for amplification  . But their   functionality on  how they operate   internally  is  different due to how it's manufactured
« Last Edit: November 20, 2019, 06:04:37 am by johnlsenchak »
Offline FrankBuss
    • Frank Buss
« Reply #4 on: November 20, 2019, 08:47:22 am »
Found a nice video what the HTC Vive tracker does:
Here is an explanation how it works, includes the video as well. Accuracy is about 1.5 mm, and it even works with just one station (with less accuracy).
I once tried a HTV Vive VR, and it is amazing how good the tracker is. But the headset was not very comfortable, and the field of view and display resolution not that great, and at least when I tried it, the image was only sharp in a small area, e.g. I couldn't read text when it was not in the center. Maybe needed some calibrations or adjustments. I tried a Microsoft Hololens as well, and it was much better, but much more expensive as well.
Online Pack34
« Reply #5 on: November 20, 2019, 10:38:06 am »
@Dave,
The serrations you noted in front of the image sensor on the scanner are called baffling. The purpose is to mitigate stray light issues. The image sensor does a good job absorbing the light, but light coming into the system can be off-axis and bounce off the sides. In general, this would reduce the SNR of your resulting image or create false images and ghosting. Another method to mitigate stray light is the finish and painting of the optical channel. This is one of the practical applications Vantablack.
Related reading:
https://www.newport.com/t/stray-light-in-monochromators-and-spectrographs
The following users thanked this post: thm_w, jonovid
Offline NivagSwerdna
« Reply #6 on: November 20, 2019, 04:09:05 pm »
"Don't eat the desiccant" such wise words...  I wonder if bigclive eats his?
"Desiccants are the most common foreign object ingestion by children under 6 years of age"
Sounds like the choking is the issue, so probably best to eat them in small pieces.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #7 on: November 20, 2019, 07:51:18 pm »
I remember a huge thread here on the forum about development of a high voltage power supply for Nixies, was that the same guy? Must have been about half a year ago.
Offline jonovid
    • JONOVID
« Reply #8 on: November 20, 2019, 09:36:01 pm »
HTC Vive VR Base Station has what looks like two spinning laser lines
the corrugated or ripple laser lens on the side of rotating drum outputs a sweeping line.
laser beam gos down the middle, axis of the drum. rotating cylinder & mirror.
two spinning laser lines give you X & Y if your motor degrees of rotation is a know value.
by timing your laser lines a 3D space is mapped out.  robot eyes
the tools & Bits  8)
quality hand tools gos next to quality test equipment.
a must have. for my bench.  :-+
« Last Edit: November 20, 2019, 09:42:26 pm by jonovid »
Hobbyist with a basic knowledge of electronics
Offline numloxx
« Reply #9 on: November 21, 2019, 12:20:38 am »
Glad you got my postcard. They have so much stuff at the Heinz Nixdorf Museum in Paderborn. I spent the entire day there. Huge calculator collection as well.
https://www.hnf.de/en/home.html - Museum
Calculator collection - https://twitter.com/numloxx/status/1171713415745888256
Enjoy :)
Offline station240
« Reply #10 on: November 21, 2019, 06:32:40 am »
Those USB to CAN adapters are handy for debugging, or capturing traffic for reverse engineering.
I should be doing more CAN stuff at the moment, but the last CAN device I bought of ebay isn't turning up |O
Seems there are two versions of the Hadou, bare PCB and cased, so Dave actually has two of these.
Offline Fungus
« Reply #11 on: November 21, 2019, 07:53:08 am »
Do you know what the 'T' stands for in "MOSFET"?
Offline ETITsynthesizer
« Reply #12 on: November 21, 2019, 03:21:56 pm »
Dave, when you said you didn't have a 40W resistor on hand that was a bit cringey for me. you have $10K in oscilloscopes but you don't have a $3 dummy load? I went on ebay. you can get a 300R and a 500R for $2.20 USD with free shipping. close enough to 810 Ohms to test that nixie driver. please do a part two.
https://www.ebay.com/itm/25-50-100W-0-01-5k-Ohm-Watt-Shell-Power-Aluminum-Housed-Case-Wirewound-Resistor/152815608794
at work we have a 600A dummy load built into a (stolen?) shopping cart. we don't have current sense shunts over 150A though. we do all the power supply calibrations at 150A or 140A. then we load test at up to 600A.
« Reply #13 on: November 21, 2019, 06:02:06 pm »
I agree. That PSU claims 40W (although I don't know why you need to go that high, I am sure my small tube display draws 5W ish... Maybe big tubes need more). We want to see it cranked up to 11 with smoke coming out and some FLIR action.
Offline FrankBuss
    • Frank Buss
« Reply #14 on: November 21, 2019, 07:05:41 pm »
Good idea with a short follow up video for the Nixie power supply. In the mailbag video, I expected that he would at least test the short circuit protection with a screwdriver or something, when he measured the voltage. Sometimes they are a bit optimistic with such claims :) Would be a very useful device for me, someday I plan to finish my Nixie clock. Price is a bit high, but if it meets the spec, and doesn't cause EMC problems etc., I would pay it.
Offline Mr. Scram
  • Display aficionado
« Reply #15 on: November 21, 2019, 07:42:12 pm »
Apparently eating desiccant isn't an issue at all.
"Silica gel is chemically inert and is considered to be non-toxic.  The concern with this substances it that it can be a choking hazard (this is why these packets often say ‘DO NOT EAT’ on them). If your child is choking on silica gel, call 911 immediately."
Offline nexus
« Reply #16 on: November 23, 2019, 09:07:29 pm »
Hi all,
This is Kevin A. I'm the guy who made the nixie power supply.
I did drop ship Dave the same resistor I used for load testing from Digikey. Hopefully he does a follow up with some load testing.
I did also take some FLIR images and videos of the supply running at a 200 milliamp load on the high voltage. You can check it out at the bottom of the post I did on this topic at: https://neonkev.com/2019/10/15/success-201-boost-at-40-watts-without-a-transformer/
The following users thanked this post: thm_w, NivagSwerdna
Offline 3roomlab
  • can you tell me how to cal sesame street meter?
« Reply #17 on: November 24, 2019, 01:28:46 am »
that robot warehouse ...
3months after their robot video
some faulty battery charger starts a fire  :(
>GBP100 million lost
overclocked CPU and GPU are a waste of energy and time, it is highly energy + calculation inefficient vs watts. there is an entire influencer industry milking users off it, they call it "premium" but lifespans are short, oxymoronic crap , more like single use.
Offline Andrew McNamara
« Reply #18 on: November 26, 2019, 11:49:54 pm »
>GBP100 million lost
Some decent coverage here: https://www.bbc.com/news/uk-england-hampshire-49071456
Some key points from the article:
  • fire started in a robot's battery charger
  • not detected by fire detection system
  • engineer noticed the fire half an hour later
  • sprinkler system activated, but was disabled for five minutes while they attempted to fight the fire by hand
  • this allowed the fire to spread to the point where most of the facility was impacted
  • 400 staff laid off
« Reply #19 on: November 27, 2019, 12:02:05 am »
Hampshire Fire and Rescue's "Ocado Fire Contributory Factors" brief: https://www.esfrs.org/_resources/assets/attachment/full/0/28939.pdf
Offline mcovington
« Reply #20 on: December 02, 2019, 05:27:01 am »
Why not load the 180V power supply with a 240-volt incandescent light bulb?  Better than not being able to do the test at all.
