Author Topic: screen tear on forum with firefox and 4K monitor  (Read 494 times)
Offline graybeard
  • Senior III-V RF/mixed signal/device engineer
    • Chris Grossman
« on: December 09, 2019, 06:35:28 pm »
I get what looks like a tear in the top of the background of the forum frame when it is displayed on my 4K monitor using Firefox 71.0 64bit on win 10.  It goes away if I lower the resolution.
Chris
Online Shock
Re: screen tear on forum with firefox and 4K monitor
« Reply #1 on: December 10, 2019, 01:05:05 am »
This was mentioned back in July, it's a small but correctable problem with the theme and will affect all users running a high resolution or zoomed out in their browser, so not a problem with your end.
https://www.eevblog.com/forum/suggestions/eevblog-forum-site-have-a-bug-with-high-resolution-monitor/msg2552526/#msg2552526
Multimeters: Fluke 87V, 117, 27/FM     >>> Fluke 51/52 Thermometer Parts Required <<<
Oscilloscopes: Rigol DS1054Z, Phillips PM3065
The following users thanked this post: I wanted a rude username
Offline Zom-B
« Reply #2 on: January 07, 2020, 07:10:13 am »
Unless you have a 50 inch monitor you'll want to use a HiDPI setting of your OS (e.g. 200% on ≤28 inch).
Still you probably want to use 200% because paragraphs stretched that long and thin are tiring to read. It's part of why they invented columns in newspapers.
« Last Edit: January 07, 2020, 07:12:57 am by Zom-B »
