Author Topic: EEVblog #1333 - Nano Diamond Self-Charging Battery DEBUNKED!  (Read 7890 times)
Offline EEVblog
Re: EEVblog #1333 - Nano Diamond Self-Charging Battery DEBUNKED!
« Reply #25 on: August 29, 2020, 03:18:00 am »
Well lets speculate a little Dave style, suppose that the're able to stuff lets say 100 of that DIP chip structures into a single modern package ? Suddenly a 10mW battery emerges, possible? Most likely.
Sure, ok. That's still not even close to revolutionising the energy industry.
That AA would still take 400 hours to self re-charge assuming zero losses.
Again, still useful in niche apps of course, but won't revolusionise much or power that EV. And you've already gone two orders of magnitude above what they supposedly have.
Secondly suppose that they can somehow scale they energy output by an order of magnitude or 2 ? Why not ?
Why not 5 orders of magnitude?
I can play that game too.
Looks at their pitch deck linked above, try and find ANY mention of actual power output. It's all just pie in the sky marketing wankery.
Offline EEVblog
« Reply #26 on: August 29, 2020, 03:19:19 am »
I feel like its important because a dead flash light can cause serious trouble.
Err, then don't use it in that application. We are talking remote controls here.
Offline EEVblog
« Reply #27 on: August 29, 2020, 03:32:22 am »
LOL
Offline EEVblog
« Reply #28 on: August 29, 2020, 03:44:49 am »
Question to ponder:
Let's say this can magically scale to an EV sized battery. The radiation never stops producing energy, energy unless consumed in some other way will be given off as heat. Where does the waste heat go?
Useful on spacecaft, you can heat your electronics with it. In an EV, not so much...
The following users thanked this post: helius
Offline pfeerick
« Reply #29 on: August 29, 2020, 04:58:57 am »
Dave bases his opinion on a single sample pics of a through hole chip that's been taken down anyway.
No it hasn't... it's the second picture of the NewAtlas article @ https://newatlas.com/energy/nano-diamond-self-charging-batteries-ndb
And a reverse google image search for the image appears to suggest it is only present in the marketing hyperbole materials... but I didn't go through all the search results...
The thing that would be interesting to find out is the actual energy density - thus it would be possible to work out if the IC package could have a higher output source, or if 100uW really is the limit, thus making this a very disruptive technology... in an alternate reality.  :-DD
Online Bud
« Reply #30 on: August 29, 2020, 05:27:31 am »
LOL
Holy crap, i was wondering what is the deal with IC type packaging. Now if someone could explain how they fit the supercapacitor in it.  :)
Offline Tsippaduida
« Reply #31 on: August 29, 2020, 05:44:34 am »
NDB promises bit too much. Has anyone looked into what these Betavoltaic components cost? They are hideously expensive even when there are no diamond manufacturing involved.
This is quite fresh technology, but the principle is known and there are even competition. In addition to CityLabs, there's Widetronics: https://www.widetronix.com/products
And to look into power densities of the original diamond-based solution you can use the numbers from http://www.bristol.ac.uk/cabot/events/2016/annual-lecture-2016.html
"The actual amount of carbon-14 in each battery has yet to be decided but one battery, containing 1g of carbon-14, would deliver 15 Joules per day.  This is less than an AA battery.  Standard alkaline AA batteries are designed for short timeframe discharge: one battery weighing about 20g has an energy storage rating of 700J/g. If operated continuously, this would run out in 24 hours. Using carbon-14 the battery would take 5,730 years to reach 50 per cent power"
Internet said that betavoltaic batteries cost around $2,200 each (unconfirmed number). And this is from current technologies, without expensive diamond manufacturing process.
They need to make several break throughs before the power density is such that phones can be powered with these. Not impossible (maybe), but don't hold your breath in waiting.
Offline EEVblog
« Reply #32 on: August 29, 2020, 05:47:31 am »
As far as we know, they haven't even gotten the 100uW yet, it's just a render.
Again, take a look at their very extensive investor presentation, it's got absolutely everything, right down to how much all the test equipment costs. Yet try and find a single mention of anything to do with power output.
Offline EEVblog
« Reply #33 on: August 29, 2020, 05:50:19 am »
Costing for the CityLabs 100uW unit is in the thousands of dollars per unit. Pricing is in that article I linked in the video.
Offline EEVblog
« Reply #34 on: August 29, 2020, 05:50:45 am »
Archived for reference purposes:
https://archive.is/GHVYn
https://archive.vn/GHVYn
Offline Domagoj T
  • Country: hr
« Reply #35 on: August 29, 2020, 06:02:36 am »
Question to ponder:
Even on spacecraft waste heat is a problem that needs to be accounted for.
For example, ISS has solar panels that generate about 100kW on average. But ISS also has radiators that dump 70kW of waste heat.
https://en.wikipedia.org/wiki/External_Active_Thermal_Control_System
Offline helius
« Reply #36 on: August 29, 2020, 04:59:48 pm »
The CityLabs units are expensive because tritium is expensive. The betavoltaic generator itself is an IC: which could be cheap as chips or expensive depending on materials. I would be very interested in any pointers to whitepapers describing them, but from what I know I'd guess they would be similar to monocrystalline PV panels, maybe using a stack to increase capture radius.
The diamond stuff should be similar to commercial laboratory grown diamonds, with the important detail that the 14C storage doesn't need to be a single crystal. So even synthetic diamond dust potentially could be used. My understanding is that until recently, there was only one manufacturer of large, monocrystalline synthetic diamonds by CVD and the process details were closely guarded. Has this become a commodity process? If not, there is significant business risk for any startup that hopes to perfect such a process.
