Author Topic: EEVblog #1305 - HEPA Solder Fume Extractor  (Read 9944 times)
Offline SilverSolder
Re: EEVblog #1305 - HEPA Solder Fume Extractor
« Reply #75 on: February 17, 2021, 02:39:32 am »
Interestingly, it seems you can get quite ill from inhaling metal fumes:
https://en.wikipedia.org/wiki/Metal_fume_fever
Offline Zai Kajou
« Reply #76 on: March 14, 2021, 09:17:06 am »
  Just watched the video for this particular fume extractor, and noticed someone found the filters for it as well, just have to message and deal with the company direct I think was said.
So just curious if this was still the way to go, or does anyone have an opinion on the Quick 6101A1 extractor (does seem to be a 3 stage and I'm sure filters are easier to buy)? I've seen it for sale for under 500$ with the tube, unfortunately I don't have the space to have a good setup, so I need some kind of extractor before I do anything, even minor stuff, and from what I've seen/read anything is better than nothing at all, just curious if anyone had any opinions on anything recently, as the companies site from the review no longer even lists that particular model, only saw it on Alibaba, and by the time you pay for the extractor and shipping the quick seems to be much cheaper.
Just thought I'd see what the thoughts on that are.
« Reply #77 on: March 14, 2021, 03:51:33 pm »
A simple solution, if you don't solder very often and don't have a big budget for fume extraction, is to rig up a little fan on a "helping hand" stand - just place it so it blows the fumes away from your face.
Any old fan (from a PC or whatever... most of us have one lying around)  will do.  For bonus point, add a small speed controller to the fan (eBay, $<very little>).
You could add a carbon filter to the fan, but I don't even bother with that...  open a window, fan on low, good to go.
This idea works because normally, the fumes are attracted to your face due to convection air currents around your head due to your body temperature.  So by just blowing them in a different direction, you inhale much less of it, and it doesn't get in your eyes.  Works for me!  :D
Why does smoke from a soldering iron ALWAYS go towards your face???
« Last Edit: March 17, 2021, 01:14:37 pm by SilverSolder »
Offline unkown_h
« Reply #78 on: March 17, 2021, 01:19:27 am »
Has anyone looked into welding respirator and respirator filters in general. I would think that you would able to find ether a readily available filter or a combination of 2 that would do the trick.
Offline thmjpr
« Reply #79 on: March 17, 2021, 04:09:05 am »
Sure those would work, but why? You can buy P100 respirator filters that are not specific to welding, that would be cheaper.
Wearing a respirator when soldering would be super uncomfortable as well.
Generally welding gear prices >> soldering gear prices.
Offline lfldp
« Reply #80 on: March 21, 2021, 12:17:09 pm »
few tips i can say there
is not worth to paying for quick 6101A because you have many cloned chinese fume extractors with cheaper price available to buy and i am sure they uses same quality filters in short
-prefilter
-hepa h13
-gas filter (filter out 85% of gas particles)
clones such as waterun f6100 and others use same filters and these filters have bituminous coal activated carbon impregnated with potassium iodide KI (i am sure quick use same carbon)
for example in last days i buyed one clone link that BEST BST-495 and have also same efficient gas filter here you have video
this fume extractor cost me half price of quick 6101a and also its replacement filters cost half price , i didnt smell any colophony outgoing from this fume extractor (could fell some % of solder fluxes) but this is very small ammount and doesnt irritiate also heavy metal gas from solder wire is reduced alot
in more expensiff fume extractors like for example bofa v300e you have activated carbon + activated alumina impregnated with kmno4 literature claim about kmno4 have wider range of various gas particles removal than potassium iodide
but in reality i dont believe about this bofa v300e gas filters could remove 100% of gas vapours
what means wider range ? in short it doesnt means about bofa v300e filters would clean you 100% air from gas it just meant about its filter could clean air from more different particles > could clean air from more brand of fluxes than other fume extractors
« Last Edit: March 21, 2021, 12:23:44 pm by lfldp »