Addendum: if the electrical properties of the diamonds aren't critical, it may be possible to use high pressure techniques to synthesize the diamonds, which were perfected by the 1960s. I'm not sure if any plants are still operating with this process, maybe there is equipment hiding in the former USSR? This could be a lot cheaper than CVD considering the latter's strict parameters.
« Last Edit: August 29, 2020, 05:08:29 pm by helius »
Online SmokedComponent
  • Country: si
« Reply #37 on: August 29, 2020, 06:04:59 pm »
Power ICs in all 4 directions!! No nasty 90, 180 degree turns to shoot those scarce electrons out!
Their marketing material is comparable to those soldering stock images. Good stuff!
Offline SMB784
    • Tequity Surplus
« Reply #38 on: August 30, 2020, 01:12:20 am »
LOL
Oh my god is that real?  There's no way that's serious.
Offline Lord of nothing
  • Country: at
« Reply #39 on: August 30, 2020, 01:45:23 am »
Well if it like special Medicine who the Research is adding up mostly not for the Materials that could be a reason why its so expencive.
:-// Why are my Chinese Tritium Marker are so cheap?
Made in Japan, destroyed in Sulz im Wienerwald.
Offline EEVblog
« Reply #40 on: August 30, 2020, 02:36:38 am »
LOL
Yes, they are serious, it's in their investor pitch document to try and raise squillions of dollars.
Offline EEVblog
« Reply #41 on: August 30, 2020, 02:43:29 am »
Aaaaand the documents are gone!
https://ndb.technology/pitch/
They are clearly watching.
Offline hendorog
« Reply #42 on: August 30, 2020, 04:11:58 am »
You are 2nd on google for "nano-diamond self charging battery" and first on youtube. I'd say it would have hit their feed pretty quick :)
Offline SMB784
    • Tequity Surplus
« Reply #43 on: August 30, 2020, 05:51:59 am »
LOL
Why did they stop at 64 pins? They could have made that humdinger in a BGA package. Real missed opportunity to fill the "I need 1000 connections to the same voltage source" niche
« Last Edit: August 30, 2020, 05:53:57 am by SMB784 »
Offline EEVblog
The following users thanked this post: BrianHG
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #45 on: August 30, 2020, 06:49:34 am »
I recently finished a project, that is using 2.5uA@7.2V on average. It is a sensor for sensor network applications. Industry 4 and all that jazz. Battery replacement are very expensive, expected lifetime (by the customer) could be decades. I could imagine using something like this, if you can meet the price target.
Also, it is smaller than the batteries. And probably dont get super hot if short circuited (safety risk)
Also, you can forget about charging regular supercaps. They just dont have the lifetime. Long term test shows, that they start leaking, and that leakage could be larger than the power usage of your device.
But the target price has to be in the range of the current Lithium batteries.
Online BrianHG
« Reply #46 on: August 30, 2020, 07:37:07 am »
See attached clip from 'NDB_One_Pager_Seed.pdf'.
[attachimg=1]
Only 2.3 million?  For tech which can eventually power cars?  Cars which use enough power to also power/heat/air condition my house for 100 years...
Though I know better, as an investor, this 'puny' figure for something so powerful when I personally need over 5x that budget for year 1 to develop a AAA grade iPhone app.
These goofballs know their product is BS and don't have the balls to actually ask for 23 million let alone 50....
« Last Edit: August 30, 2020, 07:40:30 am by BrianHG »
__________
BrianHG.
Offline EEVblog
« Reply #47 on: August 30, 2020, 07:51:10 am »
That's smart though, get some funding to pay basic wages and you don't have to really produce anything for the first year while you wait for the big funding to come through.
But they are going to be generous and only take $80k each for the first year:
« Reply #48 on: August 30, 2020, 08:51:27 am »
You will never get that sort of project into a plastic DIP package, it will always have to be in a fully hermetic package, simply because you need to protect the inside carbon from oxygen, and also because to collect the electrons you will need a fairly high grade vacuum as well, plus somewhere to store the generated alpha particles (helium gas) before they rise up to the pressure that will inhibit the cell operation.  So minimum will be a laser welded glass seal full size 14 or 16 pin DIP package with thin wall stainless steel top and bottom, with a small glass plate inside with the active material sputtered on it, and connected to the one power pin, with the other pins all shorted together and bonded to top and bottom covers as collector.  Laser welded in a ultra high vacuum chamber so that the inner cell is as close to empty as possible of any trace of gas, and likely also baked at 600C there for a few hours as well to get rid of any adsorbed gas in the inner parts.
Vacuum chamber, laser, laser aiming devices, airlock to allow parts in and out are all likely to be custom made, and production rate will be low, based on a good long number of hours per cycle per expensive jig. Only things off the shelf will be the laser itself, and the turbomolecular pumps to pull the chamber down, though the airlocks will be similar to existing SEM sample entry ports, and your window allowing the laser in would probably be an optically pure diamond window.
To scale up just put more surface area of active material, and a bigger enclosure, but there you run into limits before you have to class it as radioactive, which is why smoke detectors, while actually containing radioactive material, are not classed as hazardous radioactive waste.
A rough and ready way to DIY ( if you have a glass forming ability and can achieve neon tube levels of evacuation at home) is to use the ready made smoke detector active emitters in a vacuum tube, wonder if there are any DIY videos of this out there.
The following users thanked this post: EEVblog, BrianHG, Andrew McNamara
Online Fungus
« Reply #49 on: August 30, 2020, 09:45:07 am »
We can revolutionize the world of TV remote controls for only a couple of thousand $$$ each and a remote control the size of a shoe box...?
 :palm:
« Last Edit: August 30, 2020, 09:49:03 am by Fungus »
